Anyone know of a tool to do this type of work?
#1543773
12/04/13 06:40 PM
12/04/13 06:40 PM
BradH
Working w/ either a Dremel or a "real" die grinder (although a Dremel might do just fine for what I have in mind), I'm wondering if there's any type of fixture or vise designed for clamping down the grinder body and allowing the user to set the angle the bit touches the cutting surface w/ respect to the mounting (sliding?) surface of the fixture / vise. Think of it's usage kind of like the following (abstract as it is): You want to put a 45* bevel on the inside of a large round hole drilled into a flat deck. The tool would allow you to mount the grinder in the fixture, which would remain on the level deck surface, then pivot the grinder down to the desired angle (similar to setting a protractor), thus setting up a straight-sided carbide cutter to cut the inside edge of the cylinder at the specified angle. You'd have to move the grinder / fixture assembly by hand as you applied the bevel to the inside edge. The part being beveled wouldn't be something compact enough to mount on a lathe and modify w/ a cutting tool, which is why I'm trying to think of what would work, or find out if something like this already exists. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
Re: Anyone know of a tool to do this type of work?
[Re: BradH]
#1543780
12/05/13 12:50 PM
12/05/13 12:50 PM
BradH
I'll have to look into what a router offers.
And after checking that out, IMO that's not what I'm looking for.
I need something to help perform hand grinding at a consistent angle, rather than being subject to doing it by eye and periodically double-checking the results vs. a home-made template. ![](/ubbthreads/images/graemlins/scope.gif)
Eh, didn't hurt to ask... ![](/ubbthreads/images/graemlins/burnout.gif)
[Re: BradH]
#1543781
12/05/13 12:58 PM
12/05/13 12:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Are you trying to bevel/champher a cyl bore... tell us what the bevel is on so we get a better idea.. if you are doing a cyl bore the shops have a BIG sanding drum made at a 45* angle so it can be used on multiple size bores ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1543782
12/05/13 01:05 PM
12/05/13 01:05 PM
dogdays
We need more description because to me it certainly sounds like router work. Using a piloted bit will avoid any "by hand" stuff. You set the depth either by spacing up the base or using a plunge router with which you can set the depth of cut. Look on Youtube for demonstrations of cutting aluminum with a router. Follow Link for picture of piloted bit. http://routerbitworld.com/Chamfer-Bits-s/227.htmR.
[Re: BradH]
#1543783
12/05/13 01:40 PM
12/05/13 01:40 PM
Posts: 1,611 westerly, ri. usa
440lebaron
westerly, ri. usa
dremel sells a drill/press to hold tool not sure if it was dremel or off brand, maybe harbor frt??
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#1543784
12/05/13 02:39 PM
12/05/13 02:39 PM
BradH
Guys, you're just going to have to take my word for it that this isn't a router job. If I decide to follow through on what this would involve, it'll have to be a very careful by-hand task --> ![](/ubbthreads/images/graemlins/scope.gif) / ![](/ubbthreads/images/graemlins/sawzall-smiley.gif) / ![](/ubbthreads/images/graemlins/scope.gif) / ![](/ubbthreads/images/graemlins/sawzall-smiley.gif) Nothing else I can add at this point, so I'm finished w/ this thread. Thanks for the ideas, though. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: BradH]
#1543785
12/05/13 02:56 PM
12/05/13 02:56 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
OK Brad, what are you making and putting up for sale? I want one. I was going to make cylinder head bore adapters and radius-ed intake adapters for flowing heads on a flowbench but to much time for to little return. I just made myself a head adapter for a small block Ford and by time I buy a cylinder sleeve and 1/2 lexan I have over 100 dollars in it. Lots of work to lay it out for the head too.
[Re: scatpacktom]
#1543787
12/05/13 05:41 PM
12/05/13 05:41 PM
MR_P_BODY
There is a tool like that... It's called a milling machine
And a 360 table ![](/ubbthreads/images/graemlins/wave.gif)
