tire pressure
#1546596
12/12/13 01:21 AM
12/12/13 01:21 AM
Posts: 7,506 Az
Crizila
Az
Was running 14 lbs with tubes in my 29X13.5/15 Hoosiers QT's. Gonna start the season with the same tires, but tubeless. Thinking of starting around 20 lbs?
Fastest 300
Re: tire pressure
[Re: Crizila]
#1546601
12/12/13 01:13 PM
12/12/13 01:13 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
John I would call Hoosier & see what they reccomend. I use M/Ts and they said what Cab said. Hoosier may be able to give a good starting point. Don
Re: tire pressure
[Re: Crizila]
#1546602
12/12/13 01:37 PM
12/12/13 01:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You know your car better than anyone but ..
20 lbs sounds like an awful lot to me ??
What does MFG recommend ?
They hit it pretty close most often
No recommendations on their sight for tire pressure. They are bias ply tires. They wrinkled quite a bit with 14 lbs in them. At 11 lbs they looked like they were starting to wad. I considered going up in pressure due to less side wall support with no tubes? Car is heavy ( 3600 lbs )and I am sure more than 50% on the nose.
I would start raising it until the 60' starts to drop then back off a bit... you should see a better ET and MPH
Re: tire pressure
[Re: Crizila]
#1546607
12/12/13 08:34 PM
12/12/13 08:34 PM
Triple Threat
Renton Washington
Why are you ditching the tubes? In my experience heavier cars like them.
Re: tire pressure
[Re: Crizila]
#1546608
12/12/13 08:59 PM
12/12/13 08:59 PM
Posts: 9,846 MI, usa
dvw
MI, usa
They may need more but I doubt 20. I personally have never seen anyone run 20 PSI in a bias slick that large, maybe 15-16 Doug
Re: tire pressure
[Re: Crizila]
#1546610
12/13/13 03:12 AM
12/13/13 03:12 AM
Posts: 43,207 Bend,OR USA
Cab_Burge
If those tires are not directional how about rotating them every other race to stop and reverse the tire movement I've done that in the past on tubeless tires, mark the bead at the valve stem and watch the movement, when it has moved 1 to 2 inche switch sides and wait until it goes 1 inch past the original marks the other way and then swap them again another option is to use screws on the inside only
