904 governor ? #1543356
12/03/13 09:36 PM
12/03/13 09:36 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
I want to plug the feed hole to the governor. Saw it posted before, can't find it. Anyone do this? I have my vent in the tail hsg close to the gasket. There are 2 holes in the gov, 1 has a screen in it & the other looks like a return. Which 1 gets plugged. Thanks 4 ur time. Merry Christmas everyone.
Re: 904 governor ? [Re: rickraw] #1543357
12/03/13 10:23 PM
12/03/13 10:23 PM
Ms.
Dartwizer Offline
Dartwizer  Offline
Ms.
Go on the CRT web site.its there ,I used it also
Re: 904 governor ? [Re: Dartwizer] #1543358
12/03/13 10:36 PM
12/03/13 10:36 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
Thank u sir, i'll check it out.
Re: 904 governor ? [Re: rickraw] #1543359
12/03/13 11:05 PM
12/03/13 11:05 PM
Ms.
Dartwizer Offline
Dartwizer  Offline
Ms.
Your Welcome
Re: 904 governor ? [Re: Dartwizer] #1543360
12/04/13 12:40 AM
12/04/13 12:40 AM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
tap 10-32 install set screw. use both sealing rings on the park gear.
Re: 904 governor ? [Re: CRT] #1543361
12/04/13 02:46 AM
12/04/13 02:46 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Just did mine over the holiday weekend as I was loosing fluid out the rear vent on my 727. I carefully tack welded the indicated hole shut then filed smooth. Hopefully does the trick but, also gonna install a small vented catch can for good measure. Also, thanks CRT for the tech page on your website. Sorry for the minor hijack...
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: 904 governor ? [Re: CRT] #1543362
12/04/13 08:15 PM
12/04/13 08:15 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
Thanks John for making it a tech item. I just tapped the hole & plugged it.
