Page 1 of 11 1 2 3 10 11
My Gen III Hemi A-body build. #1552267
12/24/13 05:17 AM
12/24/13 05:17 AM
Nebraska
72Swinger Offline OP
Nebraska
Finally got things going in the right direction by making my own mounts and denting $800 headers...
Re: My Gen III Hemi A-body Borgeson marriage [Re: 72Swinger] #1552268
12/24/13 06:06 AM
12/24/13 06:06 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
Denting TTI'S? Told them about that 4-5 years ago when I got one of the first sets.
-Daty
Re: My Gen III Hemi A-body Borgeson marriage [Re: Daty Rogers] #1552269
12/24/13 09:16 AM
12/24/13 09:16 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Very disappointing that TTI couldn't take care of this properly.
Re: My Gen III Hemi A-body Borgeson marriage [Re: BergmanAutoCraft] #1552270
12/24/13 10:54 AM
12/24/13 10:54 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I installed a 5.7 in a 70 GTX on an Alterktion. I used an engine from a car not a truck. The engineer at TTI flat told me he could NOT make a set of headers for that application. Could not get around the starter. I really do not understand whay everyone "has to have headers" on these gen3 hemis. The exhaust manifold is so short to the collector ,how much can you really gain for the money and hassle.
Can it flow much better than this once you pass the heads?
Driving modern convenience in classic beauty
Re: My Gen III Hemi A-body Borgeson marriage [Re: Darius] #1552271
12/24/13 12:51 PM
12/24/13 12:51 PM
GA
roadrunninMark Offline
GA
Darius,
What are the exhaust manifolds off of that you are using?
Re: My Gen III Hemi A-body Borgeson marriage [Re: Darius] #1552272
12/24/13 12:56 PM
12/24/13 12:56 PM
Nebraska
Nebraska
What I don't understand is why people think they need to ditch Mopar suspension to have a good suspension? Also the ones that think the only way to fit a Gen III Hemi is with an Alter-k? Really so I should've spent $5000 to make life easier?
Mopar to the bone!!!
Re: My Gen III Hemi A-body Borgeson marriage [Re: 72Swinger] #1552273
12/24/13 02:41 PM
12/24/13 02:41 PM
Nevada
dezduster Offline
dezduster  Offline
Nevada
What I don't get is people leaving 25 or more HP at peak and even 5 ft# of torque across the rev range on the table. That's not efficiency. Just because you don't want to deal with headers. Many headers now days fit, most don't leak when properly installed and some fit without modification. BUT WHEN EVERYTHTING IS CUSTOM, ALL ABSOLUTS OR LIKELYIES ARE OFF!!!!
If manufacturers could justify long tube header price, pass NVH issues, install complications, guarantee they would last past the EPA mandate of 100,000 miles and would be trouble free' "no warranty issues". THEY WOULD USE THEM. The power and mileage would be up, EFFICIENCY would be up!! That's why we hot rodders use them!!! They make POWER!! Mileage "efficiency" is a bonus..
Re: My Gen III Hemi A-body Borgeson marriage [Re: Darius] #1552274
12/24/13 02:51 PM
12/24/13 02:51 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Oh yeah, it can.
However, if you don' want to mess with the fitment, gasket blow outs, and the occasional re-torque, that's cool too. I don't mind it, but I have friends who do and they stick with manifolds.
Re: My Gen III Hemi A-body Borgeson marriage [Re: TC@HP2] #1552275
12/25/13 04:13 AM
12/25/13 04:13 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I was not suggesting anyone change the entire front suspension or even change their approach. All I was asking is how much more can you gain by going to a custom header of some kind vs what you get from the stock exhaust manifold (my car has stock 5.7 exhaust manifolds). I posted the photo to show just how direct the flow will be with out using headers.
I am not a racer so 25 hp won't mean as much to me as some others,therefore the cost and hassle of the header application wouldn't be worth it to me. I will post dyno results when I get to that point with this car...maybe March sometime.
Re: My Gen III Hemi A-body Borgeson marriage [Re: Darius] #1552276
12/25/13 07:18 AM
12/25/13 07:18 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
On multiple cylinder engines, a dedicated exhausttube like in a header will scavenge a cylinder better than a combined log-type manifold will.
You still think in terms of flow, while you should be thinking in terms of 4 (hopefully) equal tubes ending all together in a plane in a formed collector where each tube is 'helping' the other tubes to scavenge/pull out the exhaust away from the cylinders.
Besides all this, my believe was that only A-body Mopars have space issues when it comes to 3gen Hemi exhausts.
I also have 5.7Hemi Dart in the works and I'm currently still convinced I will be making my own headers for this setup.
Re: My Gen III Hemi A-body Borgeson marriage [Re: BigBlockMopar] #1552277
12/25/13 02:15 PM
12/25/13 02:15 PM
Nebraska
Nebraska
This engine won't be just another Gen III btw. 420" , 247/255 cam and cnc 6.1 heads that typically flow in the 360's at .600 lift with stock valves. I wish 2" primaries would've cleared. The reason for me acting like a big baby over my header clearance is the pictures of TTI's display are so misleading.
Re: My Gen III Hemi A-body Borgeson marriage [Re: 72Swinger] #1552278
12/25/13 02:22 PM
12/25/13 02:22 PM
Nebraska
Nebraska
And here is reality, see attachment above.
Re: My Gen III Hemi A-body Borgeson marriage [Re: 72Swinger] #1552279
12/25/13 02:34 PM
12/25/13 02:34 PM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I feel your pain. Don't you just despise the term "bolt on" ? I bought a serpentine pully kit billed as "bolt on". They conveniently forgot to mention the fact you need to eliminate the EGR valve to let the AC compressor fit. No big doing without it but they could have at least supplied the block off plates in the kit or maybe "mention" that would be the case!
Re: My Gen III Hemi A-body Borgeson marriage [Re: Darius] #1552280
12/25/13 02:48 PM
12/25/13 02:48 PM
Nebraska
Nebraska
It's hard not to get down right angry. I'm just going to stick with the stock front car acc. drive.
Re: My Gen III Hemi A-body Borgeson marriage [Re: BergmanAutoCraft] #1552281
12/25/13 10:08 PM
12/25/13 10:08 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Any progress on the re-design of #1? Anything I can do to help move this along?
Thanks,
Wade
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: My Gen III Hemi A-body Borgeson marriage [Re: Uhcoog1] #1552282
12/26/13 12:13 AM
12/26/13 12:13 AM
Nebraska
Nebraska
Did I mention the very front header bolt holes on BOTH sides will need ovaled out to? Yeah....
Re: My Gen III Hemi A-body Borgeson marriage [Re: 72Swinger] #1552283
12/26/13 04:20 PM
12/26/13 04:20 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
TTI's seem to be a necessary evil. Nobody can believe that I'm spending $750 for mild steel headers.
Hooker has a 5.7 header but not a 6.1...Pretty disappointing.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: My Gen III Hemi A-body Borgeson marriage [Re: AlexP] #1552284
01/28/14 06:14 PM
01/28/14 06:14 PM
Nebraska
Nebraska
Oil cooler plumbing with thermostat. It will be protected by license plate on the street.
Re: My Gen III Hemi A-body Borgeson marriage [Re: 72Swinger] #1552285
01/28/14 11:04 PM
01/28/14 11:04 PM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
You realize you are going against Mopar convention, the oil filter has to hang over something so that it can not be removed without making a mess that is impossible to clean up.
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: My Gen III Hemi A-body Borgeson marriage [Re: 68cuda440] #1552286
01/28/14 11:10 PM
01/28/14 11:10 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Heck mine is even easier to get to than that one.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
