325-50-15 's under stock Challenger #1552816
12/24/13 11:35 PM
12/24/13 11:35 PM
St. Peters MO
speedfreek Offline OP
St. Peters MO
With the number of posts about how big will fit I thought I'd throw my setup in the mix. I moved my super stock spring hanger over so the outer studs were in the inner holes. Basically right against the framerail, so much so that I had to make a large hole for the front spring bolthead to be inside the framerail. I made offset hangers and custom bushings out of Delrin to get the springs pointed the right way out back.
I narrowed a Dana 60 and am using 15x10 Rallye wheels with Mickey Thompson 325-50-15 drag radials.
1" clearance inside and outside.
Re: 325-50-15 's under stock Challenger [Re: speedfreek] #1552817
12/24/13 11:36 PM
12/24/13 11:36 PM
St. Peters MO
St. Peters MO
Another
Re: 325-50-15 's under stock Challenger [Re: speedfreek] #1552818
12/24/13 11:40 PM
12/24/13 11:40 PM
St. Peters MO
St. Peters MO
A different angle
Re: 325-50-15 's under stock Challenger [Re: speedfreek] #1552819
12/24/13 11:40 PM
12/24/13 11:40 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Any side pics ?
Never mind you beat me to it.
Re: 325-50-15 's under stock Challenger [Re: 69CHARGERMD] #1552820
12/24/13 11:45 PM
12/24/13 11:45 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
What leaf springs are you using ? Stock ride height or 1" over?
Re: 325-50-15 's under stock Challenger [Re: 69CHARGERMD] #1552821
12/24/13 11:46 PM
12/24/13 11:46 PM
St. Peters MO
St. Peters MO
Mopar Super Stock springs
Re: 325-50-15 's under stock Challenger [Re: speedfreek] #1552822
12/24/13 11:50 PM
12/24/13 11:50 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Thanks. Going for the same look, b body Dana, big tire etc, was going to use espo 1" over stock ride height
Kinda confused on what tire size after seeing yours ( which looks awesome)
295/65 vs 325/50 ???
Great looking car
Re: 325-50-15 's under stock Challenger [Re: 69CHARGERMD] #1552823
12/24/13 11:55 PM
12/24/13 11:55 PM
St. Peters MO
St. Peters MO
Thanks.
I narrowed a Dana 2"from E body spec and with the springs moved over the wheelwell is the limiting factor. The tires are perfectly centered using those off the shelf Rallye's.
Re: 325-50-15 's under stock Challenger [Re: speedfreek] #1552824
12/25/13 12:05 AM
12/25/13 12:05 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Going to put a Dana in this soon,,,,thanks for your pics,,,looks awesome
Re: 325-50-15 's under stock Challenger [Re: 69CHARGERMD] #1552825
12/25/13 12:07 AM
12/25/13 12:07 AM
St. Peters MO
St. Peters MO
Thanks again. Good luck!
Re: 325-50-15 's under stock Challenger [Re: speedfreek] #1552826
12/25/13 12:36 AM
12/25/13 12:36 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
they fit real nice on my 'cuda
Re: 325-50-15 's under stock Challenger [Re: speedfreek] #1552827
12/25/13 12:47 AM
12/25/13 12:47 AM
WI.
Scotts71chall Offline
WI.
I run them also, but with coilovers
Re: 325-50-15 's under stock Challenger [Re: Scotts71chall] #1552828
12/25/13 12:53 AM
12/25/13 12:53 AM
St. Peters MO
St. Peters MO
Not much spring action that way!
Re: 325-50-15 's under stock Challenger [Re: speedfreek] #1552829
12/28/13 01:48 AM
12/28/13 01:48 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Re: 325-50-15 's under stock Challenger [Re: speedfreek] #1552830
12/28/13 07:50 PM
12/28/13 07:50 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Looks great. Have any picts of the underside?
Damon
Re: 325-50-15 's under stock Challenger [Re: mopardamo] #1552831
12/30/13 03:46 PM
12/30/13 03:46 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Looks awesome. I just prefer the extra dia on the sidewall of the 315/60's on my Challenger This is also on a 12" wide wheels . Required a mini tub & moving springs to the frame rail though.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 325-50-15 's under stock Challenger [Re: 69CHARGERMD] #1552832
12/30/13 05:43 PM
12/30/13 05:43 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
DO i Spy a new car Build?? Hey Doug got any info on your new car build? please pm if you need to. thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: 325-50-15 's under stock Challenger [Re: mopar65] #1552833
12/30/13 06:07 PM
12/30/13 06:07 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I had 315/60/15s in mine.
Mopar Performance
