Re: HEMI Rods in a Stock Stroke 440
[Re: B G Racing]
#1551187
12/21/13 08:01 PM
12/21/13 08:01 PM
Posts: 515 geezer acres rest home
dakotawilly
don't forget the nascar hemi boat anchor rods,they would be good to about 3000 rpm in a 440 before the massive centrifical weight sent it into catastrophic supernova,but,probably take 3 days to rev that high.....
SFI 25.5 depends,no leak,even at 213 mph....
[Re: dakotawilly]
#1551188
12/21/13 08:05 PM
12/21/13 08:05 PM
Posts: 84 Colorado
funnycar65
Colorado
just checked my Eagles are 6.860
[Re: HYPER8oSoNic]
#1551192
12/22/13 04:54 AM
12/22/13 04:54 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Unless you are doing some sustained high RPM endurance/road race/circle track operation, I would pass on those heavy HEMI forgings. Overkill in a 6-6.5k RPM 440 motor. 440 spec MP rods, Scat, Eagle, Crower or even a good set of LY rods with ARP rod bolts would suffice. You want to have strength but have a lighter than factory bobweight spec on the rotating assembly.
He said he had Eagle H beams , they are not really a lot heavier than the 440 rod other than .100 in length and the smaller pin bore.
To use the hemi length rod , as already said , you'll need a shorter piston and the pin size is probably different , but you can work around that.
[Re: funnycar65]
#1551195
12/22/13 03:47 PM
12/22/13 03:47 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
thanks for the info guys.I'm building a cheap street 440 with left over parts I have been collecting.New in the box Eagle rods I got with a bunch of HEMI stuff I bought.New 30 over JE pistons and fresh crank I got for $200 from a guy that lost his job,same with a pair of ported 906 heads that have 2.14 1.88 Manley valves I got for $100,Free block,so I might have $800 in it when I am done
Don't forget the machine work and wearable parts like main and rod bearings,piston rings and gaskest, oil and so on expences On the rods, if they are different on the wrist pin sizes than you need for the pistons you may be able to have a good machine shop like BG racing remove the wrong size bushings and rebush them to the size you need Have fun, take your time and do it correct so it will live
