Page 2 of 4 1 2 3 4
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: MR_P_BODY] #1552598
12/26/13 12:21 AM
12/26/13 12:21 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Pics please I'm in the same boat
Happy Holidays
Part of your problem is the carb to scoop clearance...
your asking a lot to have the air turn 90* in
that short distance... you would like the air horn
below the stock hood about 3/4" then use a ideal entry
which most on here call a velocity stack for the radius
Hey Mr P my problem is carb to hood clearance because I'm running a dominator carb with a 2 in spacer on a indy intake with a 4150 flange but in the spring I will try my 1000hp holley carb to see if I gain a better signal
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: GTX MATT] #1552599
12/26/13 01:02 AM
12/26/13 01:02 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
if he has an adjustable wastegate he can wind in more power & he's got 4wd.
Get him to go three rounds with you, he will be broken by the end, especially if he tries to crank the boost up.
Highly unlikely. Their stock long blocks will run a ways into the 9's for at least two seasons and lots of street miles. That I can guarantee. You.
Rooting for the mopar but nothing in racing is easy
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: 67mprfan] #1552600
12/26/13 01:03 AM
12/26/13 01:03 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My carb is 5 or so inches from the top of my six pack scoop and I've thought about drilling a couple 1" holes in the base plate and see if it picks up any.
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: justinp61] #1552601
12/26/13 01:14 AM
12/26/13 01:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Why dont you guys start testing those scoops... you
all want to use them but only because they are"correct"..
tape 2" long pieces of yarn to the front outside and
front inside... tape a camera to the hood in front
of the scoop and see whats happening... the yarn is
a cheapo wind tunnel test.. we actually do the yarn
thing in the wind tunnel before smoke testing, just
to get a idea where to look
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: MR_P_BODY] #1552602
12/26/13 01:52 AM
12/26/13 01:52 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
mine came with the car and I'm to cheap to buy a new 1 just holding off until a used 1 to pop up
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: MR_P_BODY] #1552603
12/26/13 01:59 AM
12/26/13 01:59 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
MrP I know the scoop works when sealed to the air pan. I just want to see if turbulence is costing some et and a couple holes in the base plate isn't hard to do or cover if it doesn't help. When I was messing with my LM2 this fall I tested it on back to back to back passes. I'd made several passes and decided to remove the air pan and see what it would do. It wasn't happy, I don't recall how much it fell off but it surprised me. Put the air pan back on and the et and mph came back.
Would it be faster with an aero? Probably. I like my scoop and that's all that matters to me.
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: 67mprfan] #1552604
12/26/13 02:07 AM
12/26/13 02:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What have you done to see if you can make it better...
have you tried no hood, have you tried raising the hood..
I bought the scoop I have just to get the inlet up
into the clean air flow... do I need it that high..
no I could get away with 3" lower but the more distance
between the carb and scoop only help.. but I also
use the string theory(string from the front of the
hood to the roof line) and have the bottom of the inlet
at or above the string
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: MR_P_BODY] #1552605
12/26/13 02:58 AM
12/26/13 02:58 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Most 6 pack scoops, HEMI scoops and WO/RO scoops are strictly for carb clearance, nothing aero about them. They are actually horrendous as far as drawing air. I would wager that 95% of the guys that use these unsealed and the carb actually protrudes up INTO the scoop, would be just as fast or faster with the opening blanked off and let the carb get underhood air. The underhood air, while hot, would be less turbulent.
FUNCTIONAL scoops are extremely rare
Monte
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: MR_P_BODY] #1552606
12/26/13 02:58 AM
12/26/13 02:58 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Mike I tried a air pan but the car really didn't like it and it wasn't made more of just a funnel for the air to come straight to 1 of the changes I'm looking to make or try is a different manifold with dominator flange or as stated earlier 1000hp carb with 1 in spacer(this will lower the carb but not sure if it can match up to the dom but testing will tell). Thanks for the input Mike
Dom sorry if we are hijacking your thread
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: SpareParts] #1552607
12/26/13 03:04 AM
12/26/13 03:04 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Besides the fact that the stock long blocks have cast rods and pistons, and the cranks would hit the pavement, even if that were true they will likely break something drivetrain related making a few passes in the 9s.
