Re: How do YOU adjust hydraulic lifters with adj rockers? [Re: mopar346] #1548084
12/19/13 11:28 AM
12/19/13 11:28 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I tried to check for clearance bu the valve spring is much weaker than the lifer spring so no go,
Re: How do YOU adjust hydraulic lifters with adj rockers? [Re: GomangoCuda] #1548085
12/19/13 01:01 PM
12/19/13 01:01 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
I don't follow you, are you suggesting some sort of caution. Valve springs have 300+ seat pressure un pumped lifters have 3 lbs not a surprise they collapse before any opening can occur.
Careful, your character's showing!
Re: How do YOU adjust hydraulic lifters with adj rockers? [Re: mopar346] #1548086
12/19/13 01:18 PM
12/19/13 01:18 PM
GomangoCuda Offline
GomangoCuda  Offline
Re: How do YOU adjust hydraulic lifters with adj rockers? [Re: GomangoCuda] #1548087
12/19/13 02:05 PM
12/19/13 02:05 PM
mopar346 Offline OP
mopar346  Offline OP
Ahh...........go catch AND yes that would be a problem if the valve springs were weaker than the lifter spring.
Re: How do YOU adjust hydraulic lifters with adj rockers? [Re: Cab_Burge] #1548088
12/19/13 02:49 PM
12/19/13 02:49 PM
New York
rarefish Offline
rarefish  Offline
New York
On my T/A motor, I ended up shimming the rocker shafts up about 0.025" to gain some push rod to rocker arm clearance. It was a lot cheaper than buying a set of custom length push rods.
Why wouldn't you use the adjusters on the rocker arms and turn them 1/4 to 1/3 turn out to get the clearances needed
Push rods become to long due to head and deck machining. As most people here have said that your adjustment should be 1/2 to 3/4 turns in from zero lash. So if zero lash starts with the adjuster ball hardly protruding from the rocker arm because of the push rod length. You will most likely find that you will have a push rod cup to rocker arm clearance problem when the valve opens.
Shimming the rocker arm shafts at the pedestals will allow the rocker arm adjuster ball to protrude more at zero lash. Then you add the 1/2 to 3/4 turns in of adjustment. Hopefully will have gained the clearance you need when the valve opens.
