midplate thoughts #1550197
12/19/13 03:39 PM
12/19/13 03:39 PM
illinois usa
K
king coronet Offline OP
K
illinois usa
Hi everyone. Just started a tube frame chassis and looking for opinions on mounting a midplate. I was thinking about using a full plate, like an altered and supporting it off of the dash bar and lower frame rails with uprights between the rails and dash bar,using the midplate as part of the firewall. Can it be bolted in,planing on a steel midplate 25.4 cert? Any pictures ? Thanks Al MERRY CHRISTMAS HAPPY NEW YEAR
Re: midplate thoughts [Re: king coronet] #1550198
12/19/13 04:40 PM
12/19/13 04:40 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Bump/Would like some input as well...planning my chassis build and undecided on best way to do the midplate.
Re: midplate thoughts [Re: king coronet] #1550199
12/19/13 05:04 PM
12/19/13 05:04 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
This is the way a car SHOULD be built. The midplate area is an integral structural part of the car to make one stiff. As for mounting, I usually frame my opening from tubing as you describe and then weld straps of narrow plate inside the opening. The 1/4" alum midplate then bolts to those straps all around the opening with 1/4-20 bolts and the plate sits flush with the outside edge of the tubing. Basically the midplate becomes a "bolt in" firewall for that section of chassis.
Monte
Re: midplate thoughts [Re: Monte_Smith] #1550200
12/19/13 05:19 PM
12/19/13 05:19 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
Midplate is good. Mine attaches at 10 points.
2011 Drag Pak Challenger
Re: midplate thoughts [Re: rickseeman] #1550201
12/19/13 09:51 PM
12/19/13 09:51 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
If I were redoing my car that is exactly what I would do.
Leon
Re: midplate thoughts [Re: Leon441] #1550202
12/20/13 01:47 AM
12/20/13 01:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
My mid plate attaches at 6 points but its just a single
rail car.. actually both my cars are the same single
rails with 6 points but I also dont use the mid plate
as part of the fire wall... the tunnel comes up to
the verticals and thats where the fire wall starts..
I have small cars so I keep the tunnel pretty tight
to the trans for room inside
