Update on W2 340 #1543402
12/03/13 11:08 PM
12/03/13 11:08 PM
western PA
Sb Valiant Offline OP
western PA
I know some of you guys remember who I am and some of my posts regarding my engine. Finally going to lay some stuff to rest. In our W2 heads we do infact have
2.080" intake valves and 1.600" exhaust. They are the longer valve version. We do
need new valves they are old and shot. Another down fall is it's 3/8 stem which isn't
good for my application. Will be going to what it looks like a 11/32 valve. Next few
things to to do and find out is the head cc's, valve job, guides, and the machine work
that is needed. So yes I think the bigger 950 carb and 1 7/8 headers that most reccomended will be positive gains!
Brock
Re: Update on W2 340 [Re: Sb Valiant] #1543403
12/04/13 10:43 AM
12/04/13 10:43 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Good luck.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Update on W2 340 [Re: 1967dartgt] #1543404
12/04/13 01:49 PM
12/04/13 01:49 PM
dogdays Offline
dogdays  Offline
Why not 5/16 or 8mm stems?
R.
Re: Update on W2 340 [Re: Sb Valiant] #1543405
12/04/13 02:40 PM
12/04/13 02:40 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Brock
Who`s setten em up for ya?
Re: Update on W2 340 [Re: dogdays] #1543406
12/04/13 03:39 PM
12/04/13 03:39 PM
western PA
western PA
I really didn't think of that but it's nice to also be able to use something common and easier to get unless those sizes are not a major problem to do..
Re: Update on W2 340 [Re: Thumperdart] #1543407
12/04/13 03:40 PM
12/04/13 03:40 PM
western PA
western PA
My boss and I at the machine shop I work at
Re: Update on W2 340 [Re: Sb Valiant] #1543408
12/04/13 04:47 PM
12/04/13 04:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Cool...............
Re: Update on W2 340 [Re: Thumperdart] #1543409
12/04/13 07:11 PM
12/04/13 07:11 PM
dogdays Offline
dogdays  Offline
What's the valve stem diameter on a Hemi? 5/16"
G3 Hemi? 8mm, IIRC.
Racers have been using 5/16 or 8mm stems to save weight on valves for 30 years or more.
NASCAR type motors are running 7mm and even I've heard of some 6mm stems, that's pretty doggone small, makes me wonder. But IMHO as long as you're replacing guides, go to a common smaller size, and that's 5/16 or 8mm.
R.
Re: Update on W2 340 [Re: dogdays] #1543410
12/04/13 07:48 PM
12/04/13 07:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
G3 Hemi? 8mm, IIRC.
R.
He should look at whats available in the 2.08 size
and the length needed... some of the companies will
make certain lengths in certain sizes... I went with
the 11/32 stems on mine.... sure he might be able
to get 5/16 but at twice the price
Re: Update on W2 340 [Re: MR_P_BODY] #1543411
12/04/13 08:43 PM
12/04/13 08:43 PM
western PA
western PA
X2 on what Mr. P said. I have heard of a old trick about taking a hemi valve and cutting it to size and putting them in W2's being that they were lighter which would be the 5/16 stem like dogdays had mentioned . But how long is a smaller stem valve like that going to last and wouldn't it break easier ? I have the standard length valve setup in my W2's after asking Mr. P some questions. Thanks again
Re: Update on W2 340 [Re: Sb Valiant] #1543412
12/05/13 01:47 PM
12/05/13 01:47 PM
dogdays Offline
dogdays  Offline
Dudes, I don't know how much they cost. That's for you to find out.
But break? I wondered about that too, how does 500 miles with big springs at 9000 rpm sound? NASCAR. That's where they have downsized the stems to 7 and maybe even 6mm.
If G2 and G3 Hemis can run'em stock, why would they have durability problems in a Wedge?
R.
