2001 RAM 3500 TOW RIG PROGRAMER #1546662
12/12/13 08:40 AM
12/12/13 08:40 AM
North Carolina
CALSDART Offline OP
CALSDART  Offline OP
North Carolina
Looking for recommendations for a programer/tuner for my 2001 DODGE RAM tow rig. It has 125,000 miles on it, auto, 5.9 diesel. I tow a 28 ft box with the car and golf cart.What have you had success with?
Calvin Thompson
Re: 2001 RAM 3500 TOW RIG PROGRAMER [Re: CALSDART] #1546663
12/12/13 09:32 AM
12/12/13 09:32 AM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
Edge Juice with Attitude. I had a 2001 truck with one on and I have one on my 2006 Ram.
Re: 2001 RAM 3500 TOW RIG PROGRAMER [Re: DodgeCharger] #1546664
12/12/13 09:45 AM
12/12/13 09:45 AM
North Carolina
CALSDART Offline OP
CALSDART  Offline OP
North Carolina
Thanks Dodgecharger
Calvin Thompson
Re: 2001 RAM 3500 TOW RIG PROGRAMER [Re: DodgeCharger] #1546665
12/12/13 09:58 AM
12/12/13 09:58 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Depends how much you want to spend. Edge Juice with attitude is definately the best in my opinion. You can make power /smoke adjustment on the fly, and make big power. It most definately has enough power to kill a stock automatic trans. If you are just looking for a kick in the pants, get an edge ez. It will make a noticeable difference, the are fairly inexpensive, easy to install (plug in), and won't hurt durability to bad.
Re: 2001 RAM 3500 TOW RIG PROGRAMER [Re: DodgeCharger] #1546666
12/12/13 10:08 AM
12/12/13 10:08 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
My last 2001 came with a Superchips programmer, and it added a ton to it...Pulled my 24' fully loaded with quad, fuel, tool, generator, race car, etc 10klbs like it wasn't there....Pretty cheap price on those too....
Re: 2001 RAM 3500 TOW RIG PROGRAMER [Re: CALSDART] #1546667
12/12/13 10:52 AM
12/12/13 10:52 AM
Sterling Heights, MI
John_T_Brown Offline
Used this for years for towing and you can program the engine on the highest power setting without any problems.
Go Here
If it ain't broke fix it anyway!
Re: 2001 RAM 3500 TOW RIG PROGRAMER [Re: John_T_Brown] #1546668
12/12/13 11:10 AM
12/12/13 11:10 AM
Out West
408strokerdart Offline
Out West
I have a superchips programmer on my '06 and it is awsome. Can't deny the results....27mpg empty and over 16mpg towing my 40' gooseneck loaded down. Just have to be very careful as you can blow thru the stock clutch very easily. I have a dual disc South Bend clutch on my "to-do" list.
Re: 2001 RAM 3500 TOW RIG PROGRAMER [Re: 408strokerdart] #1546669
12/12/13 12:18 PM
12/12/13 12:18 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
do it right the first time: GAUGES, TRANSMISSION UPGRADES, POWER ADDER. This is what you NEED to do if you want to stay happy with your truck. I've lost count on how many people back in the day added the power ignoring the rest of the package. Good gauges are $400... drop in the bucket compared to a melted #6 piston.
80+k of towing bliss with my 01. Edge EZ, RV275 injectors, Goerend torque converter and valve body kit, BD X-monitor gauges. Tows our 24 or 28 race rig in the mountains of the west and does it well.
