Page 3 of 6 1 2 3 4 5 6
Re: Hemi Transplant in my '69 Daytona [Re: Slant6pak] #1552088
06/03/14 01:29 PM
06/03/14 01:29 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Did some work this weekend thus far. Mated the tranny to the motor. Had an episode of "I hate headers". Of course, the original bends of the tranny lines don't work with headers. So, I massaged them and I believe all is good. I have to get another 90 degree power steering fitting. I got the smaller 66-68 fitting. I do believe the 69 and later are larger. Got the mini-starter as well... Everything seems to be going forward albeit slowly. But, that's OK. So far the TTI headers bend rather well.
After these pictures where taken, I installed the starter cable and realized the safety/neutral switch was incorporated in it. So, the harness I had new was your typical V8 harness. Oh well, now I have a new one for my future project.
Troy
Houston Mopar Connection Club
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552089
06/03/14 11:42 PM
06/03/14 11:42 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Very nice Troy.
Sheldon
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552090
06/09/14 10:07 AM
06/09/14 10:07 AM
Houston, Tx
Houston, Tx
Well, yesteday I tackled the front control arms. Installed the new PST upper bushing and cleaned things up. Love that bushing removal/installation tool. Cosmoline application of the lowers and they are ready for reinstall. The lower control arms have the PST polygraphite bushings as well. I will wait till the motor is in so there is less things in the way. I want to make the installation of the drivetrain as simple and unobstructed as possible. Looks good if I say so out of the garage with a rattle can from RestoRick.
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552091
06/09/14 10:08 AM
06/09/14 10:08 AM
Houston, Tx
Houston, Tx
Cosmoline application ( from RestoRick )
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552092
06/09/14 10:08 AM
06/09/14 10:08 AM
Houston, Tx
Houston, Tx
All done..
Cosmoline is actually darker than what appears in the picture.
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552093
06/12/14 12:58 AM
06/12/14 12:58 AM
Houston, Tx
Houston, Tx
More control arm stuff......... factory markings..........
Orange = passenger side
Blue = driver's side..
Disclaimer: I am in no way stipulating that the colors shown are assembly line correct hues of the colors they are......
Now, research on the markings on the valve cover...... Jimbo?
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552094
06/13/14 09:33 AM
06/13/14 09:33 AM
Houston, Tx
Houston, Tx
Thanks to Jim's intel;
This is what I'm going with "22"; my final answer, for better or worse, till death do us part...... It is what it is......
I'm going back to the clutch 216 fan style initially. Yes, the fan's dusty and it's not a 070 clutch. ........ I'm losing it.....
I need to get the radio noise suppressor as well.......
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552095
06/13/14 10:38 AM
06/13/14 10:38 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
...And a green stamped coil
Re: Hemi Transplant in my '69 Daytona [Re: ScottSmith_Harms] #1552096
06/13/14 04:26 PM
06/13/14 04:26 PM
Houston, Tx
Houston, Tx
wellllllllllll, unless I can get one stenciled, this isn't the one that's actually going to be on it. Since I am going with a MSD-6A system, I have to have the MSD Blaster coil, which I bought in black.. Now, if it isn't overly expensive to do that, I'll add that little touch too !!!
Thanks for the feedback Scott......... Always looking to improve the overall OEM look within reason and to the extent of the components I'm using....
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552097
06/13/14 05:50 PM
06/13/14 05:50 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Troy just get the green stamp from ECS to put on the coil of your choice.
Ron
Re: Hemi Transplant in my '69 Daytona [Re: RJS] #1552098
06/13/14 07:48 PM
06/13/14 07:48 PM
Houston, Tx
Houston, Tx
Ron
Ahh..
OK, I forget the extent of what Dave has to offer.....
Thanks for the tidbit of info...
Troy
Re: Hemi Transplant in my '69 Daytona [Re: RJS] #1552099
06/13/14 10:31 PM
06/13/14 10:31 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, that or just paint it all black, those white stamped coils just scream "I shop at Year One"
Re: Hemi Transplant in my '69 Daytona [Re: ScottSmith_Harms] #1552100
06/14/14 12:08 AM
06/14/14 12:08 AM
Houston, Tx
Houston, Tx
Ah man !!! Now, that's cold !!! ( albeit, I have gotten a couple of things from them, like my harnesses from M&H ).....
Well, time for more "stuff". Test fitting the auxiliary transmission fluid cooler lines. These are standard equipment on Hemi-auto cars because of the higher stall speed converter used. I found the perfect place to route the one line, through the strength bend that runs along the latch tray. Not sure why Creative didn't put the line there, it fits with a slight bend forward. Guess it was easier hack the latch tray and route the line instead of forming the tube. I may form the tube some more so it approaches the latch tray at a perpendicular direction.
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552101
06/14/14 12:09 AM
06/14/14 12:09 AM
Houston, Tx
Houston, Tx
Side shot..
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552102
06/17/14 11:08 AM
06/17/14 11:08 AM
Houston, Tx
Houston, Tx
New brake system means new fluid. I went with this very high temp racing fluid. Under the hood of this Daytona, it can get warm....good stuff...
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552103
06/20/14 06:54 PM
06/20/14 06:54 PM
Houston, Tx
Houston, Tx
Well, today was the day I brought together the 426 Hemi and Daytona. With the help from Tuffy and Jacob, things went pretty smooth. So, finished is a major milestone in Operation Hemi-Transplant.
Lot more to do, but this is one less thing......
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552104
06/20/14 06:54 PM
06/20/14 06:54 PM
Houston, Tx
Houston, Tx
positioning.
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552105
06/20/14 06:55 PM
06/20/14 06:55 PM
Houston, Tx
Houston, Tx
Tuffy helping out.
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552106
06/20/14 06:56 PM
06/20/14 06:56 PM
Houston, Tx
Houston, Tx
more
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552107
06/20/14 06:57 PM
06/20/14 06:57 PM
Houston, Tx
Houston, Tx
tucked away......
Troy
