Re: valve spring removal with head on
[Re: Tempest]
#1547879
12/15/13 05:37 PM
12/15/13 05:37 PM
Posts: 25,933 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I like to use a shot-filled hammer on a deep-well socket placed on the retainer instead of hitting the retainer directly.
[Re: stumpy]
#1547882
12/15/13 07:19 PM
12/15/13 07:19 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Plenty enough pressure. The piston won't be at TDC it will be all the way down. The air pressure pushes it down when it pressurizes the cylinder. Tapping the retainer lightly will release any varnish holding it in place.
The pressure doesn't necessarily push the piston down. If you leave a spark plug or so in the heads it will hold.
[Re: 64Post]
#1547884
12/15/13 07:55 PM
12/15/13 07:55 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
I don’t use rope or air. I bring #1 to TDC and use the 180º method, which brings 2 pistons to TDC simultaneously. I’ll smack the retainers with a socket, then do 4 valves at a time. Turn the crank 180º and repeat on the next pair of cylinders.
never changed a spring myself but this method seems to be the easiest? what are the 'pitfalls' to this method?
[Re: mikemee1331]
#1547885
12/15/13 08:05 PM
12/15/13 08:05 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
If the pistons are down it the hole and not a zero deck the valve will drop.I almost always use air even when I did them at the shop.Ive used the rope a few times.Last time we did them on the kids 413 it took about an hour to do all 8 cylinders.Rocky
Chrysler Firepower
[Re: therocks]
#1547886
12/15/13 08:16 PM
12/15/13 08:16 PM
mikemee1331
bethlehem pa
that makes sense but who wouldn't check to make sure the piston was at TDC. it just seems so simple? perhaps i've missed something here...
[Re: stumpy]
#1547888
12/15/13 08:31 PM
12/15/13 08:31 PM
mikemee1331
bethlehem pa
Down in the hole means the piston isn't at the top edge of cylinder which all not all pistons are at TDC. A zero deck piston is at the top of the cylinder at TDC but most stock pistons are not zero deck. They are below the top by a good bit in some low compression motors.
thank you Stumpy! now it clicks!
[Re: mikemee1331]
#1547889
12/15/13 08:37 PM
12/15/13 08:37 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
that makes sense but who wouldn't check to make sure the piston was at TDC. it just seems so simple? perhaps i’ve missed something here...
Valve drop: Due to various piston top designs, it’s wise to do the first valve and note the valve drop. If the valve drops so much that you need a second person to hold the valve up with a pencil magnet while you compress the spring and install the locks then maybe you might want to use hose to hold the valve up.
[Re: jst19600]
#1547893
12/16/13 12:39 AM
12/16/13 12:39 AM
RapidRobert
You already took care of it but as said I just put a socket on the retainer & give the socket a good rap with a medium hammer so the retainer/locks/valve ain't frozen to each other then compress the retainer/spring like you were originally doing. If they're still stuck put the socket up there again & hit it harder. A pencil or telescoping magnet works good for retrieving the keepers