Re: 2001 RAM 3500 TOW RIG PROGRAMER [Re: J_BODY] #1546670
12/12/13 04:38 PM
12/12/13 04:38 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
Re: 2001 RAM 3500 TOW RIG PROGRAMER [Re: 72demon416] #1546671
12/12/13 05:07 PM
12/12/13 05:07 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
My 2002 was an excellent tow rig
Mine was different from yours since it was a 5.9 HO with 6 speed manual. The PO used it to pull a 5th wheel all up and down the West Coast and he had equipped it with Gauges (EGT, Boost & Fuel Pressure), Exhaust Brake, South Bend clutch and "marine" injectors. I played with air filter kits and went back to stock. I carried a timing kit (Van Aacken?)in the box for 3 years and never felt the need to install it. I did install a 4" MBRP stainless exhaust and saw a little improvement in EGT under load (and a change in exhaust note) and I did install a FASS DDRP lift pump on the frame rail when I changed the dying VP44. It towed the family 8,000# travel trailer with ease all over the Northwest. I would still have it if I had not wrecked it (and me) and had to sell it. The Chev 1 ton dually with 454 TH400 I have now is a poor replacemment, both in power, reliability and fuel economy The only place the Chev is better is the seats (2 full size benches) and if I had a Mega Cab CTD with A/T there would be no contest.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 2001 RAM 3500 TOW RIG PROGRAMER [Re: 72demon416] #1546672
12/12/13 07:31 PM
12/12/13 07:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I put a A-pillar gauge set on my truck.. has fuel
pressure, boost pressure and EGT.. best thing you
can do
Re: 2001 RAM 3500 TOW RIG PROGRAMER [Re: dizuster] #1546673
12/12/13 09:12 PM
12/12/13 09:12 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
speaking from experience here.
Or get super nasty and put a P pump on that 24v
Re: 2001 RAM 3500 TOW RIG PROGRAMER [Re: CALSDART] #1546674
12/12/13 11:07 PM
12/12/13 11:07 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
I run a smarty programmer.. works really well for me...
Re: 2001 RAM 3500 TOW RIG PROGRAMER [Re: John_T_Brown] #1546675
12/13/13 01:01 AM
12/13/13 01:01 AM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
x2 on the Hypertech. I've been running one set to stage 3 for about 100K miles on my 01 2500, nice power, zero probs, tows great, picked up 2 mpg hiway to boot. Since I live in the People's Republik of Kahlifonia, its real handy to be able to put her back to the stock map for the biennial smog-check (really...on a diesel?!) Kind of like how we used to disconnect all of the smog crap & crank the timing back in the 70's, then reconnect it all & lean & retard everything every 2 years just for 5 minutes on the smog machine!
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: 2001 RAM 3500 TOW RIG PROGRAMER [Re: J_BODY] #1546676
12/13/13 01:10 AM
12/13/13 01:10 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have a Bully Dog Triple Dog and it worked pretty well until I had an injector go wide-open, hydraulic the engine, and kick a rod. That was at 165K miles and if I would have just stopped when it started blowing white smoke it probably would have been fine. The biggest issue with Cummins engines are the injectors, as long as you keep them clean and lubricated any power adder will work just fine.
JB Rhinehart, Realist
A-Body's RULE!
Re: 2001 RAM 3500 TOW RIG PROGRAMER [Re: Rhinodart] #1546677
12/13/13 01:21 AM
12/13/13 01:21 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
It's probably a good time to point out that the biggest issue in the 24v is the VP44 injection pump. The stock lift pump doesn't keep up with fuel demands of a chipped truck and since the VP is cooled and lubricated by fuel, when it starts to get a low supply of fuel they get hot and fail. That costs you money
Re: 2001 RAM 3500 TOW RIG PROGRAMER [Re: SpareParts] #1546678
12/13/13 02:00 AM
12/13/13 02:00 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Knock on wood, I'm sill running my original VP44 on my 01 2500 6 speed. Moved the stock lift pump at 88K back by the tank using a Vulcan kit and 1/2" lines to the filter and from the filter to the VP44. No power adders...yet. 167k miles.
Re: 2001 RAM 3500 TOW RIG PROGRAMER [Re: Sixpak] #1546679
12/13/13 02:06 AM
12/13/13 02:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm lucky (in a way)... I run the old 12 valve and all
I do is put a bigger fuel card in the pump(just a metal
plate with a different slot) and the different governor
Re: 2001 RAM 3500 TOW RIG PROGRAMER [Re: MR_P_BODY] #1546680
12/13/13 03:13 AM
12/13/13 03:13 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
We diesel enthusiasts have reason to believe that 12 valves and P pumps were engineered by God.
Re: 2001 RAM 3500 TOW RIG PROGRAMER [Re: SpareParts] #1546681
12/13/13 02:07 PM
12/13/13 02:07 PM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
I'm just looking for better economy on m 2004 w/ 6-speed.
Been thinking of getting a Smarty or Banks tuner. Haven't had much feedback form anyone as far as economy on any tuners.
Most seemed to be more worried about HP over economy.
I personally bought a Diesel for Economy for pulling a trailer not HP.
