Page 1 of 8 1 2 3 4 5 6 7 8
5" bore space Mopar blocks #1542679
12/02/13 07:12 PM
12/02/13 07:12 PM
Delray beach, Florida
P
Performance Only Offline OP
P
If they were available, how many on here would consider using one. Naturally there would be heads, etc. to go with them.
I'm really curious if your answer is no, what the reason would be.
Naturally any engine combo like that wouldn't be cheap, so I realize that probably eliminates 98% of the people on Moparts.
Obviously nothing would be made by Mopar that would bolt on, but if you were looking for big power is that really a concern?
Of course I would want one
single choice
Votes accepted starting: 12/02/13 06:11 PM
You must vote before you can view the results of this poll.
Nope, I need 906 heads
single choice
maybe, if the price was right
single choice
No, it wouldn't be Mopar
single choice
machine shop owner and engine builder
Re: 5" bore space Mopar blocks [Re: Performance Only] #1542680
12/02/13 07:22 PM
12/02/13 07:22 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
I have a question, do you currently have some cylinder head prototypes in the works or is this just a interest gauge?
Adriel Paradise
Substation Design Engineer III
Re: 5" bore space Mopar blocks [Re: Performance Only] #1542681
12/02/13 07:28 PM
12/02/13 07:28 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... Naturally any engine combo like that wouldn't be cheap, so I realize that probably eliminates 98% of the people on Moparts.
I just looked over the survey... you can revise that to 99.5% by the time you eliminate the "906 heads" and "must have Mopar parts" contingent.
And I'm not even going to respond the survey 'cuz I KNOW I'm not the target audience. It's taken me this long just to consider running heads that require offset intake rockers and switching to a solid roller on the street.
Re: 5" bore space Mopar blocks [Re: BradH] #1542682
12/02/13 07:43 PM
12/02/13 07:43 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
this is my opinion. from what I see, the guys that really spend money don't even have jobs. those same guys are taking out their 632 big chief chevys and building small blocks. everyone wants to say they run a small block because a big block in most people eyes can be a 800 cube motor.
small block small tire shootouts are the most popular races I see where I'm at.
with that being said, what is the bore spacing of a gen 3 hemi and how big can it go
Re: 5" bore space Mopar blocks [Re: sixpackgut] #1542683
12/02/13 07:54 PM
12/02/13 07:54 PM
Q
Quicktree Offline
Quicktree  Offline
Q
i'll stick with my SB unless i hit the lotto
Re: 5" bore space Mopar blocks [Re: sixpackgut] #1542684
12/02/13 08:05 PM
12/02/13 08:05 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Dan,I'am sure some will have an interest like the guys that go for the big Sonny's,Kasse's,Fulton and other exotic engines but the market would be limited to those with highend budgets.The more basic type of engine has a larger market.Lose of one or two small budget bracket customers and a business can survive,lose of one or two large budget customers can and will certainly effect your bottom line.After all it's not just a 5" bore space block its everything that goes with it that will drive the cost to where only a few will can play.
Re: 5" bore space Mopar blocks [Re: Performance Only] #1542685
12/02/13 08:13 PM
12/02/13 08:13 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I have been trying to talk David into making a 5.0" Hemi block/head combo.
Re: 5" bore space Mopar blocks [Re: Performance Only] #1542686
12/02/13 10:07 PM
12/02/13 10:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont have any concern for the big block stuff anymore
and with all of the special parts I couldnt afford it
Re: 5" bore space Mopar blocks [Re: MR_P_BODY] #1542687
12/03/13 12:20 AM
12/03/13 12:20 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
If i had Bob George's money i'd build 1. I'm like Mr.P, sb. My car is fast enough.
Re: 5" bore space Mopar blocks [Re: rickraw] #1542688
12/03/13 12:37 AM
12/03/13 12:37 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Although I would love to see it. I dont see myself ever needing or affording anything that exotic. I am a bracket racer and my Aluminum block and heads 540 may be as exotic as I can ever afford! More power to ya though!
Re: 5" bore space Mopar blocks [Re: cl440] #1542689
12/03/13 02:46 AM
12/03/13 02:46 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
The dry, sarcastic post and poll questions cracked me up; I LOL’d…
Re: 5" bore space Mopar blocks [Re: 64Post] #1542690
12/03/13 10:43 AM
12/03/13 10:43 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I would love to have one, depending on cyl. head choices.
