Re: 5" bore space Mopar blocks
[Re: Monte_Smith]
#1542759
12/05/13 07:39 PM
12/05/13 07:39 PM
Posts: 573 PA
68CudaB1
PA
Heck, Best Machine had trouble selling the 5 pairs of B1 PSO heads they did, I don't see the demand for a 5" block.
Because at the end of the day, those heads STILL bolt on a bore limited, 4.800 bore space block. If that head was cast in a 4.840 to bolt on the Indy or other 4.840 block, THEN you would have something.
Monte
The Predator heads fit your scenario? My point is Mopar people will not spend the $$$.......
[Re: 68CudaB1]
#1542760
12/05/13 08:05 PM
12/05/13 08:05 PM
Posts: 8,282 fredericksburg,va
cudaman1969
fredericksburg,va
Monte
You are right I would NEVER buy one with a bbchevy head on it. Hemi head or no head, Mopar or no car. Guess we could like a certain wheelstander car did, had a chevy engine with hemi valve covers bolted over the chevy covers and fake plug wires. Said he couldn't afford the hemi
[Re: pittsburghracer]
#1542762
12/05/13 08:28 PM
12/05/13 08:28 PM
Posts: 3,395 Pa
Hot 340
Pa
Some of you guys try to make it sound so easy to spend 10's of thousands of dollars on racing. Most of us as racers own our cars, do as much work on them as we can to save a buck, and go racing. We are not like dirt track racers and have teams helping financially like they do. My local dirt track (Lernerville) consists mostly of teams, people that never drive the car, and many never touch the car, but they pay to be part of "the team". Look at MY CAR out there going laps. Drag racing at the local level is not like that. We have a wife and house, and kids that hopefully come first. We are not cheap racers, we are budget racers. But we do race.
Great post, and my thoughts exactly when I posted earlier. It gets irritating when some of us who are not wealthy but NOT cheapskates without desire for innovaton either, get thrown in with the op's "98 percent".
[Re: 68CudaB1]
#1542763
12/05/13 08:28 PM
12/05/13 08:28 PM
Posts: 19,369 Las Vegas
Al_Alguire
Las Vegas
Monte kinda got to the point I was trying to make. What exactly are you going to do that will make it as "mopar". And as already alluded to they do already exist from CN...If you are willing to fork over $9200-10000+
[Re: camastomcat]
#1542766
12/05/13 08:39 PM
12/05/13 08:39 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
There are a lot of valid points in this thread.
IMO there already is a Mopar 5.0 and 5.3" bore space block out there. Just because you are used to seeing it in Chevies does not make it a GM engine. If someone made a one piece oil pan spacer cap arrangement with cross bolts main caps would that make you think it is a mopar? How about if they made it fit a mopar bell housing? Do you hear the chevy guys complaining about their shaft rockers or gear rotors in their dry sump pumps complain? In any of these purpose designed and built engines there are a lot of ideas robbed from all three of the big American manufacturers. It just seems the Chevy guys are more interested in going fast and not about whether or not they can buy their valve cover gaskets at the local auto parts store.
Leon
[Re: PETE@BESTMACHINE]
#1542768
12/06/13 02:50 AM
12/06/13 02:50 AM
Posts: 1,106 Quebec, Canada
Diablo
Quebec, Canada
I consider this a very good 5" bore space engine at that cubic inch. It has the 99 hemi heads and as been as quick as 6.61 210.50 at 2300 lbs. How many people are willing to run something that makes peak power that high? That is the nature of the beast with that kind of power. I wish we had a current parts like those today.
And what cubic inch would this be at?
[Re: Al_Alguire]
#1542770
12/06/13 01:04 PM
12/06/13 01:04 PM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
Maybe I am naive so help me out a little here. What is going to make this new venture at 5, or 5.3" bore space motor a "Mopar", the bellhousing pattern? Someone wanting to put a TF behind a 5" bore space motor out there? Sounds to me more like you are considering developing a new 5/5.3 BS engine platform?!? So I ask again what makes it a Mopar? Maybe I am just missing the point here.
