welding aluminum radiators #1546637
12/12/13 04:13 AM
12/12/13 04:13 AM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
What's the deal on tig welding radiators, Had some an fittings welded on and the welder said he had problems. The radiator is used nascar one, beautifully tig welded, now not so much.
Re: welding aluminum radiators [Re: rowin4] #1546638
12/12/13 04:29 AM
12/12/13 04:29 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Clean, clean, and clean some more. just like anything that is aluminum and needs to be welded. There are preweld cleaners made just for aluminum that clean very well that remove oils and oxidation. I am sure the antifreeze is a pain to get completely cleaned off, but it has to be done. The only radiator I have welded was a new griffin that was epoxied together at the cores and I had no problems with it. Just welded a side cover for a quad today that was very oily before cleaning and it came out great. Washed with alcohol and then the preweld cleaner. Beep
Re: welding aluminum radiators [Re: Bigbeep] #1546639
12/12/13 04:45 AM
12/12/13 04:45 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What he said..Likely the cause was contamenents from inside the radiator. Not much you can do in that case. best to start with a NEW radiator if you are gonne be doing any welding on it.
Re: welding aluminum radiators [Re: Al_Alguire] #1546640
12/12/13 11:31 AM
12/12/13 11:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Clean it GOOD with a stainless brush and clean the
color off the fitting
EDIT
I do the welding first then drill the hole so you
dont get trash coming out of the hole
Re: welding aluminum radiators [Re: MR_P_BODY] #1546641
12/12/13 05:27 PM
12/12/13 05:27 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
EDIT
That's a good tip. Thanks.
Re: welding aluminum radiators [Re: Leigh] #1546642
12/12/13 08:25 PM
12/12/13 08:25 PM
organ
maximum entropy Offline
organ
i did radiators for a living for 1/5 of a century. once aluminum has been in service, it is corrupted, and requires different methods. beyond a certain point, they are no longer weldable. like alguire said, the problem is from within, mainly.
Re: welding aluminum radiators [Re: Leigh] #1546643
12/12/13 10:04 PM
12/12/13 10:04 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
EDIT
