Re: Race gas performance on pump gas?
[Re: moparcanuk]
#1547334
12/14/13 05:18 AM
12/14/13 05:18 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
WTF is going on with the sight now I had MR Yuck runs a sixpak with the Snow water/meth injection kit on this post when I posted it last night
[Re: moparcanuk]
#1547336
12/14/13 01:19 PM
12/14/13 01:19 PM
Posts: 12,028 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
In this day and age of varying gas qualities, inconsistent ethanol content and regulatory changes, water injection may well at least protect our engines if not add a significant level of performance.
I am seriously considering making it a part of my next build. I run 11:1 on pump gas and things are good.......most of the time. But the engine is on the edge and occasionally I need to back the timing off because of gas even though I gas up at the same place. (93 octane supposedly)
It appears that meth/water injection can produce real performance improvements in certain combos. The water injection just may be a cushion that allows for a tighter tune without being on the ragged edge of destruction. That alone would be worth the price of admission.
Master, again and still
[Re: rbstroker]
#1547339
12/15/13 01:24 PM
12/15/13 01:24 PM
Posts: 4,916 new berlin wisconsin
Mr T2U
there have been several cars on my friends dyno that had water/methanol injection. it has wasted his heated oxygen sensor on the dyno several times. it can help if you motor is built for it and you know what how to use it properly. basically with W/M injection it cools the intake charge allowing you to run more timing and compression for additional power. it can also be used in boosted applications for more power. it really helps boosted cars without intercoolers.
perception is 90% of reality
[Re: moparcanuk]
#1547342
12/15/13 04:47 PM
12/15/13 04:47 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
'Race gas performance on pump gas'...
The eternal chase...
At the end of the day, I think I'll make my life easier...
Like I have for a lot of years...
Throw in a little CAM 2...And be good to go...
I have no desire for incessant cam changes, head changes, compression jockeying, timing issues, carb issues, temp variations, pre-ignition, detonation, octane issues...
And on and on and on...
[Re: DaveRS23]
#1547349
12/16/13 01:01 AM
12/16/13 01:01 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I am seriously considering making it a part of my next build. I run 11:1 on pump gas and things are good.......most of the time. But the engine is on the edge and occasionally I need to back the timing off. The water injection just may be a cushion that allows for a tighter tune without being on the ragged edge of destruction. That alone would be worth the price of admission.
I had a few people suggest this product when I was dealing with detonation in my Charger. I have no room to use a spacer plate type system though since my air cleaner is 1/4" from the hood. Running 11.0 or higher compression ratios mean that you can't ever let your guard down. I decided that being on that ragged edge of detonation for a few extra HP isn't worth it to me.
