Is there a cure??? AAR side marker light studs stripped #1545531
12/08/13 11:49 PM
12/08/13 11:49 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
I put my side marker light housings in a few weeks ago and used the correct reproduction cone nuts. The studs that are cast into the bezel appeared fine before installation and I was using a nut driver and didn't crank on them at all but they never seemed to tighten. I am gonna pull them apart in the next few days to see if it stripped them as I fear. As you can appreciate they are already painted so I would really prefer not to replace them. Does anyone know a cure for this? I am considering something to build up the stud and triying again, any suggestions would be greatly appreciated.
Thanks in advance, Kevin
Careful, your character's showing!
Re: Is there a cure??? AAR side marker light studs stripped [Re: mopar346] #1545532
12/09/13 04:01 AM
12/09/13 04:01 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
jb weld
Re: Is there a cure??? AAR side marker light studs stripped [Re: mopar346] #1545533
12/09/13 05:16 AM
12/09/13 05:16 AM
Lancaster, CA
W
WARBUG Offline
WARBUG  Offline
W
Lancaster, CA
The studs are not cast into the bezel they are threaded into it and are replaceable. Just grab the stud with a vise grip and unscrew it. Replace the acorn nut too if necessary but the painted frame is certainly salvageable. I saw the stud sold separately but don't remember who it was that carried them.
Re: Is there a cure??? AAR side marker light studs stripped [Re: WARBUG] #1545534
12/09/13 10:32 AM
12/09/13 10:32 AM
mopar346 Offline OP
mopar346  Offline OP
On a 70 2 of the studs are replaceable and they are fine, but 2 are part of the casting like an emblem. You can see them in the auction below.
I thought about JB weld just not sure how it will hold up as the nut cuts into it.
http://www.ebay.com/itm/70-CUDA-REAR-MAR...9fc&vxp=mtr
Re: Is there a cure??? AAR side marker light studs stripped [Re: mopar346] #1545535
12/09/13 02:04 PM
12/09/13 02:04 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
carefully dress down the stripped stud and epoxy a short length of brass tubing. You can even go oversized if you drill out the mounting holes.
Re: Is there a cure??? AAR side marker light studs stripped [Re: srt] #1545536
12/09/13 03:37 PM
12/09/13 03:37 PM
Sacramento,California
JRepucci Offline
JRepucci  Offline
Replace the marker housing... a car is only as good as the parts its built with.
