tire pressure #1546596
12/12/13 01:21 AM
12/12/13 01:21 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Was running 14 lbs with tubes in my 29X13.5/15 Hoosiers QT's. Gonna start the season with the same tires, but tubeless. Thinking of starting around 20 lbs?
Fastest 300
Re: tire pressure [Re: Crizila] #1546597
12/12/13 01:27 AM
12/12/13 01:27 AM
You could start at 20 lbs and then, if it spins, let it down a 1/2 lb at a time until it stops spinning BTW, are those tires radials or bias ply tires? Me no speak Hoosiers
Re: tire pressure [Re: Crizila] #1546598
12/12/13 01:33 AM
12/12/13 01:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Weight on the back of the car makes a BIG difference
what you need for pressure
Re: tire pressure [Re: Cab_Burge] #1546599
12/12/13 01:34 AM
12/12/13 01:34 AM
S.E. South Dakota !
bigdad Online content
Still Posting A Lot
bigdad  Online Content
Still Posting A Lot
S.E. South Dakota !
You know your car better than anyone but ..
20 lbs sounds like an awful lot to me ??
What does MFG recommend ?
They hit it pretty close most often
Re: tire pressure [Re: bigdad] #1546600
12/12/13 12:46 PM
12/12/13 12:46 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
No recommendations on their sight for tire pressure. They are bias ply tires. They wrinkled quite a bit with 14 lbs in them. At 11 lbs they looked like they were starting to wad. I considered going up in pressure due to less side wall support with no tubes? Car is heavy ( 3600 lbs )and I am sure more than 50% on the nose.
Fastest 300
Re: tire pressure [Re: Crizila] #1546601
12/12/13 01:13 PM
12/12/13 01:13 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
John I would call Hoosier & see what they reccomend.
I use M/Ts and they said what Cab said.
Hoosier may be able to give a good starting point.
Don
Re: tire pressure [Re: Crizila] #1546602
12/12/13 01:37 PM
12/12/13 01:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would start raising it until the 60' starts to drop
then back off a bit... you should see a better ET
and MPH
Re: tire pressure [Re: MR_P_BODY] #1546603
12/12/13 02:16 PM
12/12/13 02:16 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
14-24 seems to be the range. I went from 14 to 18 and pickup a bit. I was told to try 24 with caltracs and dump air til it does'nt spin. mph is better with more air. I run my qtp without tubes.
Re: tire pressure [Re: Crizila] #1546604
12/12/13 04:57 PM
12/12/13 04:57 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Are those qtp`s? If so, I raced for years in the 10 1/2-12 lbs. range and for me 12 was best but never tried more............
Re: tire pressure [Re: Thumperdart] #1546605
12/12/13 05:03 PM
12/12/13 05:03 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
yes quick time pro 28x11.50. hoosier suggested starting at 14, so I ran it there first couple times out. last time out put 16 in and then 18 and mph went from 128 to 129 and 130. 131 with hoosier drag radial at 18.
Re: tire pressure [Re: mopar dave] #1546606
12/12/13 06:17 PM
12/12/13 06:17 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Ok, thanks all. Think I will start at 18 and go from there. Made multiple changes since last time out, so it's "guess-o-matic" On many fronts. Just trying not to do something stupid - AGAIN
Fastest 300
Re: tire pressure [Re: Crizila] #1546607
12/12/13 08:34 PM
12/12/13 08:34 PM
Renton Washington
Triple Threat Offline
Renton Washington
Why are you ditching the tubes? In my experience heavier cars like them.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: tire pressure [Re: Crizila] #1546608
12/12/13 08:59 PM
12/12/13 08:59 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
They may need more but I doubt 20. I personally have never seen anyone run 20 PSI in a bias slick that large, maybe 15-16
Doug
Re: tire pressure [Re: Triple Threat] #1546609
12/12/13 10:46 PM
12/12/13 10:46 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
I might go back to them, but I was having "rim creep" at 14 lbs and was concerned about swallowing a valve stem. Don't wanna use screws. Could have glued them, which is what I have done when I mounted them back up without the tubes. Next outing is first week in January, so I guess I will see then.
Fastest 300
Re: tire pressure [Re: Crizila] #1546610
12/13/13 03:12 AM
12/13/13 03:12 AM
If those tires are not directional how about rotating them every other race to stop and reverse the tire movement I've done that in the past on tubeless tires, mark the bead at the valve stem and watch the movement, when it has moved 1 to 2 inche switch sides and wait until it goes 1 inch past the original marks the other way and then swap them again another option is to use screws on the inside only
Re: tire pressure [Re: Cab_Burge] #1546611
12/13/13 01:46 PM
12/13/13 01:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`d run screws myself and screws on the inside only have proven to not be the answer. There`s some videos and posts on the bullet talking about this and even mentions having the inside and outside screws be in the exact location. It was also mentioned that the amount of screws determins how the tire "wads up" and the length of those wads................
Re: tire pressure [Re: Thumperdart] #1546612
12/13/13 02:29 PM
12/13/13 02:29 PM
Q
Quicktree Offline
Quicktree  Offline
Q
is this pressure while you are street racing or at the track?
Re: tire pressure [Re: Quicktree] #1546613
12/13/13 02:48 PM
12/13/13 02:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I don`t street race............YET! What pressures r u refering too?
Re: tire pressure [Re: Quicktree] #1546614
12/13/13 03:48 PM
12/13/13 03:48 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
. Good idea on the tire rotation Cab. Already got them marked.
Fastest 300
Re: tire pressure [Re: Thumperdart] #1546615
12/13/13 03:53 PM
12/13/13 03:53 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Ya Dom, was running screws on both sides and same location per your thread. Just don't want to screw my new Convo Pros if I don't have to. BTW, got a screw locating disc for 15" wheels if anyone ever needs to borrow it.
Fastest 300
