Re: My Gen III Hemi A-body Borgeson marriage
[Re: BergmanAutoCraft]
#1552270
12/24/13 11:54 AM
12/24/13 11:54 AM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
I installed a 5.7 in a 70 GTX on an Alterktion. I used an engine from a car not a truck. The engineer at TTI flat told me he could NOT make a set of headers for that application. Could not get around the starter. I really do not understand whay everyone "has to have headers" on these gen3 hemis. The exhaust manifold is so short to the collector ,how much can you really gain for the money and hassle. Can it flow much better than this once you pass the heads?
Driving modern convenience in classic beauty
[Re: Darius]
#1552274
12/24/13 03:51 PM
12/24/13 03:51 PM
Posts: 5,388 Pikes Peak Country
TC@HP2
Pikes Peak Country
Oh yeah, it can.
However, if you don' want to mess with the fitment, gasket blow outs, and the occasional re-torque, that's cool too. I don't mind it, but I have friends who do and they stick with manifolds.
[Re: TC@HP2]
#1552275
12/25/13 05:13 AM
12/25/13 05:13 AM
Darius
Sacramento, Ca
I was not suggesting anyone change the entire front suspension or even change their approach. All I was asking is how much more can you gain by going to a custom header of some kind vs what you get from the stock exhaust manifold (my car has stock 5.7 exhaust manifolds). I posted the photo to show just how direct the flow will be with out using headers. I am not a racer so 25 hp won't mean as much to me as some others,therefore the cost and hassle of the header application wouldn't be worth it to me. I will post dyno results when I get to that point with this car...maybe March sometime.
[Re: BigBlockMopar]
#1552277
12/25/13 03:15 PM
12/25/13 03:15 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
This engine won't be just another Gen III btw. 420" , 247/255 cam and cnc 6.1 heads that typically flow in the 360's at .600 lift with stock valves. I wish 2" primaries would've cleared. The reason for me acting like a big baby over my header clearance is the pictures of TTI's display are so misleading.
Mopar to the bone!!!
[Re: 72Swinger]
#1552278
12/25/13 03:22 PM
12/25/13 03:22 PM
72Swinger
Nebraska
And here is reality, see attachment above.
[Re: 72Swinger]
#1552279
12/25/13 03:34 PM
12/25/13 03:34 PM
Darius
Sacramento, Ca
I feel your pain. Don't you just despise the term "bolt on" ? I bought a serpentine pully kit billed as "bolt on". They conveniently forgot to mention the fact you need to eliminate the EGR valve to let the AC compressor fit. No big doing without it but they could have at least supplied the block off plates in the kit or maybe "mention" that would be the case!
[Re: Darius]
#1552280
12/25/13 03:48 PM
12/25/13 03:48 PM
72Swinger
Nebraska
It's hard not to get down right angry. I'm just going to stick with the stock front car acc. drive.
[Re: Uhcoog1]
#1552282
12/26/13 01:13 AM
12/26/13 01:13 AM
72Swinger
Nebraska
Did I mention the very front header bolt holes on BOTH sides will need ovaled out to? Yeah....
