Page 1 of 3 1 2 3
wheelstands and 60' times #1551227
12/21/13 09:57 PM
12/21/13 09:57 PM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
Do wheelstands effect 60' times ? Better to set up high or low. My car's currently 60ing at 1.37 and the bars are set low with about 4 - 5" under the wheels.
thx chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: wheelstands and 60' times [Re: chryco] #1551228
12/21/13 10:10 PM
12/21/13 10:10 PM
gregsdart Offline
gregsdart  Offline
All you can do is try it out and see what happens. Go up about a foot and see what the slip says. My car responds best to about a two foot wheel stand. Pro Stocks, on the other hand, need less
Isn't the track a little slippery this time of year? I grew up in the Grand Forks area, never had good traction from December till April!
Re: wheelstands and 60' times [Re: chryco] #1551229
12/21/13 10:43 PM
12/21/13 10:43 PM
Regina Sask, Canada
V
Viper469 Offline
Viper469  Offline
V
Regina Sask, Canada
Mine 60's 1.28-30 When i set it up to do a bigger wheelie.If i tone it down it's around 1.35. So to those that say a big wheelie is wasted motion
Re: wheelstands and 60' times [Re: Viper469] #1551230
12/21/13 11:17 PM
12/21/13 11:17 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Re: wheelstands and 60' times [Re: ProSport] #1551231
12/21/13 11:37 PM
12/21/13 11:37 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
They do when the rear tires are tripping the beams... ...this one went out 120ft. Normally I'm 1.24 or so...it was a 1.33 60ft.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: wheelstands and 60' times [Re: Eric] #1551232
12/21/13 11:51 PM
12/21/13 11:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have to watch which tires trip the lights.. if its
all of a sudden slow its usually the rear tires
Re: wheelstands and 60' times [Re: MR_P_BODY] #1551233
12/21/13 11:55 PM
12/21/13 11:55 PM
Penna
70satelliteguy Offline
Penna
I know that others will disagree but with my car bigger wheelstands equal better 60 ft! Don't know exactly why but that is just my experience!!
Mike
Re: wheelstands and 60' times [Re: MR_P_BODY] #1551234
12/22/13 12:00 AM
12/22/13 12:00 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine is best at about 8"-12". More than that it starts to slow. However traction does not seem to be an issue with my car.
Doug
Re: wheelstands and 60' times [Re: dvw] #1551235
12/22/13 01:21 AM
12/22/13 01:21 AM
Cab_Burge Online work
Cab_Burge  Online Work
This car is lightweight, 2750 lbs. with me in it, it is nose heavy, over 55% on the nose and doesn't have a lot of power either 676 HP. It does 60 ft well, 1.27, with the chassis barely lifting the front tires Powerglide with 5.86 rear gears in this run I have to throttle stop it down to 10.00 and under 135 MPh t allow me to drive it legaly
Re: wheelstands and 60' times [Re: 70satelliteguy] #1551236
12/22/13 01:38 AM
12/22/13 01:38 AM
SoCal
Brian Hafliger Offline
SoCal
Mike
My car does this too!
Brian Hafliger
Re: wheelstands and 60' times [Re: Brian Hafliger] #1551237
12/22/13 03:18 AM
12/22/13 03:18 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Mike
I can tell you why, if your car is better in the 60' with the wheels up in the air you need the extra rotation to plant the tires and make it hook.
Re: wheelstands and 60' times [Re: Quicktree] #1551238
12/22/13 11:45 AM
12/22/13 11:45 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Bigger wheelstands like this one below, slow down mine around .3 in the 1/4. Best Et's and 60ft's come from touching down just before 60ft.
Re: wheelstands and 60' times [Re: chryco] #1551239
12/22/13 01:21 PM
12/22/13 01:21 PM
Sterling Heights, MI
John_T_Brown Offline
No, just set the wheelie bars (raise or lower)until the car is smooth in first gear you will have the quickest times when the car feels smooth and slow. It will not matter how high you go when everything is right.
If it ain't broke fix it anyway!
Re: wheelstands and 60' times [Re: chryco] #1551240
12/22/13 01:58 PM
12/22/13 01:58 PM
gregsdart Offline
gregsdart  Offline
I see it as a situation of how quick total weight transfer can occur. A slow stocker doesn't have the power to weight to transfer quick enough to not have to use artificial weight transfer, like rear suspension reaction , soft front springs and travel. The more powerful the car, and the sharper the setup, (CG, suspension, applied power at the hit)the quicker all the weight gets on the rear, and the lower the wheelstand needs to be. If you watch a video of Billy Gliddens Mustang, you will see a car that has a better setup than most of the class he runs in. The car flat leaves with the fronts just off the ground, where others are pulling wheelstands to achieve the same thing, but not getting down track as fast. I suspect he learned a lot from another Glidden.
Re: wheelstands and 60' times [Re: gregsdart] #1551241
12/22/13 06:45 PM
12/22/13 06:45 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
When you leave and the front tires go straight up does that effect your reaction time. Mine pulls them straight up at the hit and I have been having a problem red lighting. Thanks...
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: wheelstands and 60' times [Re: D-50] #1551242
12/22/13 06:47 PM
12/22/13 06:47 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
Yes it does I had the same problem that you have I was red lighting a lot.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: wheelstands and 60' times [Re: D-50] #1551243
12/22/13 07:42 PM
12/22/13 07:42 PM
gregsdart Offline
gregsdart  Offline
About .02 on my car.
Re: wheelstands and 60' times [Re: 440W8 Duster] #1551244
12/22/13 07:48 PM
12/22/13 07:48 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
big wheelstands slow me down but i put that down to shifting early, (wheels in the air, select another gear), a nice long wheelstand gets me into the high 1.2's, no wheelstand & we looking at mid 1.3's.
Re: wheelstands and 60' times [Re: chryco] #1551245
12/23/13 04:49 AM
12/23/13 04:49 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
The higher the wheels are in the air, the quicker my Demon goes.
Re: wheelstands and 60' times [Re: qwkmopardan] #1551246
12/23/13 12:11 PM
12/23/13 12:11 PM
Penna
Penna
"The higher the wheels are in the air, the quicker my Demon goes"
How many passes do you get out of a rear bumper Dan?
Mike
Page 1 of 3 1 2 3
