rear exit shifter cable in e body #1553392
12/26/13 04:42 PM
12/26/13 04:42 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
Has anyone used a aftermarket shifter with rear exit in a e body? like to buy a pro bandit shifter but all i seen say or show rear exit
like to put some type of pistolgrip shifter in our challenger
car has foward non manual shift valve body
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: rear exit shifter cable in e body [Re: toplescuda] #1553393
12/26/13 08:14 PM
12/26/13 08:14 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
You would be better off with a rear exit shifter cable because everyone I know that has the cable go towards the front (on the side of the trans) ends up with the cable getting melted by the headers.
Re: rear exit shifter cable in e body [Re: SNK-EYZ] #1553394
12/26/13 08:48 PM
12/26/13 08:48 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Is rear exit cable even a option in a e body
wont the lever on tranny be moving oppsite in a rear exit cable shifter?
1971 charger
Re: rear exit shifter cable in e body [Re: toplescuda] #1553395
12/26/13 09:45 PM
12/26/13 09:45 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
No, the difference is that it swaps direction (if it was pushing to up or down shift it will now be pulling) no problem with a Morse cable.
What is a problem is getting a straight shot at the lever with the cable. On my 70 Cuda I drilled a hole through the trans crossmember and made a bracket. Takes a little engineering and effort but no more burned cables.
Re: rear exit shifter cable in e body [Re: toplescuda] #1553396
12/26/13 09:56 PM
12/26/13 09:56 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
I usually mod my Hursts so that they come to the shift arm from the rear. I posted a pic of this on a thread here a day or two ago. It is not hard or complicated and works real well.
You anchor the end of the cable to a bolt threaded into the kick down pivot. Then weld a washer on to the pin that goes to the shift arm and put that between the nuts on the end of the cable housing.
That way, the cable inner is held steady while the housing moves back and forth with the shift lever.
One more tip; if you have any pick and pull yards near you, you can look in the engine bays of later model GM cars that have the engine removed. Some of them have the neatest heat sleaves over some lines and hoses. Those sleaves work great to further protect the cable from exhaust heat. And they are cheap.
Master, again and still
Re: rear exit shifter cable in e body [Re: DaveRS23] #1553397
12/27/13 01:39 AM
12/27/13 01:39 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Winters Shifters are rear exit.
Re: rear exit shifter cable in e body [Re: topbrent] #1553398
12/27/13 10:53 AM
12/27/13 10:53 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
What did you fab up.to keep.the cable from flopping against the.driveahaft and exhaust?
1971 charger
Re: rear exit shifter cable in e body [Re: toplescuda] #1553399
12/27/13 11:49 AM
12/27/13 11:49 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Rear exit PP shifter
Re: rear exit shifter cable in e body [Re: dthemi] #1553400
12/27/13 01:35 PM
12/27/13 01:35 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
How long of cable did you need?
1971 charger
Re: rear exit shifter cable in e body [Re: toplescuda] #1553401
12/27/13 02:38 PM
12/27/13 02:38 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
PPP here as well...Needed a 3' or 2' cable. I think mine was a 3'..
