Tire Size for 1970 Roadrunner #1549421
12/17/13 05:38 PM
12/17/13 05:38 PM
Illinois
bltcuda1972 Offline OP
Illinois
I am planning buying new tire for my Christmas, I got rim 15x7 (front) and 15x10 (rear) for 1970 Roadrunner. So I need to know what size of tire that will fit and without rubbing the edge. I use 8 3/4 rear 3rd member and no cut.
Re: Tire Size for 1970 Roadrunner [Re: bltcuda1972] #1549422
12/17/13 10:18 PM
12/17/13 10:18 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I can't swear to you exactly what will fit using a 15 x 10. I used a 17 x 9.5 on the rear of mine with a 275-60-17 tire. Backspacing is crucial to making it fit. I have a 68 Charger 8 3/4 rear in mine (typical 68-70 B body)with 5 1/2" backspacing. I ended up using a set of 1/4" wheel spacers to move the tire away from the spring a little. Depending on how wide of a tire you want to get 5" backspace should work. The section width on mine is about 11 1/2" and I do have a little (very little) more room to the outside. I would guess a 275-60-15 should fit fine. Mine are 30" tall so I also had to move the entire rear back 3/4" to keep from rubbing the 1/4 panel at the front.
...FAFO...
Re: Tire Size for 1970 Roadrunner [Re: skicker] #1549423
12/18/13 12:50 PM
12/18/13 12:50 PM
Illinois
Illinois
Thanks for help
Re: Tire Size for 1970 Roadrunner [Re: bltcuda1972] #1549424
12/18/13 03:35 PM
12/18/13 03:35 PM
MAIne
MoparABE Offline
MoparABE  Offline
MAIne
I lIke 235/70r15 front and 25570r15 rear. gives a mean stance.
Re: Tire Size for 1970 Roadrunner [Re: MoparABE] #1549425
12/19/13 01:00 PM
12/19/13 01:00 PM
Illinois
Illinois
ok thanks I will compare with those size tires
