95 Dodge Ram transmission #1545398
12/08/13 09:04 PM
12/08/13 09:04 PM
Mo.
racerx Online work OP
racerx  Online Work OP
Mo.
Anyone know what tranny comes in these trucks? It has the 5.9 if that matters.And r there any rebuild kits out there for them.Thax.
Re: 95 Dodge Ram transmission [Re: racerx] #1545399
12/08/13 10:12 PM
12/08/13 10:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Stick or auto 2 wheel or 4 wheel drive?
Re: 95 Dodge Ram transmission [Re: stumpy] #1545400
12/08/13 10:21 PM
12/08/13 10:21 PM
Mo.
Mo.
2-wheel auto
Re: 95 Dodge Ram transmission [Re: racerx] #1545401
12/08/13 10:43 PM
12/08/13 10:43 PM
Kansas
cascius Offline
cascius  Offline
Kansas
Gas or Diesel?
Re: 95 Dodge Ram transmission [Re: cascius] #1545402
12/08/13 11:55 PM
12/08/13 11:55 PM
Mo.
Mo.
Gas.
Re: 95 Dodge Ram transmission [Re: racerx] #1545403
12/09/13 03:15 AM
12/09/13 03:15 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
It's got a 46 RH, plenty of rebuild kits and some worthy upgrades to the OD unit
Re: 95 Dodge Ram transmission [Re: WO23Coronet] #1545404
12/09/13 09:57 PM
12/09/13 09:57 PM
Mo.
Mo.
Care to share?what or my option on the od unit?I think mines is getting ready to kick the bucket it's has this vibration at about 55-60 mph in od and it seems to have a slight rpm slippage and was wondering whats my option?..........Thax
Re: 95 Dodge Ram transmission [Re: racerx] #1545405
12/10/13 01:02 AM
12/10/13 01:02 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You can use the diesel guts to beef up the capacity of your trans. Add an extra clutch to the front drum to a total of 4 is an easy upgrade. Adding extra OD brake and direct clutches in the OD will also help. A good shift kit with valve body mods to increase line pressure and pressure to the TC lock up clutch is also a good idea. Use a GOOD plate style aftermarket cooler when re-installed to keep the heat in check. The factory cooler set-up through the radiator is not the best to say the least.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 95 Dodge Ram transmission [Re: 71yelladustr] #1545406
12/10/13 09:04 PM
12/10/13 09:04 PM
Truckville, the capital of NY
85_Ram_4speed Offline
The factory had external coolers that install in between the rad and A/C condensor--They bolt right onto the V-brace. Couldn't get any easier. I just got a couple from a junkyard (make sure they have clean fluid in them and then still flush them out with cleaner) and installed one in my '95 as I have been starting to tow my trailer some more.
Outcast Dodge guy.
Re: 95 Dodge Ram transmission [Re: 71yelladustr] #1545407
12/13/13 02:21 PM
12/13/13 02:21 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Will a 1995 2wd OD unit from a 47RH
bolt onto a
1995 2wd 46RH transmission in place of its original OD unit?
Or must you start with a OD unit from a 46RH and then beef up its internals?
Re: 95 Dodge Ram transmission [Re: 360view] #1545408
12/14/13 01:19 PM
12/14/13 01:19 PM
Missouri U.S.A.
Missouri U.S.A.
It will bolt on to the 46. You will want to swap out the diesel governor for the gas unit.
10.02@134
