valve spring removal with head on #1547877
12/15/13 05:27 PM
12/15/13 05:27 PM
Wichita,ks.
jst19600 Offline OP
jst19600  Offline OP
Wichita,ks.
Im trying to remove the valve springs with heads on engine.I purchased a valve spring removal tool that bolts to the rocker shaft stands.Ive hooked up my air compressor to the spark plug hole and have aired it up to 120 psi but the valve still goes down and it wont break free from the retainer.Need suggestions on what i should try,do not want to pull heads off.
Re: valve spring removal with head on [Re: jst19600] #1547878
12/15/13 05:34 PM
12/15/13 05:34 PM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
Tap retainer w/ rubber mallet and try again.
Also, I prefer the rope method and TDC but that's just me. If you lose air pressure for any reason, you are pulling the head.
Re: valve spring removal with head on [Re: Tempest] #1547879
12/15/13 05:37 PM
12/15/13 05:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I like to use a shot-filled hammer on a deep-well socket placed on the retainer instead of hitting the retainer directly.
Re: valve spring removal with head on [Re: John_Kunkel] #1547880
12/15/13 05:42 PM
12/15/13 05:42 PM
Wichita,ks.
jst19600 Offline OP
jst19600  Offline OP
Wichita,ks.
Do i have enough air pressure?Whats the minimum i can safely have without dropping the valve?I do have the cylinder at TDC.
Re: valve spring removal with head on [Re: jst19600] #1547881
12/15/13 05:49 PM
12/15/13 05:49 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Plenty enough pressure. The piston won't be at TDC it will be all the way down. The air pressure pushes it down when it pressurizes the cylinder. Tapping the retainer lightly will release any varnish holding it in place.
Re: valve spring removal with head on [Re: stumpy] #1547882
12/15/13 07:19 PM
12/15/13 07:19 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
The pressure doesn't necessarily push the piston down. If you leave a spark plug or so in the heads it will hold.
Re: valve spring removal with head on [Re: stumpy] #1547883
12/15/13 07:26 PM
12/15/13 07:26 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I don’t use rope or air. I bring #1 to TDC and use the 180º method, which brings 2 pistons to TDC simultaneously. I’ll smack the retainers with a socket, then do 4 valves at a time. Turn the crank 180º and repeat on the next pair of cylinders.
Re: valve spring removal with head on [Re: 64Post] #1547884
12/15/13 07:55 PM
12/15/13 07:55 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
never changed a spring myself but this method seems to be the easiest? what are the 'pitfalls' to this method?
Re: valve spring removal with head on [Re: mikemee1331] #1547885
12/15/13 08:05 PM
12/15/13 08:05 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If the pistons are down it the hole and not a zero deck the valve will drop.I almost always use air even when I did them at the shop.Ive used the rope a few times.Last time we did them on the kids 413 it took about an hour to do all 8 cylinders.Rocky
Chrysler Firepower
Re: valve spring removal with head on [Re: therocks] #1547886
12/15/13 08:16 PM
12/15/13 08:16 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
that makes sense but who wouldn't check to make sure the piston was at TDC. it just seems so simple? perhaps i've missed something here...
Re: valve spring removal with head on [Re: mikemee1331] #1547887
12/15/13 08:28 PM
12/15/13 08:28 PM
Grand Prairie,Texas
Grand Prairie,Texas
Down in the hole means the piston isn't at the top edge of cylinder which all not all pistons are at TDC. A zero deck piston is at the top of the cylinder at TDC but most stock pistons are not zero deck. They are below the top by a good bit in some low compression motors.
Re: valve spring removal with head on [Re: stumpy] #1547888
12/15/13 08:31 PM
12/15/13 08:31 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
thank you Stumpy! now it clicks!
Re: valve spring removal with head on [Re: mikemee1331] #1547889
12/15/13 08:37 PM
12/15/13 08:37 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
that makes sense but who wouldn't check to make sure the piston was at TDC. it just seems so simple? perhaps i’ve missed something here...
Valve drop: Due to various piston top designs, it’s wise to do the first valve and note the valve drop. If the valve drops so much that you need a second person to hold the valve up with a pencil magnet while you compress the spring and install the locks then maybe you might want to use hose to hold the valve up.
Re: valve spring removal with head on [Re: 64Post] #1547890
12/15/13 09:14 PM
12/15/13 09:14 PM
Wichita,ks.
jst19600 Offline OP
jst19600  Offline OP
Wichita,ks.
Thanks for the help,got them all changed.I brought each cylinder up to its TDC and used a breakover bar on my rachet to stop the crank bolt from turning.
Re: valve spring removal with head on [Re: jst19600] #1547891
12/15/13 09:52 PM
12/15/13 09:52 PM
You did it the smart way with the pistons at TDC, once the rocker arms and shaft assemblys are removed it doesn't matter if the cam or distributors match the piston location, as long as the piston is at TDC when you work on that set of valves the valve can not drop all the way into the cylinders when Murpphy strikes John Kunkels method works well on seperating the keepers from the retainers
Re: valve spring removal with head on [Re: Cab_Burge] #1547892
12/15/13 10:24 PM
12/15/13 10:24 PM
Wichita,ks.
jst19600 Offline OP
jst19600  Offline OP
Wichita,ks.
Yes,whapped them a few times with a socket and mallet and they came free.Now these new valves springs better better correct my performance issue i had this year.
Re: valve spring removal with head on [Re: jst19600] #1547893
12/16/13 12:39 AM
12/16/13 12:39 AM
You already took care of it but as said I just put a socket on the retainer & give the socket a good rap with a medium hammer so the retainer/locks/valve ain't frozen to each other then compress the retainer/spring like you were originally doing. If they're still stuck put the socket up there again & hit it harder. A pencil or telescoping magnet works good for retrieving the keepers
