Hayden Trans Coolers & Which line is pressure & return #1549842
12/18/13 04:11 PM
12/18/13 04:11 PM
Maryville tn
67coronetman Offline OP
Maryville tn
Ok I am Installing ( 2 ) trans coolers on my street/strip car both are Hayden trans coolers the larger one is 10 x 16 x 3/4 with a 9" electric fan mounted on it this one will be the bottom cooler in front of the Radiator the second one is 5 x 12 x 3/4 and it will sit on top off the bottom one. What I am asking is...
1. Which line is the pressure line coming off the trans I believe its the front one and the back one is the return if I am wrong please tell me.
2. Second should I run the pressure line in the bottom cooler first with the fan or run it to the very top cooler and let it run down and finish in the larger cooler with the fan then back to the transmission..
Thanks for any help.
Old car are me......
Re: Hayden Trans Coolers & Which line is pressure & return [Re: 67coronetman] #1549843
12/18/13 04:45 PM
12/18/13 04:45 PM
okla.
sam64 Offline
sam64  Offline
okla.
yes front is pressure,why not just use one big cooler with the fan?stacking them is not good,the heat from one will just slow the cooling of the other if stacked.
Re: Hayden Trans Coolers & Which line is pressure & return [Re: 67coronetman] #1549844
12/18/13 06:36 PM
12/18/13 06:36 PM
Generally you run the hot fluid to the top so it gets cooled as it goes downward just like the radiator coolant does but it ain't a dealbreaker & especially with 2 coolers there will be some additional routing as you know to connect em up & in your case go with whichever way lets everything connect together the easiest/neatest. On a side note do check that you are getting adequate radiator airflow for adequate cooling at slower speeds in stop & go driving
Re: Hayden Trans Coolers & Which line is pressure & return [Re: sam64] #1549845
12/18/13 11:57 PM
12/18/13 11:57 PM
Maryville tn
Maryville tn
Thanks for the advise i was thinking that two would cool even better but i understand what you are saying so i would be just as good with the bigger one with the fan... I do have a cooler that is about 1 1/2 think maybe a little bit more with very large tubes maybe i should you that one instead i just want the best cooling i can get for my trans to last longer & work better is all..:)
Re: Hayden Trans Coolers & Which line is pressure & return [Re: RapidRobert] #1549846
12/18/13 11:59 PM
12/18/13 11:59 PM
Maryville tn
Maryville tn
That is what i was thinking but i always ask for help or advise cause someone may have done the same in the passed and it worked good or maybe not so thanks for all the help & advise..
Re: Hayden Trans Coolers & Which line is pressure & return [Re: sam64] #1549847
12/19/13 12:01 AM
12/19/13 12:01 AM
Maryville tn
Maryville tn
By the way i like your car in the picture nice car.
Re: Hayden Trans Coolers & Which line is pressure & return [Re: RapidRobert] #1549848
12/23/13 10:58 PM
12/23/13 10:58 PM
Maryville tn
Maryville tn
I got great air flow so far and trans cooling if doing good.
Re: Hayden Trans Coolers & Which line is pressure & return [Re: 67coronetman] #1549849
12/23/13 11:06 PM
12/23/13 11:06 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
BE careful .... tooo many coolers could spoil the stall-speed of the converter
Re: Hayden Trans Coolers & Which line is pressure & return [Re: BeEtLeJuIcE !] #1549850
12/23/13 11:12 PM
12/23/13 11:12 PM
Maryville tn
Maryville tn
Yea i just used one big trans cooler with the fan.
