95 Dodge Ram transmission #1545398
12/08/13 09:04 PM
12/08/13 09:04 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Anyone know what tranny comes in these trucks? It has the 5.9 if that matters.And r there any rebuild kits out there for them.Thax.
Re: 95 Dodge Ram transmission [Re: racerx] #1545399
12/08/13 10:12 PM
12/08/13 10:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Stick or auto 2 wheel or 4 wheel drive?
Re: 95 Dodge Ram transmission [Re: stumpy] #1545400
12/08/13 10:21 PM
12/08/13 10:21 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
2-wheel auto
Re: 95 Dodge Ram transmission [Re: racerx] #1545401
12/08/13 10:43 PM
12/08/13 10:43 PM
Kansas
cascius Offline
cascius  Offline
Kansas
Gas or Diesel?
Re: 95 Dodge Ram transmission [Re: cascius] #1545402
12/08/13 11:55 PM
12/08/13 11:55 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Gas.
Re: 95 Dodge Ram transmission [Re: racerx] #1545403
12/09/13 03:15 AM
12/09/13 03:15 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
It's got a 46 RH, plenty of rebuild kits and some worthy upgrades to the OD unit
Re: 95 Dodge Ram transmission [Re: WO23Coronet] #1545404
12/09/13 09:57 PM
12/09/13 09:57 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Care to share?what or my option on the od unit?I think mines is getting ready to kick the bucket it's has this vibration at about 55-60 mph in od and it seems to have a slight rpm slippage and was wondering whats my option?..........Thax
Re: 95 Dodge Ram transmission [Re: racerx] #1545405
12/10/13 01:02 AM
12/10/13 01:02 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You can use the diesel guts to beef up the capacity of your trans. Add an extra clutch to the front drum to a total of 4 is an easy upgrade. Adding extra OD brake and direct clutches in the OD will also help. A good shift kit with valve body mods to increase line pressure and pressure to the TC lock up clutch is also a good idea. Use a GOOD plate style aftermarket cooler when re-installed to keep the heat in check. The factory cooler set-up through the radiator is not the best to say the least.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 95 Dodge Ram transmission [Re: 71yelladustr] #1545406
12/10/13 09:04 PM
12/10/13 09:04 PM
Truckville, the capital of NY
85_Ram_4speed Offline
The factory had external coolers that install in between the rad and A/C condensor--They bolt right onto the V-brace. Couldn't get any easier. I just got a couple from a junkyard (make sure they have clean fluid in them and then still flush them out with cleaner) and installed one in my '95 as I have been starting to tow my trailer some more.
Outcast Dodge guy.
Re: 95 Dodge Ram transmission [Re: 71yelladustr] #1545407
12/13/13 02:21 PM
12/13/13 02:21 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Will a 1995 2wd OD unit from a 47RH
bolt onto a
1995 2wd 46RH transmission in place of its original OD unit?
Or must you start with a OD unit from a 46RH and then beef up its internals?
Re: 95 Dodge Ram transmission [Re: 360view] #1545408
12/14/13 01:19 PM
12/14/13 01:19 PM
Missouri U.S.A.
Missouri U.S.A.
It will bolt on to the 46. You will want to swap out the diesel governor for the gas unit.
10.02@134
