Removing Undercoating #155114
11/22/08 08:24 PM
11/22/08 08:24 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Anybody here ever use the Fein Multimaster tool with the ridgid scraper to remove undercoating?
Re: Removing Undercoating [Re: dart4forte] #155115
11/22/08 08:25 PM
11/22/08 08:25 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
putty knife and a torch,just keep torch moving....
Re: Removing Undercoating [Re: 340dart4spd ] #155116
11/22/08 08:52 PM
11/22/08 08:52 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
propane torch and putty knife....
Re: Removing Undercoating [Re: 340dart4spd ] #155117
11/22/08 08:56 PM
11/22/08 08:56 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Re: Removing Undercoating [Re: 68CoronetRT] #155118
11/22/08 09:09 PM
11/22/08 09:09 PM
Lees Summit, MO
BrianT Offline
BrianT  Offline
Lees Summit, MO
A buddy of mine used one of these when he stripped his Chevelle. It's a little pricey, but worked like a charm. He says it was worth every penny. Best part is, when I'm ready I can borrow it as long as I buy a new head for it.
high $ Snap On tool
I just looked at the sanding tool you were talking about and these are priced about the same. Your sander could obviously be used for other things, the Snap On tool is a uni-tasker.
1970 Duster 340 clone
Re: Removing Undercoating [Re: BrianT] #155119
11/22/08 10:32 PM
11/22/08 10:32 PM
New Hampshire
W
whitemtnelf Offline
whitemtnelf  Offline
W
New Hampshire
Wire brush and Xylene - melts it away. Need lots of ventilation
Re: Removing Undercoating [Re: whitemtnelf] #155120
11/22/08 10:35 PM
11/22/08 10:35 PM
paint remover works the best
Re: Removing Undercoating #155121
11/22/08 10:53 PM
11/22/08 10:53 PM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
$5.99 cans of paint stripper and double sided razor blades and 1 1/2 scrapper with one side slightly grounded down works good. Do sections at a time. Hell with the torch and keeping it moving scheme........I can see potential drama in that.
Re: Removing Undercoating [Re: dart4forte] #155122
11/22/08 11:26 PM
11/22/08 11:26 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
I used a needle scaler on lots of areas.
It worked great.
Re: Removing Undercoating [Re: boydsdodge] #155123
11/23/08 11:25 AM
11/23/08 11:25 AM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Leave it on. If its that hard to get off its doing a good job of protecting whats under it. Whatever you put back on may not be as good.
Re: Removing Undercoating [Re: boydsdodge] #155124
11/23/08 08:08 PM
11/23/08 08:08 PM
Mesa, Arizona
Mesa, Arizona
It worked great.
Okay, I give up, what is a needle scaler? In answer to leaving it on I'm running fenderwells so the area where the coating is will get hot. I'm leaving the coating in the upper fender well alone.
Re: Removing Undercoating [Re: dart4forte] #155125
11/23/08 08:17 PM
11/23/08 08:17 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
It worked great.
http://www.novatekco.com/html/needle_scalers.html
Re: Removing Undercoating [Re: 340dart4spd ] #155126
11/23/08 08:21 PM
11/23/08 08:21 PM
Mesa, Arizona
Mesa, Arizona
Thanks, bet that tool costs a bundle
Re: Removing Undercoating [Re: dart4forte] #155127
11/23/08 08:30 PM
11/23/08 08:30 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
It would not be my choice... I still prefer using a torch to soften undercoat .and a wide scraper to remove it...
Re: Removing Undercoating [Re: dart4forte] #155128
11/23/08 08:30 PM
11/23/08 08:30 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Use proper PP. Personal protection. My welder ended up in the emergency room with an awful rash when grinding the undercoating off on a hot day. Baaaad rash. The subframe connectors are great though...
Re: Removing Undercoating [Re: dart4forte] #155129
11/23/08 11:30 PM
11/23/08 11:30 PM
boydsdodge Offline
boydsdodge  Offline
You can get needle scalers at harbour freight or Princess Auto up here in Canada,They are cheap and did a great job on my car.
After the scaler I had very little to clean.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=1108
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=1109
This is what I used, it attached to my air chisle.
Re: Removing Undercoating [Re: 340dart4spd ] #155130
11/24/08 12:14 AM
11/24/08 12:14 AM
None
71rm23 Offline
71rm23  Offline
None
I'm using a heat gun but a wide scraper as well. Mine seems to come off pretty easy, so far. While I'm on this subject and not to deviate from the OP but here's a question related to this:
What to put/do to the metal after removing the undercoating? I would think you need to do something soon to prevent anything happening to the metal. In my case, it could be a while to take it to a body shop(if that's the process)
Re: Removing Undercoating [Re: dart4forte] #155131
11/24/08 09:10 AM
11/24/08 09:10 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
If anyone is close to me, and your car is on a rotissierie. I will remove everything off the bottem of your car except for the paint in about 4 hours.You could bring the car to me or I could come to you.No scrape marks or gouges and no open flame used. PM me for the cost and availability.
Normally the metal would be media blasted and then immediately primed and painted.
Re: Removing Undercoating [Re: Challenger 1] #155132
11/24/08 10:15 AM
11/24/08 10:15 AM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
I used a needle scaler also but I can see where it might not work with other cars. I had the black undercoating on the car(barracuda) that was hardened and it came off fine with a needle scaler. But, the 69 Superbee has the snot colored stuff on it that seems more gooey. If anyone chooses to use the needle scaler, spend the money and get the Ingersol Rand unit from Northern Tools. I used the one from Harbor freight and it lasted all of about 5 hours and the local store told me to pound sand on an exchange, it was a factory warranty. The two units look identical but the IR unit has lasted.
By the way, if anyone is near Challenger1, take him up on his offer for removal and media blasting. Both jobs are time consuming and well worth the money spent to have others do it better and faster.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: Removing Undercoating [Re: Challenger 1] #155133
11/24/08 12:48 PM
11/24/08 12:48 PM
None
71rm23 Offline
71rm23  Offline
None
I just might do that Challenger 1. I've seen what you have done to your car(s) and I'm impressed. It would be worth it to me to bring it to you or come up with other arrangements