I don't get it either. What market is this going after???? I see that your saying you have no interest in using already cast heads. If it doesn't matter that it looks like a mopar engine. If it is a complete one off, and it doesn't bolt up to mopar mounts or accessorries how is different than any other big inch IHRA type pro stock motor. Just like a Sonnys motor has almost no commonality to a BBC it sounds like this motor will have no commonality to a mopar. Its already clear that a large portion of the mopar crowd doesn't need a motor a like that. I would be willing to bet its because most people don't need something with that level of performance. If your intent is to a build a one off motor that has no resemblence to existing mopar platforms and is not liscensed by mopar, why target a mostly hobbiest level brand loyal website. Sounds like you need to take the mystery engine to PRI and put it up next to Sonnys or other high end builders. Go after the high end crowd that isn't focused on brand loyalty racing. But that isn't going to be an easy feat to jump in the big leagues with them and compete. I wish you luck with whatever your thinking of building.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: MR_P_BODY]
#1542774
12/06/13 02:20 PM
12/06/13 02:20 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Mr_P,Pittsburghracer,the 2 of you have been running Mopars long enough to know as long as I have run them I have to be a True Mopar person and too Hard Headed to do anything the easy way. I not only think us Mopar Racers need a 5.0 block but I would buy one even if it were 1-1/2 times higher than the Brand XXX just so I could call it a Mopar. And thats what this post is about to get opinions and it does not anger me like it seems to do others who have different opinions.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#1542775
12/06/13 02:47 PM
12/06/13 02:47 PM
Posts: 20,180 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Hey my Keith Black block says MOPAR on it. I truly wish Dan all the luck in the world with this project. I know Dan and had some great dealings with him. To see his shop grow over the years thru some really bad years tells us all he can do what it takes to become successful. Just look around and see how many shops have closed over the late 10 years. Hard work and many sleepless nights is what it takes at times and they do what it takes. I'm a bracket racer because that's all I can afford to do as it is for many others. Some of the issues these aftermarket blocks have drive guys away from the sport.
[Re: MRMOPAR622]
#1542776
12/06/13 03:03 PM
12/06/13 03:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I've been racing a Mopar from the FIRST time I was ever on the track.... at first I worked for GM in their labs and owned a 62 Dart.. after I got out of the service I didnt want to go back to GM so I hired into Chrysler in their labs... they gave me a pay check for 35 years and payed my retirement... so yes I am VERY brand loyal... and all we own are mopars for all of our daily drivers... will I ever own a 5.0+ bore spacing block... I really doubt it, only due to I cant race faster than 10.0 now days and with my lighter cars it doesnt take much HP to get there.. I understand that Dan is just looking but all the best to him IF he decided to jump
[Re: Performance Only]
#1542777
12/06/13 04:55 PM
12/06/13 04:55 PM
Posts: 2,091 Delray beach, Florida
Performance Only
First of all, Let me say thank you to everyone for sharing your thoughts, opinions etc. regardless if they were positive or negative in nature. Anyone with any sense knows that what I'm planning is a narrow market but also a very competitive market. It's not something that's going to drive me to the poor house or put me out of business like some might think or suggest. If everyone was content through the years with what was currently available at the time, we wouldn't have half the products or technology we have today. As far as I'm concerned there isn't anything made today that can't be improved upon tomorrow.
machine shop owner and engine builder
[Re: cudaman1969]
#1542778
12/06/13 06:27 PM
12/06/13 06:27 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Monte
And there you go.......Too much of THIS attitude among Mopar guys, is the reason we don't have cutting edge parts. You are going to have to explain to me how a Predator is a BB Chevy head. Last time I checked, they bolted on a 4.800 bore space Mopar block and NOTHING else, plus they are a spread port head. Show me ONE BB Chevy that EVER came from the factory with a spread port head.
Monte