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: GTX MATT] #1552608
12/26/13 03:09 AM
12/26/13 03:09 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Besides the fact that the stock long blocks have cast rods and pistons, and the cranks would hit the pavement, even if that were true their drivetrains won't last that many passes in the 9s.
Like I said I am rooting mopar, fact is the 4G63 crank is proven well into the 8's, the rest of it will go into the 9's reliably. Where you will see issues is the transfer case (in a talon) but the EVO has a much stronger T case. I'm not thrilled about it either but it's what it is.
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: Monte_Smith] #1552609
12/26/13 03:41 AM
12/26/13 03:41 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
Monte
This right here ^^^^
The six pack scoop gets worse as speed increases , the frontal area on stock vehicles causes a low pressure area from deflecting air off of the grill causing a dead spot and lift zone area right around the scoop. By drilling holes in the back of the scoop you are actually letting air in not out from the high pressure area around the front windshield , this is the thought process around the cowl hood .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: MR_P_BODY] #1552610
12/26/13 01:57 PM
12/26/13 01:57 PM
State of confusion
Thumperdart Offline OP
State of confusion
Happy Holidays
I have a tube connecting the air horns w/holes drilled in it. Just picture 5 evenly space holes drilled in the back of the scoop then tear dropped wide on top to smaller on the bottom...........upside down tear drops. I`ll get pics today and have em posted.
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: GTX MATT] #1552611
12/26/13 02:01 PM
12/26/13 02:01 PM
State of confusion
State of confusion
He kills clutches monthly and his 10-sec honda kills trannies..........I HATE IMPORTS...........
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: justinp61] #1552612
12/26/13 02:09 PM
12/26/13 02:09 PM
State of confusion
State of confusion
Did this and it did nothing. Think about this; the air is swirling around at the BACK of the scoop not the bottom..............add holes to the BACK of the scoop(pics today)and you`ll see what I did IF it`s sealed and pullin air..............Went from 12.8 afr`s to 14.2 at wot........ Went from 11.2-12.2 cruise to 13.2-14.2 and it`s clean and crisp..............
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: go green] #1552613
12/26/13 02:12 PM
12/26/13 02:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Monte
some of the guys are thinking backwards on
what is really happening with the holes
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: MR_P_BODY] #1552614
12/26/13 02:18 PM
12/26/13 02:18 PM
State of confusion
State of confusion
Not my case..............I attached yarn to my hood and it`s being pulled in so it`s taking air in the ft. plus now it`s not trying to rip itself off as bad at speed.
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: Thumperdart] #1552615
12/26/13 03:04 PM
12/26/13 03:04 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If you can get your hands on an old Direct Connection manual, read the section on hood scoops. It explains perfectly what is happening and why most factory scoops are useless.
As for the yarn trick....unless you put it RIGHT at the opening of the scoop and filmed it during a pass, you still don't know. And even if it DOES pull the yarn in, doesn't mean a whole lot. As was mentioned above, the holes in the rear of the scoop are now allowing some air to the carb. THAT is what helped it. Aside from high in the air, the low pressure area at the base of the windshield is the BEST place to draw air and now you are doing that with the rear holes
All this same stuff you guys are talking about right now was PROVEN way back in the 70s by the Chrysler engineering team. The front end of a 70 Dart is still like it was in.......well, the 70s and the aero hasn't changed. Stock scoops suck(not air though), period, end of story.
Monte
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: Monte_Smith] #1552616
12/26/13 03:20 PM
12/26/13 03:20 PM
State of confusion
State of confusion
Monte
If that`s the case about pullin air from the windshield(which I find hard to believe)then how come all of the talk about a cowl having to be as close as possible when the back of my scoop is miles away?
Re: 6-PAC SCOOP ISSUES SOLVED...................... [Re: Thumperdart] #1552617
12/26/13 03:30 PM
12/26/13 03:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Monte
Its just a matter of how much pressure is at any
given point... I'm sure there is more pressure at
or real close to the windshield vs 8"-10" forward
of it... put a hose to a inches of water gauge and
move the end of the hose to different points to see
what kind of pressure is in different spots(make sure
the end of the hose is angled the same... then even
aim the hose inlet in different directions to see if
it changes)
Page 2 of 4 1 2 3 4
