Anyone know of a tool to do this type of work? #1543773
12/04/13 06:40 PM
12/04/13 06:40 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Working w/ either a Dremel or a "real" die grinder (although a Dremel might do just fine for what I have in mind), I'm wondering if there's any type of fixture or vise designed for clamping down the grinder body and allowing the user to set the angle the bit touches the cutting surface w/ respect to the mounting (sliding?) surface of the fixture / vise.
Think of it's usage kind of like the following (abstract as it is): You want to put a 45* bevel on the inside of a large round hole drilled into a flat deck. The tool would allow you to mount the grinder in the fixture, which would remain on the level deck surface, then pivot the grinder down to the desired angle (similar to setting a protractor), thus setting up a straight-sided carbide cutter to cut the inside edge of the cylinder at the specified angle.
You'd have to move the grinder / fixture assembly by hand as you applied the bevel to the inside edge. The part being beveled wouldn't be something compact enough to mount on a lathe and modify w/ a cutting tool, which is why I'm trying to think of what would work, or find out if something like this already exists.
Re: Anyone know of a tool to do this type of work? [Re: BradH] #1543774
12/04/13 06:48 PM
12/04/13 06:48 PM
BradH Offline OP
BradH  Offline OP
What just came to mind is something like an overgrown version of a micrometer stand...
Re: Anyone know of a tool to do this type of work? [Re: BradH] #1543775
12/04/13 07:01 PM
12/04/13 07:01 PM
dogdays Offline
dogdays  Offline
How about a small router with a roundover bit?
R.
Re: Anyone know of a tool to do this type of work? [Re: BradH] #1543776
12/04/13 07:01 PM
12/04/13 07:01 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
How about a carbide cutter in a router. A router has a pilot that would make an even depth of cut.
Re: Anyone know of a tool to do this type of work? [Re: AAR-B4] #1543777
12/05/13 12:31 AM
12/05/13 12:31 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Router bits do an excellent job on aluminum. You can cut some very creative edges with them.
Doug
Re: Anyone know of a tool to do this type of work? [Re: BradH] #1543778
12/05/13 11:23 AM
12/05/13 11:23 AM
BradH Offline OP
BradH  Offline OP
I'll have to look into what a router offers. What I had in mind for "real world" usage is a little more creative than the example I offered, but I didn't have a good way to explain it in simpler terms.
Thanks,
Brad
Re: Anyone know of a tool to do this type of work? [Re: BradH] #1543779
12/05/13 12:43 PM
12/05/13 12:43 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Router sounds interesting to me. Wouldn't it spin kind of fast for cutting metals? Just curious..... ...
Randy
Re: Anyone know of a tool to do this type of work? [Re: BradH] #1543780
12/05/13 12:50 PM
12/05/13 12:50 PM
BradH Offline OP
BradH  Offline OP
And after checking that out, IMO that's not what I'm looking for.
I need something to help perform hand grinding at a consistent angle, rather than being subject to doing it by eye and periodically double-checking the results vs. a home-made template.
Eh, didn't hurt to ask...
Re: Anyone know of a tool to do this type of work? [Re: BradH] #1543781
12/05/13 12:58 PM
12/05/13 12:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you trying to bevel/champher a cyl bore... tell
us what the bevel is on so we get a better idea..
if you are doing a cyl bore the shops have a BIG sanding
drum made at a 45* angle so it can be used on multiple
size bores
Re: Anyone know of a tool to do this type of work? [Re: MR_P_BODY] #1543782
12/05/13 01:05 PM
12/05/13 01:05 PM
dogdays Offline
dogdays  Offline
We need more description because to me it certainly sounds like router work. Using a piloted bit will avoid any "by hand" stuff. You set the depth either by spacing up the base or using a plunge router with which you can set the depth of cut.
Look on Youtube for demonstrations of cutting aluminum with a router.
Follow Link for picture of piloted bit.
http://routerbitworld.com/Chamfer-Bits-s/227.htm
R.
Re: Anyone know of a tool to do this type of work? [Re: BradH] #1543783
12/05/13 01:40 PM
12/05/13 01:40 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
dremel sells a drill/press to hold tool not sure if it was dremel or off brand, maybe harbor frt??
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Anyone know of a tool to do this type of work? [Re: 440lebaron] #1543784
12/05/13 02:39 PM
12/05/13 02:39 PM
BradH Offline OP
BradH  Offline OP
Guys, you're just going to have to take my word for it that this isn't a router job.
If I decide to follow through on what this would involve, it'll have to be a very careful by-hand task --> / / /
Nothing else I can add at this point, so I'm finished w/ this thread. Thanks for the ideas, though.
Re: Anyone know of a tool to do this type of work? [Re: BradH] #1543785
12/05/13 02:56 PM
12/05/13 02:56 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
OK Brad, what are you making and putting up for sale? I want one. I was going to make cylinder head bore adapters and radius-ed intake adapters for flowing heads on a flowbench but to much time for to little return. I just made myself a head adapter for a small block Ford and by time I buy a cylinder sleeve and 1/2 lexan I have over 100 dollars in it. Lots of work to lay it out for the head too.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Anyone know of a tool to do this type of work? [Re: pittsburghracer] #1543786
12/05/13 03:05 PM
12/05/13 03:05 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
There is a tool like that... It's called a milling machine
Re: Anyone know of a tool to do this type of work? [Re: scatpacktom] #1543787
12/05/13 05:41 PM
12/05/13 05:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
And a 360 table
Re: Anyone know of a tool to do this type of work? [Re: MR_P_BODY] #1543788
12/05/13 09:35 PM
12/05/13 09:35 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
We have what you're talking about at work. It's not something you can buy though. It was a custom designed apparatus.
