B Body Rack and pinion - Info wanted #1547183
12/13/13 06:39 PM
12/13/13 06:39 PM
Bethlehem Pa.
tinman68 Offline OP
tinman68  Offline OP
Bethlehem Pa.
I'm considering a rack and pinion for my 68 Charger B-body Big block.
please post info on various types. installation issues. and you opinion on this project.
also can I remove existing steering power steering box w/headers mounted to motor.
Re: B Body Rack and pinion - Info wanted [Re: tinman68] #1547184
12/13/13 07:31 PM
12/13/13 07:31 PM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
Check out Reilly Motor Sports set up.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: B Body Rack and pinion - Info wanted [Re: klunick] #1547185
12/14/13 12:24 AM
12/14/13 12:24 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I installed an alterktion in my 70 GTX and it was a piece of cake. I am not done with the build yet so I cannot say how it handles but I am positive it is going to be awesome! All the guys with them in A Bodies rave about it.
Driving modern convenience in classic beauty
Re: B Body Rack and pinion - Info wanted [Re: Darius] #1547186
12/14/13 12:26 AM
12/14/13 12:26 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
What will you do in the rear? Here is what I did, also purchased from RMS
Re: B Body Rack and pinion - Info wanted [Re: tinman68] #1547187
12/14/13 02:23 AM
12/14/13 02:23 AM
Pikes Peak Country
TC@HP2 Online content
TC@HP2  Online Content
Pikes Peak Country
Unless you are considering swapping out the entire front suspension for something specifically designed to work with a rack, I'd advise against a simple R&P conversion and install a Borgeson steering box instead. It bolts in easier, doesn't loose turning radius, avoids adding bump steer, is smaller and lighter than the original box, and its feel is probably as close to a R&P as you can get with a steering box.
Re: B Body Rack and pinion - Info wanted [Re: TC@HP2] #1547188
12/15/13 01:49 AM
12/15/13 01:49 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Slightly OT, at the PRI show I saw my first "herringbone" R&P, for those that have everything
Re: B Body Rack and pinion - Info wanted [Re: jcc] #1547189
12/16/13 11:32 AM
12/16/13 11:32 AM
Wildwood, FL
1fastabody Offline
1fastabody  Offline
Wildwood, FL
X2 for the Borgeson steering box. Bolts right in and gives you that "feel"
Re: B Body Rack and pinion - Info wanted [Re: 1fastabody] #1547190
12/16/13 05:10 PM
12/16/13 05:10 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
The reduced turning radius and bump steer issues alone should be carefully considered. The new borg box offers precision and feel that was never available in the past.
