2001 RAM 3500 TOW RIG PROGRAMER
#1546662
12/12/13 08:40 AM
12/12/13 08:40 AM
Posts: 90 North Carolina
CALSDART
North Carolina
Looking for recommendations for a programer/tuner for my 2001 DODGE RAM tow rig. It has 125,000 miles on it, auto, 5.9 diesel. I tow a 28 ft box with the car and golf cart.What have you had success with?
Calvin Thompson
Re: 2001 RAM 3500 TOW RIG PROGRAMER
[Re: DodgeCharger]
#1546666
12/12/13 10:08 AM
12/12/13 10:08 AM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
My last 2001 came with a Superchips programmer, and it added a ton to it...Pulled my 24' fully loaded with quad, fuel, tool, generator, race car, etc 10klbs like it wasn't there....Pretty cheap price on those too....
[Re: J_BODY]
#1546670
12/12/13 04:38 PM
12/12/13 04:38 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
do it right the first time: GAUGES, TRANSMISSION UPGRADES, POWER ADDER. This is what you NEED to do if you want to stay happy with your truck. I've lost count on how many people back in the day added the power ignoring the rest of the package. Good gauges are $400... drop in the bucket compared to a melted #6 piston.
80+k of towing bliss with my 01. Edge EZ, RV275 injectors, Goerend torque converter and valve body kit, BD X-monitor gauges. Tows our 24 or 28 race rig in the mountains of the west and does it well.
[Re: 72demon416]
#1546671
12/12/13 05:07 PM
12/12/13 05:07 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
My 2002 was an excellent tow rig Mine was different from yours since it was a 5.9 HO with 6 speed manual. The PO used it to pull a 5th wheel all up and down the West Coast and he had equipped it with Gauges (EGT, Boost & Fuel Pressure), Exhaust Brake, South Bend clutch and "marine" injectors. I played with air filter kits and went back to stock. I carried a timing kit (Van Aacken?)in the box for 3 years and never felt the need to install it. I did install a 4" MBRP stainless exhaust and saw a little improvement in EGT under load (and a change in exhaust note) and I did install a FASS DDRP lift pump on the frame rail when I changed the dying VP44. It towed the family 8,000# travel trailer with ease all over the Northwest. I would still have it if I had not wrecked it (and me) and had to sell it. The Chev 1 ton dually with 454 TH400 I have now is a poor replacemment, both in power, reliability and fuel economy The only place the Chev is better is the seats (2 full size benches) and if I had a Mega Cab CTD with A/T there would be no contest.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: 72demon416]
#1546672
12/12/13 07:31 PM
12/12/13 07:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I put a A-pillar gauge set on my truck.. has fuel pressure, boost pressure and EGT.. best thing you can do
[Re: dizuster]
#1546673
12/12/13 09:12 PM
12/12/13 09:12 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Depends how much you want to spend. Edge Juice with attitude is definately the best in my opinion. You can make power /smoke adjustment on the fly, and make big power. It most definately has enough power to kill a stock automatic trans. If you are just looking for a kick in the pants, get an edge ez. It will make a noticeable difference, the are fairly inexpensive, easy to install (plug in), and won't hurt durability to bad.
speaking from experience here.
Or get super nasty and put a P pump on that 24v
[Re: John_T_Brown]
#1546675
12/13/13 01:01 AM
12/13/13 01:01 AM
Posts: 257 Way North Idaho
1KoolBee
Way North Idaho
x2 on the Hypertech. I've been running one set to stage 3 for about 100K miles on my 01 2500, nice power, zero probs, tows great, picked up 2 mpg hiway to boot. Since I live in the People's Republik of Kahlifonia, its real handy to be able to put her back to the stock map for the biennial smog-check (really...on a diesel?!) Kind of like how we used to disconnect all of the smog crap & crank the timing back in the 70's, then reconnect it all & lean & retard everything every 2 years just for 5 minutes on the smog machine!
'68 Bee 383/TF/Factory Air...high school sweetheart '67 GTX Clone project,500 six pack,Hemi4-speed,Dana 05 Dodge Viper, 505 V-10, 6-speed Tremec
[Re: J_BODY]
#1546676
12/13/13 01:10 AM
12/13/13 01:10 AM
Posts: 43,626 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I have a Bully Dog Triple Dog and it worked pretty well until I had an injector go wide-open, hydraulic the engine, and kick a rod. That was at 165K miles and if I would have just stopped when it started blowing white smoke it probably would have been fine. The biggest issue with Cummins engines are the injectors, as long as you keep them clean and lubricated any power adder will work just fine.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Sixpak]
#1546679
12/13/13 02:06 AM
12/13/13 02:06 AM
MR_P_BODY
I'm lucky (in a way)... I run the old 12 valve and all I do is put a bigger fuel card in the pump(just a metal plate with a different slot) and the different governor
[Re: MR_P_BODY]
#1546680
12/13/13 03:13 AM
12/13/13 03:13 AM
SpareParts
Janesville, WI
We diesel enthusiasts have reason to believe that 12 valves and P pumps were engineered by God.
