Time to build a pump gas motor...543" ... Indy's... #1550774
12/21/13 12:40 AM
12/21/13 12:40 AM
Chowchilla,ca
Chassisman Offline OP
Chowchilla,ca
Been a while since I've asked a question or needed input on here.
I have a set of -1's... a 1971 block that will go 55 over (already 30 over).A 1050 Dom ...Indy intake with 2" 4150/4500 adapter.....
Mainly looking for cam input ...and any tricks to make it more durable.
Ready to get started soon...THANKS !!!
Re: Time to build a pump gas motor...543" ... Indy's... [Re: Chassisman] #1550775
12/21/13 01:10 AM
12/21/13 01:10 AM
gregsdart Offline
gregsdart  Offline
440-1 heads are going to push a stock block pretty hard. I preach using a center weighted crank after seeing the results in my mega block, and in your case, It would help block life a lot. Go as light as you can on piston and rod weight, 7.10 rods with 2.20 rod journals, or smaller if the crank is a real stout piece. I have run 2.1 rods, was told by Crower they would be strong enough with their crank for my app. See if piston and ring makers think using .043 rings top and second with standard oil rings will work. The .043 setup is worth a lot of friction reduction, and makes great power if oil control is good. I run a vacuum pump and alky with mine, so I am not sure about a pump gas deal. The cam is pretty much up to what you want for torque range. David Vizzards book "HOW TO BUILD HORSEPOWER" has a great section on cam selection, and points to a farely narrow LSA for your app, (108 or less, depending on a lot of things) based on valve size and cubes. The book is a good read. Porting those heads is going to be worth a lot. How high are you willing to rev this motor, and the lowest point you are willing to get decent torque?
Re: Time to build a pump gas motor...543" ... Indy's... [Re: Chassisman] #1550776
12/21/13 01:22 AM
12/21/13 01:22 AM
SoCal
Brian Hafliger Offline
SoCal
Pump gas? Roller or FT cam? Desired HP level?
Brian Hafliger
Re: Time to build a pump gas motor...543" ... Indy's... [Re: gregsdart] #1550777
12/21/13 01:45 AM
12/21/13 01:45 AM
Chowchilla,ca
Chowchilla,ca
4000 is where I'd like the TQ to come in... take it to 6200-6500 RPM... I'm gonna get the -1's CNC ported ..2.19 vales..looking around 2200 on the bob weight.. I'm not chasing low numbers... 9.50's would be great... but 10.40's would work too... I just want a low maint ....fun car to run. Plus my boy is now 15 so he'll be in it soon if we don't build his altered/FC soon...
Re: Time to build a pump gas motor...543" ... Indy's... [Re: Brian Hafliger] #1550778
12/21/13 01:48 AM
12/21/13 01:48 AM
Chowchilla,ca
Chowchilla,ca
....glad you chimed in... My boys GF lives in Temecula... we've been running at Barona with his junior... I'm gonna need your input and most likely some machine work... but a buddy keeps trying to get to take it to Rettig Bros....I'm not sold on them though.
Lets say FT to keep the cost down....and yes...pump gas...650 ish on the HP
Re: Time to build a pump gas motor...543" ... Indy's... [Re: Chassisman] #1550779
12/21/13 02:03 AM
12/21/13 02:03 AM
SoCal
SoCal
10.7:1, Hand ported -1's, stock main caps at that level or Aluminum incase of future upgrades.
Cam around 270@ .050 and as much rocker ratio as you can throw at it.
Should make 650 or more pretty easily...prolly more like 680's.
Brian Hafliger
Re: Time to build a pump gas motor...543" ... Indy's... [Re: Chassisman] #1550780
12/21/13 02:14 AM
12/21/13 02:14 AM
Cab_Burge Online work
Cab_Burge  Online Work
Your going to have to really struggle to keep that rascal under 650 HP on pump gas My old low deck stroker with a set of Eddy RPM non M.W. ports and a single, Team G 4500 flange intake with a Holley 9375 non HP 1050 made over 650 HP up here at 2500 Ft + elevation That was in the winter though with a high pressure front going through at or under 35 F during those tests, it was on Studka brand engine dyno that was supposedily calibrated at the time of the tests The same short block with a set of Indy SR M.W. port sizes and the same carb. on a 400-3 intake made over 720 Hp on another engine dyno, DTS brand in the early summer up here in Klamath Falls ,OR which is above 4300 FT That was on Oregon non Ethanol 91 octane pump swill The cam in that motor was a Comp Cams solid roller with 260 @.050 on the intakes with .420 lobe lift and 266@ .050 on the exhaust side with .409 lobe lift, I did use a set of Harland Sharp 1.6 rockers That motor(518 C.I., 4.375 bore with 4.300 stroke) made peak HP at or close to 6500 RPM with the SR heads I loved that motor, no matter which heads, intake or carbs. that where on it it ran good and held up very well It would run low tens and high nines through the exhaust sytem with me in it with the car weighing 3450lb + I shifted it at or slightly above 7100 RPM, that is where it seem to be happy at no matter which intake or heads
Re: Time to build a pump gas motor...543" ... Indy's... [Re: Chassisman] #1550781
12/21/13 04:44 AM
12/21/13 04:44 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Rettigs?? NOOOOOOO! UNLESS Wann is doing the work himself. Want a really good central valley shop? Valley Balancing in Ceres.
Re: Time to build a pump gas motor...543" ... Indy's... [Re: cudadoug] #1550782
12/21/13 05:03 AM
12/21/13 05:03 AM
Chowchilla,ca
Chowchilla,ca
Ken Boyd has done a few motors for me...Larry Gilley assembled my last one...ran great til I messed it up.
Re: Time to build a pump gas motor...543" ... Indy's... [Re: Chassisman] #1550783
12/21/13 10:58 AM
12/21/13 10:58 AM
gregsdart Offline
gregsdart  Offline
If your goals are moderate, (600 hp,6,000 max rpm) you can skip the porting other than bowl work, run a cam with moderate duration (270 @ .050 or less) shift it at 5600 to 5800 and run high nines all day long if the weight is down to 3,000 or less. A 543 cube motor with a big hydraulic cam would work great here, very low maintenance. I had a 475 cube rb with this basic combo, 6,000 rpm shifts, ran 10.10 at 3180.
