Re: using chevy pistons in a mopar
[Re: pittsburghracer]
#1546811
12/12/13 03:36 PM
12/12/13 03:36 PM
Posts: 20,678 in a cattle trailer down by th...
Guitar Jones
Skip the Chevy pistons, not only is the valve angle wrong but the valves in a Chevy aren't on center with the cylinder like the SBM.
I've had Wiseco, Diamond, and Ross pistons in the past and all are high quality and you can get exactly what you want for just a little more money over a shelf stock. Well worth it in my opinion.
[Re: mopar dave]
#1546816
12/12/13 04:35 PM
12/12/13 04:35 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Last time I talked to Vic all their pistons were not all listed. A phone call next week would get you the needed info. ![](/ubbthreads/images/graemlins/Twocents.gif) Are you calculating your compression at deck height and with that compression are your going with cometic gaskets? They will make you what you need.
[Re: mopar dave]
#1546820
12/12/13 05:10 PM
12/12/13 05:10 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Looks like you have some playing room with that head gasket.
[Re: mopar dave]
#1546821
12/12/13 05:36 PM
12/12/13 05:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I talked to Diamond and for about $35 for the set they will move the pin height if needed and other things as well... I have chevy blanks in mine that the valve pockets are mopar and I had some dish put in to lower the compression a little... they will treat you well and they have been quick.... the last set I got took 3 days for my Rampage...but I also know the owner ![](/ubbthreads/images/graemlins/wave.gif)
#1546824
12/13/13 12:28 AM
12/13/13 12:28 AM
Posts: 526 NC
barracuda man
NC
I don't know why guys want to make this game harder than it already is but you should call Wisco and ask to talk to Vic Elinger. They have some beautiful on the shelf items for Mopars. Vic is a Mopar man himself. He is at PRI this week so call him next week and see what they have to offer. These are going in my build for next year.
![](http://i753.photobucket.com/albums/xx174/jacadamore/smallblockstrokerbuildparts004_zps5656f6c5.jpg)
![](http://i753.photobucket.com/albums/xx174/jacadamore/smallblockstrokerbuildparts003_zps6b67c998.jpg)
![](http://i753.photobucket.com/albums/xx174/jacadamore/smallblockstrokerbuildparts002_zpse5e308b2.jpg)
This is the piston i plan to run with aluminum rods and a 65* comedic head gasket.Hope to run 6.30 ets with the sb 418 stroker. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Performance Only]
#1546826
12/13/13 02:25 AM
12/13/13 02:25 AM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Just so you know, it's about 40.00 dollars PER CHANGE to shelf stock and you're allowed UP TO TWO CHANGES. I’m a Distributor for Diamond, Let me know if I can help.
Dan,
Didn’t they used to give you 2 free changes?
So there’s a 2 limit change for stocking numbers now?
What if I want 3 or 4 total changes?
