Race gas performance on pump gas? #1547333
12/14/13 03:29 AM
12/14/13 03:29 AM
Orleans, Ontario
moparcanuk Offline OP
Orleans, Ontario
There is an article in Chrysler Power that talks about Snow Performance's water/methanol injection system for Six Packs. Just wondering if anyone knows anything about it.
http://www.snowperformance.net/produ...le-pdf-130.pdf
Re: Race gas performance on pump gas? [Re: moparcanuk] #1547334
12/14/13 05:18 AM
12/14/13 05:18 AM
WTF is going on with the sight now I had MR Yuck runs a sixpak with the Snow water/meth injection kit on this post when I posted it last night
Re: Race gas performance on pump gas? [Re: moparcanuk] #1547335
12/14/13 10:20 AM
12/14/13 10:20 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yuck will be along to tell you how great it is.
It won't allow you to run pump gas in place of race if that's what your motor is built for.
Re: Race gas performance on pump gas? [Re: moparcanuk] #1547336
12/14/13 01:19 PM
12/14/13 01:19 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
In this day and age of varying gas qualities, inconsistent ethanol content and regulatory changes, water injection may well at least protect our engines if not add a significant level of performance.
I am seriously considering making it a part of my next build. I run 11:1 on pump gas and things are good.......most of the time. But the engine is on the edge and occasionally I need to back the timing off because of gas even though I gas up at the same place. (93 octane supposedly)
It appears that meth/water injection can produce real performance improvements in certain combos. The water injection just may be a cushion that allows for a tighter tune without being on the ragged edge of destruction. That alone would be worth the price of admission.
Master, again and still
Re: Race gas performance on pump gas? [Re: moparcanuk] #1547337
12/15/13 12:41 PM
12/15/13 12:41 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
This sounds like "snake oil" to me, but I've been wrong before.
http://www.watertogas.com/water-gas-injector.html
This is the land of the free because of the brave
Re: Race gas performance on pump gas? [Re: rbstroker] #1547338
12/15/13 01:23 PM
12/15/13 01:23 PM
, it defies logic that drawing a non fuel substance (water vapor) into an eng would give you better mileage & from the looks of it I wouldn't think it'd even draw much vapor at all & even if water vapor did help you'd have to heat the water somehow to get it to turn to vapor
Re: Race gas performance on pump gas? [Re: rbstroker] #1547339
12/15/13 01:24 PM
12/15/13 01:24 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
there have been several cars on my friends dyno that had water/methanol injection. it has wasted his heated oxygen sensor on the dyno several times.
it can help if you motor is built for it and you know what how to use it properly.
basically with W/M injection it cools the intake charge allowing you to run more timing and compression for additional power.
it can also be used in boosted applications for more power. it really helps boosted cars without intercoolers.
perception is 90% of reality
Re: Race gas performance on pump gas? [Re: rbstroker] #1547340
12/15/13 01:33 PM
12/15/13 01:33 PM
Mr T2U Offline
Mr T2U  Offline
it's not snake oil. it's basic science.
when you lean your engine out it make combustion temps go higher and you get pinging. add water injection to your lean mixture and now your temps are cooler now no more pinging.
leaner mixtures equal better gas mileage.
you must be careful with it. if you don't have the correct mixtures it can cause problems fast.
Re: Race gas performance on pump gas? [Re: RapidRobert] #1547341
12/15/13 03:45 PM
12/15/13 03:45 PM
jersey
Spaceman Spiff Offline
jersey
http://www.legendarycollectorcars.com/fe...xclusive-video/
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Race gas performance on pump gas? [Re: moparcanuk] #1547342
12/15/13 04:47 PM
12/15/13 04:47 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
'Race gas performance on pump gas'...
The eternal chase...
At the end of the day, I think I'll make my life easier...
Like I have for a lot of years...
Throw in a little CAM 2...And be good to go...
I have no desire for incessant cam changes, head changes, compression jockeying, timing issues, carb issues, temp variations, pre-ignition, detonation, octane issues...
And on and on and on...
Re: Race gas performance on pump gas? [Re: moparcanuk] #1547343
12/15/13 05:39 PM
12/15/13 05:39 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Deja vu..., Sort of reminds me of the Edelbrock water injecton system from the 70's/80's.
Re: Race gas performance on pump gas? [Re: moparfan53] #1547344
12/15/13 08:15 PM
12/15/13 08:15 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
How often on average do you need to refill the water?
I want my fair share
Re: Race gas performance on pump gas? [Re: SomeCarGuy] #1547345
12/15/13 08:35 PM
12/15/13 08:35 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
I still have about TEN Spearco water injection kits bought from Buckeye Sales(any of you know who that was?) ....
Me thimks Eddy just rElabeled that Spearco kit with their own box ...
Re: Race gas performance on pump gas? [Re: SomeCarGuy] #1547346
12/15/13 08:36 PM
12/15/13 08:36 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Nothing really new. How about some 'Turbo-Rocket Fluid'?
http://auto.howstuffworks.com/1962-1963-oldsmobile-f85-jetfire2.htm
Re: Race gas performance on pump gas? [Re: 6PakBee] #1547347
12/15/13 09:51 PM
12/15/13 09:51 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i think the germans did it on their fighter aircraft in ww2. they also used NO2. is it practical? maybe, maybe not. it's been around for decades but seems to be more of a "niche" item.
Re: Race gas performance on pump gas? [Re: lewtot184] #1547348
12/15/13 10:01 PM
12/15/13 10:01 PM
OP, if you decide to use the Snow kit I would use it with straight Methanol only, no water I have used methanol with race gas years ago in a bracket car before the Snow system was available To directly answer your question on how to step up performance on amotor to make it runs a sgood as a race motor on race gas there is really no way to do that, if you make a big C.I. stroker motor designed for pump gas you can, and I have, make a hoop of power My 512 C.I. 400 block with a set of mildy ported 906 heads with 9.25 to 1 comp. ratio made 612 HP at 4500 RPM and 644 Ft. lbs. at 4500 RPM on CA pump swill back in 2004 Once I added a set of ported Eddy RPM, Harland Sharp 1.6 rockers and up the compresion ratio(10.29 to 1) to use the aluminum heads on pump gas it made more power and torque Lots of ways to skin the kitty
Re: Race gas performance on pump gas? [Re: DaveRS23] #1547349
12/16/13 01:01 AM
12/16/13 01:01 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I am seriously considering making it a part of my next build. I run 11:1 on pump gas and things are good.......most of the time. But the engine is on the edge and occasionally I need to back the timing off.
I had a few people suggest this product when I was dealing with detonation in my Charger. I have no room to use a spacer plate type system though since my air cleaner is 1/4" from the hood. Running 11.0 or higher compression ratios mean that you can't ever let your guard down.
I decided that being on that ragged edge of detonation for a few extra HP isn't worth it to me.
