Re: 6-PAC SCOOP ISSUES SOLVED......................
[Re: GTX MATT]
#1552599
12/26/13 01:02 AM
12/26/13 01:02 AM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
if he has an adjustable wastegate he can wind in more power & he's got 4wd.
Get him to go three rounds with you, he will be broken by the end, especially if he tries to crank the boost up.
Highly unlikely. Their stock long blocks will run a ways into the 9's for at least two seasons and lots of street miles. That I can guarantee. You.
Rooting for the mopar but nothing in racing is easy ![](/ubbthreads/images/graemlins/wink.gif)
[Re: justinp61]
#1552601
12/26/13 01:14 AM
12/26/13 01:14 AM
Posts: 52,972 Romeo MI
MR_P_BODY
My carb is 5 or so inches from the top of my six pack scoop and I've thought about drilling a couple 1" holes in the base plate and see if it picks up any.
Why dont you guys start testing those scoops... you all want to use them but only because they are"correct".. tape 2" long pieces of yarn to the front outside and front inside... tape a camera to the hood in front of the scoop and see whats happening... the yarn is a cheapo wind tunnel test.. we actually do the yarn thing in the wind tunnel before smoke testing, just to get a idea where to look ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 67mprfan]
#1552604
12/26/13 02:07 AM
12/26/13 02:07 AM
MR_P_BODY
mine came with the car and I'm to cheap to buy a new 1 just holding off until a used 1 to pop up
What have you done to see if you can make it better... have you tried no hood, have you tried raising the hood.. I bought the scoop I have just to get the inlet up into the clean air flow... do I need it that high.. no I could get away with 3" lower but the more distance between the carb and scoop only help.. but I also use the string theory(string from the front of the hood to the roof line) and have the bottom of the inlet at or above the string ![](/ubbthreads/images/graemlins/wave.gif)
[Re: GTX MATT]
#1552608
12/26/13 03:09 AM
12/26/13 03:09 AM
SpareParts
Janesville, WI
Besides the fact that the stock long blocks have cast rods and pistons, and the cranks would hit the pavement, even if that were true their drivetrains won't last that many passes in the 9s.
Like I said I am rooting mopar, fact is the 4G63 crank is proven well into the 8's, the rest of it will go into the 9's reliably. Where you will see issues is the transfer case (in a talon) but the EVO has a much stronger T case. I'm not thrilled about it either but it's what it is.
[Re: Monte_Smith]
#1552609
12/26/13 03:41 AM
12/26/13 03:41 AM
Posts: 778 Sherwood park, Alberta.
go green
Most 6 pack scoops, HEMI scoops and WO/RO scoops are strictly for carb clearance, nothing aero about them. They are actually horrendous as far as drawing air. I would wager that 95% of the guys that use these unsealed and the carb actually protrudes up INTO the scoop, would be just as fast or faster with the opening blanked off and let the carb get underhood air. The underhood air, while hot, would be less turbulent.
FUNCTIONAL scoops are extremely rare
Monte
This right here ^^^^
The six pack scoop gets worse as speed increases , the frontal area on stock vehicles causes a low pressure area from deflecting air off of the grill causing a dead spot and lift zone area right around the scoop. By drilling holes in the back of the scoop you are actually letting air in not out from the high pressure area around the front windshield , this is the thought process around the cowl hood .
[Re: go green]
#1552613
12/26/13 02:12 PM
12/26/13 02:12 PM
MR_P_BODY
Monte
some of the guys are thinking backwards on what is really happening with the holes ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Thumperdart]
#1552615
12/26/13 03:04 PM
12/26/13 03:04 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Not my case..............I attached yarn to my hood and it`s being pulled in so it`s taking air in the ft. plus now it`s not trying to rip itself off as bad at speed.
If you can get your hands on an old Direct Connection manual, read the section on hood scoops. It explains perfectly what is happening and why most factory scoops are useless.
As for the yarn trick....unless you put it RIGHT at the opening of the scoop and filmed it during a pass, you still don't know. And even if it DOES pull the yarn in, doesn't mean a whole lot. As was mentioned above, the holes in the rear of the scoop are now allowing some air to the carb. THAT is what helped it. Aside from high in the air, the low pressure area at the base of the windshield is the BEST place to draw air and now you are doing that with the rear holes
All this same stuff you guys are talking about right now was PROVEN way back in the 70s by the Chrysler engineering team. The front end of a 70 Dart is still like it was in.......well, the 70s and the aero hasn't changed. Stock scoops suck(not air though), period, end of story.
Monte
[Re: Monte_Smith]
#1552616
12/26/13 03:20 PM
12/26/13 03:20 PM
Thumperdart
State of confusion
Monte
If that`s the case about pullin air from the windshield(which I find hard to believe)then how come all of the talk about a cowl having to be as close as possible when the back of my scoop is miles away? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: Thumperdart]
#1552617
12/26/13 03:30 PM
12/26/13 03:30 PM
MR_P_BODY
Monte
Its just a matter of how much pressure is at any given point... I'm sure there is more pressure at or real close to the windshield vs 8"-10" forward of it... put a hose to a inches of water gauge and move the end of the hose to different points to see what kind of pressure is in different spots(make sure the end of the hose is angled the same... then even aim the hose inlet in different directions to see if it changes) ![](/ubbthreads/images/graemlins/wave.gif)
