2008 Ram rear rotors ---HELP!!!! #1552509
12/24/13 02:40 PM
12/24/13 02:40 PM
Cambridge, Ontario, Canada
CUDAJAS Offline OP
CUDAJAS  Offline OP
Any tips on getting the rear rotors off a 2008 ram.
I am in the midst of doing the brakes and the rotors wont budge!!
HELP please.
Thanks,
Jason
Re: 2008 Ram rear rotors ---HELP!!!! [Re: CUDAJAS] #1552510
12/24/13 02:49 PM
12/24/13 02:49 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
BFH...hope you have new ones. Don't forget there's a parking brake in there that may need to be backed off because of rust. Good luck!
Re: 2008 Ram rear rotors ---HELP!!!! [Re: Dcuda69] #1552511
12/24/13 03:54 PM
12/24/13 03:54 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Smack the back side of the rotor with a bfh in the space where the caliper was.
Re: 2008 Ram rear rotors ---HELP!!!! [Re: Dcuda69] #1552512
12/24/13 04:44 PM
12/24/13 04:44 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Spray a good penetrating on the hub register also.That can help get them loose.Then antisieze the hub before you put new rotors on.If you smack them where they seat on the front a lot of times they will pop loose.Did a bunch at work.Dont be suprised if the park brake falls apart also.Had the shoes fall off on a lot of them.You did cut the little clips they have from the factory to hold the rotor on I hope.Rocky
Chrysler Firepower
Re: 2008 Ram rear rotors ---HELP!!!! [Re: therocks] #1552513
12/25/13 02:01 AM
12/25/13 02:01 AM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
small sledge hammer working around the perimeter. The rears on our 02 were very solidly rusted to the axle flange.
Re: 2008 Ram rear rotors ---HELP!!!! [Re: 135sohc] #1552514
12/25/13 12:03 PM
12/25/13 12:03 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
On my 2008 I had to beat them off with a sleg hammer only to find it was a front that was thumping turned the fronts and replaced the rears! Yea kinda have to after that and now lots of anti seize .
I had sprayed penitrating oil over night, tried heat first then with the oil. then a sludge after talking with a mechanic even that did not get them of till the next morning!
3 years ago for me truck only had 30,000 miles and rotors looked like new. wish I had taken fronts in to turn first but wanted them all off at once!
