What are these lower control arms off of? swaybar tabs. #1541848
11/30/13 06:35 PM
11/30/13 06:35 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
trying to figure out what these lower control arms will fit. Thought these was 1972 b-body?
Re: What are these lower control arms of off? [Re: migsBIG] #1541849
11/30/13 06:36 PM
11/30/13 06:36 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
2
Re: What are these lower control arms of off? [Re: migsBIG] #1541850
11/30/13 06:37 PM
11/30/13 06:37 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
3
Re: What are these lower control arms of off? [Re: migsBIG] #1541851
11/30/13 06:51 PM
11/30/13 06:51 PM
Rancho Cordova, California (Sa...
hemi71x Online content
hemi71x  Online Content
First, look to see if you can see any letters stamped in the front of the LCA.
If you see letters RW, then your LCA's are 70-72 B Body and 70-74 E Body. (all the same)
If you see letters VL, then they are 73-76 A Body LCA's.
(To me they look like B & E Body LCA's, by looking at the pivot shaft diameter)
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: What are these lower control arms off of? swaybar tabs. [Re: migsBIG] #1541852
11/30/13 07:44 PM
11/30/13 07:44 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
What are you going to do with them?
Re: What are these lower control arms off of? swaybar tabs. [Re: 71birdJ68] #1541853
11/30/13 08:11 PM
11/30/13 08:11 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
I sold them to a guy, but said they 1/2 inch too short to fit his 1972 roadrunner.
Re: What are these lower control arms off of? swaybar tabs. [Re: migsBIG] #1541854
11/30/13 08:14 PM
11/30/13 08:14 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Pins look like A-body... Have him check the stampings for body style.
Re: What are these lower control arms off of? swaybar tabs. [Re: migsBIG] #1541855
11/30/13 08:17 PM
11/30/13 08:17 PM
Then they are A body LCA's. "Shafts" are different between the body styles.
Like i stated, look for the letters on the LCA's
Re: What are these lower control arms off of? swaybar tabs. [Re: Jim_Lusk] #1541856
11/30/13 08:22 PM
11/30/13 08:22 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
ok, i'll have the guy verify what the stampings are. Weird, I pulled those off the 72' charger myself, wonder if the previous owner changed them out?
Re: What are these lower control arms off of? swaybar tabs. [Re: migsBIG] #1541857
11/30/13 08:29 PM
11/30/13 08:29 PM
They don't interchange unless someone physically changes the shafts, or pins, (whatever one personally calls them) between the two body style LCA's.
Re: What are these lower control arms off of? swaybar tabs. [Re: hemi71x] #1541858
11/30/13 10:03 PM
11/30/13 10:03 PM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
If im not mistaken the A body pieces are longer than the B body. Some thing is not adding up here.
Re: What are these lower control arms off of? swaybar tabs. [Re: mod5v] #1541859
11/30/13 10:31 PM
11/30/13 10:31 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The B body LCAs are curved along the bottom edge. ALL A body LCAs have a flat section as shown on those arms. Visual ID is the quickest way to tell compared to lookin at part #s that could be under rust or grease.
I'm surprised that Jim didn't know that. He is usually pretty sharp on the suspension stuff.
Re: What are these lower control arms off of? swaybar tabs. [Re: Kern Dog] #1541860
11/30/13 11:22 PM
11/30/13 11:22 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
73-76 a body.
Re: What are these lower control arms off of? swaybar tabs. [Re: mcmopars] #1541861
12/01/13 01:18 AM
12/01/13 01:18 AM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Dang, don't know how these got switched around. Looks like 73+ a-body then, somehow got mixed up. Looks like I'm going to have to refund the guy or make it right with him.
Thanks for the info everybody.
Re: What are these lower control arms off of? swaybar tabs. [Re: migsBIG] #1541862
12/01/13 09:53 AM
12/01/13 09:53 AM
indiana
mcmopars Offline
mcmopars  Offline
indiana
how would a body arms fit b body?if you pulled them off?
Re: What are these lower control arms off of? swaybar tabs. [Re: mcmopars] #1541863
12/01/13 03:31 PM
12/01/13 03:31 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
The mounting shafts are different, but the LCA bushings are the same. You can theoretically swap a few parts around to fit a B arm in an A car or vice versa. The A arms ARE 1/2" longer from ball joint to the pivot shaft. It is possible to put A body arms in a 62-72 B car to get much more negative camber for circle track racing. The strut rod location is very close. The sway bar tabs closely resemble 70-72 B arms.
Re: What are these lower control arms off of? swaybar tabs. [Re: migsBIG] #1541864
12/01/13 04:39 PM
12/01/13 04:39 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Is it possible he has a late '72 calender year that is actually a '73 that has an entirely different arm? Like these: https://board.moparts.org/ubbthreads/show...e=0#Post7941221
Re: What are these lower control arms off of? swaybar tabs. [Re: TC@HP2] #1541865
12/01/13 04:42 PM
12/01/13 04:42 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
That is not a 73 B body arm!
Re: What are these lower control arms off of? swaybar tabs. [Re: MPerry] #1541866
12/01/13 04:44 PM
12/01/13 04:44 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I know that, but does migBIG's buyer know that? They appear to be 73-76 a body arms, which are longer than the pre '73 B body arms, yet still to short for the dude who wants to buy them. I suspect that guy may have '73 arms.
Re: What are these lower control arms off of? swaybar tabs. [Re: TC@HP2] #1541867
12/01/13 04:46 PM
12/01/13 04:46 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Well he would have to be pretty oblivious to think he has a 72 with an isolated k member.
