Re: Did a Front Steer Rack Conversion on my Road Runner [Re: STEFF] #1541279
11/29/13 01:18 PM
11/29/13 01:18 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Critical comments......Fire away.....I'm cool with it.
I would add a few pieces of tubing to help support the part that the LCA goes in, It will certainly move around when it's stressed like wheel stands or hard braking.
Something like this will help
Re: Did a Front Steer Rack Conversion on my Road Runner [Re: SB412DUSTER] #1541280
11/30/13 11:59 AM
11/30/13 11:59 AM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
No torsion bars? what holds the back of the lcr in?
thanks
Re: Did a Front Steer Rack Conversion on my Road Runner [Re: Blown61] #1541281
11/30/13 12:12 PM
11/30/13 12:12 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Dude I don't mean to be rude but that's just flat out dangerous and should never be on the road( or track) Your going to kill yourself and/or someone else.
I understand your intent and desire and I applaud that but for starters that "steering arm" WILL fail and with catastrophic consequences. The "k-frame will flex and bend and break in short order too. Not to mention how it will steer even if it didn't break. PLEASE PLEASE PLEASE find someone with a lot of experience to help you with this before something very horrific happens.
Again your best interests are at heart here, not trying to rain on your parade or insult you in any way.
Re: Did a Front Steer Rack Conversion on my Road Runner [Re: Blown61] #1541282
11/30/13 12:14 PM
11/30/13 12:14 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Looks alittle weak to me. Remember that the steerig arms/ball joints from the factory was made of forged steel.
Also the stock k-member have alot of flex going on and i cant see you made it better.
I always try to think triangulate when i fab stuff.
Need to think 3 dim.
Just my two cent.
Re: Did a Front Steer Rack Conversion on my Road Runner [Re: Blown61] #1541283
11/30/13 02:25 PM
11/30/13 02:25 PM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
thanks
Torsion Bars will be used. They just aren't in, in the pic. I will go to coilovers once I get some front struts in from the cage.
Re: Did a Front Steer Rack Conversion on my Road Runner [Re: brads70] #1541284
11/30/13 02:40 PM
11/30/13 02:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
DAMN... some of you thing you have to have a 2" square
piece of cast to get the tires to turn... you sure
wouldnt like mine
Re: Did a Front Steer Rack Conversion on my Road Runner [Re: brads70] #1541285
11/30/13 03:12 PM
11/30/13 03:12 PM
STEFF Offline OP
STEFF  Offline OP
Dude I don't mean to be rude but that's just fmmlat out dangerous and should never be on the road( or track) Your going to kill yourself and/or someone else.
Those steering arms are for mock-up and getting bumpsteer and ackerman figured out. Once finalized. A more robust arm will be made.
The k-frame does NOT support the motor. I have a motor plate. I'm going to add an additional rib like SB412duster posted. But, other than that, it'll be plenty strong. It's really no different than someone cutting the center out for oil pan access.
I did plenty of research looking at many different frames, for mopars and many other makes as well. There isn't as much steel in them as you'd think.
Thanx for the input and crtiques.
I appreciate the input and crtiques.
Re: Did a Front Steer Rack Conversion on my Road Runner [Re: STEFF] #1541286
11/30/13 04:36 PM
11/30/13 04:36 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Really awesome job, very impressed....Along with your Drag Week completion with a new engine...
Re: Did a Front Steer Rack Conversion on my Road Runner [Re: Dragula] #1541287
11/30/13 10:36 PM
11/30/13 10:36 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Apparently most of you guy's have never looked at a strut steering system, 1/4" flat plate bolted on with 2 - 3/8 bolts. Never heard of one breaking.
Re: Did a Front Steer Rack Conversion on my Road Runner [Re: STEFF] #1541288
11/30/13 10:39 PM
11/30/13 10:39 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I believe when using TB's, the K sees the weight from the motor, whether is on mounts or plate, but when going to coil overs, the k only sees the motor when on mounts, although on coilovers it does see a small %, depending motion ratio stuff.
Re: Did a Front Steer Rack Conversion on my Road Runner [Re: STEFF] #1541289
12/01/13 12:57 AM
12/01/13 12:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Steff... on that PM.... strut rods also
Re: Did a Front Steer Rack Conversion on my Road Runner [Re: STEFF] #1541290
12/01/13 11:10 AM
12/01/13 11:10 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Ok I'm not trying to stir the pot, but here is my two cents. Tried to explain it in the simplest way possible.
First, remember the old saying. "Every action has an equal and opposite reaction".