Re: 5" bore space Mopar blocks [Re: camastomcat] #1542691
12/03/13 12:48 PM
12/03/13 12:48 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I personally think our engines are too big and powerful now. It's hard to hook them up if the track is marginal. 800 horsepower works good and is obtainable with a pump gas Hemi. But since you want to talk about it...
It could be done by the right man. We know what we want. Externally it would look like a 426 Hemi, but it would be wider bore spacing and taller decks. The valve gear and ports would look like what Kaase and Sonny sell now.
Kaase and Sonny have done all the R&D for us already. We are not trying to reinvent the wheel. Just set a 426 Hemi block and a Sonny's 5" Hemi on the bench and morph them.
It would be nice if Chrysler would get involved but that's probably not going to happen.
50 years ago Lynn Townsend walked out of his office and told his engineers "build the Hemi" and changed our lives forever. 40 years ago Keith Black built the aluminum Hemi. Now would be a good time for another man with vision to step up.
It wouldn't have to be for the money but it did make Keith Black and Sonny rich.
It would be for the dream. Just like 130 years ago when Karl Benz invented the small engine which made possible the automobile. You have to have a man of vision and work ethic to get anything done.
2011 Drag Pak Challenger
Re: 5" bore space Mopar blocks [Re: camastomcat] #1542692
12/03/13 01:17 PM
12/03/13 01:17 PM
gregsdart Offline
gregsdart  Offline
Funny! I want the whole motor for $5500, 1500 hp, low mantenance
Seriously, a look at how many B1TS motors have been built ought to shed light on the market out there. If the power potential was up there like the BBC stuff, and the cost was reasonable (on par), then MAYBE the Mopar deal might sell some. But not being able to use a lot of stock based stuff (different crank, intakes, heads,water pump type, etc) ) will narrow the market to the point I doubt that it could be priced competitively.
Re: 5" bore space Mopar blocks [Re: rickseeman] #1542693
12/03/13 01:26 PM
12/03/13 01:26 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I don't know for shue but didn't Indy build a wider bore block and special head for a wedge about 10-15 years ago? 4.90 if I remember right. Anyway the BBC crank and alot of other small parts could be used to keep the cost down.
Re: 5" bore space Mopar blocks [Re: gregsdart] #1542694
12/03/13 01:30 PM
12/03/13 01:30 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Seriously, a look at how many B1TS motors have been built ought to shed light on the market out there. If the power potential was up there like the BBC stuff, and the cost was reasonable (on par), then MAYBE the Mopar deal might sell some. But not being able to use a lot of stock based stuff (different crank, intakes, heads,water pump type, etc) ) will narrow the market to the point I doubt that it could be priced competitively. [/quote
You beat me to the stripe
Re: 5" bore space Mopar blocks [Re: Performance Only] #1542695
12/03/13 01:44 PM
12/03/13 01:44 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Will I be able to use my new 60mm roller Purpleshaft .509 cam????
RIP Monte Smith
Re: 5" bore space Mopar blocks [Re: cudaman1969] #1542696
12/03/13 01:47 PM
12/03/13 01:47 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
I wish I had the means. I've got a pretty decent mental capacity to design some things. If I had the means, I would sell the block associated parts at cost with maybe a $50-100 profit margin because I personally would rather flood the market with outstanding mopar based parts than make a profit. But for me, it would be a side project and for most, they are trying make a living off of it. I'm built different in that way. I just wish we had more crazy mopar fanatics willing to throw money at a development project like this. When Mike Moran built and designed his new 5.3 BS turbo hemi motor, I have to believe he was just building something he thought would be cool because I doubt he will turn a major profit with it being that the market audience is so small. He just wanted to advance turbo technology. I say why not advance Mopars as well.
Adriel Paradise
Re: 5" bore space Mopar blocks [Re: cudaman1969] #1542697
12/03/13 01:49 PM
12/03/13 01:49 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Guess my question is whats the point? There are already plenty of 5" and 5.3" bore space stuff out there on the market. They are not Ford or Chevy so why try and make something and call it Mopar? Those 5 and 5.3BS engines are purpose built race pieces period. If someone wants to step up to that level there are options out there now.
Re: 5" bore space Mopar blocks [Re: Al_Alguire] #1542698
12/03/13 02:37 PM
12/03/13 02:37 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Why would someone want to build another one of these, just to call it a Mopar? It costs a ton o money in head research and configuration and then you have to sell them. Indy has a 4.84 bore center block for the 600-13 head, but that head doesn't get it done like a predator would. Although, who could blame them for not spending the money to do it? Besides, people would say it's not a Mopar anyway.......buy a "purpose built race motor" if you want more power, period.
