Lug pattern size #1542977
12/03/13 12:49 AM
12/03/13 12:49 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
What would be the bolt pattern size on a 1980 1/2 ton, long bed Dodge?
I'm looking for a truck for a 16 year old and have come across a few /6, four speeds out there.
Oh, and what kind of gas mileage have you guys seen with these rigs?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Lug pattern size [Re: cdstl] #1542978
12/03/13 01:19 AM
12/03/13 01:19 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
5X4 1/2 that \6 will get all over the board for MPG but you do a Super Six intake & carb
Back in the day I made a \6 lean the other way in a truck like you're describing
Too much Holiday Cheer!
Re: Lug pattern size [Re: cdstl] #1542979
12/03/13 01:19 AM
12/03/13 01:19 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Two wheel drive has five 1/2x20 studs in a 4 1/2" bolt circle. The 4x4 has 1/2 studs too but five in a 5 1/2 " circle....they eat gas pretty well. I suppose a two wheel drive might get near 20 mpg on highway only.
Re: Lug pattern size [Re: cdstl] #1542980
12/03/13 09:00 AM
12/03/13 09:00 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Thanks for the posts. I was hoping for a little better mileage but I guess with the rearend gearing that it probably has, I should have known. A car would probably be easier on gas.
Re: Lug pattern size [Re: cdstl] #1542981
12/03/13 12:07 PM
12/03/13 12:07 PM
dogdays Offline
dogdays  Offline
It's not the rearend gearing as much as the weight of the vehicle.
Put that slant six in a Valiant and it'll get much better mileage than in a 2-ton pickup truck.
On the other hand a pickup is a lot handier.....
R.
Re: Lug pattern size [Re: cdstl] #1542982
12/03/13 12:07 PM
12/03/13 12:07 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
72-84 2wd 5x4.5"
85+ 2wd 5x5.5"
72-74 4wd 5x5.5"
75-79 4wd 5x4.5"
80+ 4wd 5x5.5"
This should be in the arcives with the axle ID
