welding aluminum radiators
#1546637
12/12/13 04:13 AM
12/12/13 04:13 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
What's the deal on tig welding radiators, Had some an fittings welded on and the welder said he had problems. The radiator is used nascar one, beautifully tig welded, now not so much.
Re: welding aluminum radiators
[Re: Bigbeep]
#1546639
12/12/13 04:45 AM
12/12/13 04:45 AM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
What he said..Likely the cause was contamenents from inside the radiator. Not much you can do in that case. best to start with a NEW radiator if you are gonne be doing any welding on it.
[Re: Al_Alguire]
#1546640
12/12/13 11:31 AM
12/12/13 11:31 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Clean it GOOD with a stainless brush and clean the color off the fitting EDIT I do the welding first then drill the hole so you dont get trash coming out of the hole
[Re: MR_P_BODY]
#1546641
12/12/13 05:27 PM
12/12/13 05:27 PM
Posts: 5,991 Anoka County, MN
Leigh
Anoka County, MN
That's a good tip. Thanks.
[Re: Leigh]
#1546642
12/12/13 08:25 PM
12/12/13 08:25 PM
Posts: 5,080 organ
maximum entropy
organ
i did radiators for a living for 1/5 of a century. once aluminum has been in service, it is corrupted, and requires different methods. beyond a certain point, they are no longer weldable. like alguire said, the problem is from within, mainly.