When the car brakes, nose dives, comes of a wheelie, etc... here is part of what happens.
First look at Figure "A" in the top left corner.
This is a section through the frame rail and rear attachment point of the K-member. Force #1 represents the weight of the car pushing down in the frame rail. Force #2 represents the force from the lower control arm holding the car up. In principal, this is what keeps the car "Up". You can see that these forces are not in line. What this means is that there will be a "twisting" of the frame rail.
Now look at Figure "B" at the bottom.
You can see the same Force #1 and Force #2. This results in the "twisting" that I was trying to simply explain in Figure A. The twisting is shown as Force #3.
So what counter acts the twisting of Force #3? It's safe to assume that most of Force #1 is also distributed through the front portion of the untouched K-frame. It is much larger/stronger then the rear square tube that was added.
As Force #3 twists up, it creates a Force #4 on the square tube. Force #4 and Force #1 (on the front of the K-Frame) are now "fighting" eachother to keep the car up. This is what normally happens with a stock K-frame.
But what you can envision, is that there is a huge mismatch of strength between the old front box section of the K-frame, and the new 1" square tube that has been added. The new square tube is clearly not as strong as the old boxed K-frame section.
To make things worse, the holes that are drilled for rack attachment bolts, is right through the worst part of the load path in the small square tube.
If Force #1 is hard enough, it will try to bend/break the new square tube because of the translated Force #4. This will most likely occur right at the rear hole that was drilled for fastener access to the rack attachment.
If it were mine, I would cut the square tubes off, replace with adequate size round tube, and weld tabs off the round tube to attach the rack. That way the tube is not compromised because of the rack attachment hole.
Just my opinion....but something to think about.
Re: Did a Front Steer Rack Conversion on my Road Runner [Re: dizuster] #1541291
12/01/13 11:40 AM
12/01/13 11:40 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Good work Steve. I think, given the time and materials, you could/would build a functioning space shuttle. I really like the explaination given by Scott too. I thought I had some 1 1/4" .134 mild steel tube,... I DON'T. Anyway, it's good to see these ideas materialize. Hope to see you over the holidays.
Re: Did a Front Steer Rack Conversion on my Road Runner [Re: dizuster] #1541292
12/01/13 01:06 PM
12/01/13 01:06 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I agree the added square tubing is imo also a problem area, the stress concentration on the mid angle welded joint is going to be rather high, and competing with the thru bolts for weakest area. I think it can be reinforced, or upgraded with a replacement, without starting over. I would not automatically suggest round tubing, as it's greatest strength attribute compared to equally sized square? tubing is torsional strength, and not sure that is a big concern on this support piece.
However the Op's point on the many over the years rather cut-up/butchered drag race k's for oil pan clearance makes for a rather compelling argument, although street/road vs drag are two different animals.
Re: Did a Front Steer Rack Conversion on my Road Runner [Re: STEFF] #1541293
12/01/13 02:37 PM
12/01/13 02:37 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Steff I have been watching this thread and can relate, I'm in the middle of a K-member project myself for me and a couple of buddies a-body cars.
I would suggest you buy a caster camber gauge (if you don't have one) and set the caster/camber before you spend too much time on the bump steer and shape of the steering arms. It will make a difference, when you move the top of the spindle back it will raise the steering arm and vice versa.
"Just a Bracket car dressed up like a streetcar"
Re: Did a Front Steer Rack Conversion on my Road Runner [Re: Just-a-dart] #1541294
12/01/13 03:01 PM
12/01/13 03:01 PM
5th and plum
redmist Offline
redmist  Offline
5th and plum
Looks like it might work, My guess is that the bars where your rack are attached will flex and crack at the K-frame joint.
If it does, you will be moving your rack back and forth instead of your wheels.
Be careful.
Re: Did a Front Steer Rack Conversion on my Road Runner [Re: redmist] #1541295
12/01/13 10:51 PM
12/01/13 10:51 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I also built a K member with a rack for my Roadrunner.
69 GTX 68 Road Runner
Re: Did a Front Steer Rack Conversion on my Road Runner [Re: redmist] #1541296
12/01/13 10:59 PM
12/01/13 10:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Be careful.
On My Rampage with the wider tires I have learned
that I dont turn the wheel at a dead stand still..
I am always rolling to turn the tires be it slow or
what not I dont like putting all the pressure on the
rack itself... I feel they arent all that strong
Re: Did a Front Steer Rack Conversion on my Road Runner [Re: STEFF] #1541297
12/02/13 04:11 PM
12/02/13 04:11 PM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
...nice
