TRICKS AND METHODS ON DYEING INTERIOR #154084
11/20/08 01:25 PM
11/20/08 01:25 PM
Amherst
P
plumcrzyTA Offline OP
P
Amherst
On my T/A I have a white vinyl interior.It is in good shape but it could be whiter.What would be the best dye and method to do it?
THANKS!!!David
Re: TRICKS AND METHODS ON DYEING INTERIOR [Re: plumcrzyTA] #154085
11/20/08 01:49 PM
11/20/08 01:49 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Eastwoods sells all kinds of that stuff. Did my Charger interior yeasr ago and it's held up fine.
Re: TRICKS AND METHODS ON DYEING INTERIOR [Re: bobby66] #154086
11/20/08 02:21 PM
11/20/08 02:21 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Be fore you start dyeing stuff go get a box of Mr Clean Magic Erasers & try scrubbing it with that...It does a pretty amazing job...If it doesn't get things clean enough to satisfy you at least it's a good preperation step for dyeing...The problems with dyeing are 1)loss of grain pattern 2)it sometimes peels if the surface wasn't clean enough or the dye was of questionable quality 3)once you've dyed the part you really can't completely remove it....
If you decide to dye SEM & Mar-Hyde both give good results but over time it will fade & then you'll want to do another lap with the dye so refer back to "The problems with dyeing"...
Re: TRICKS AND METHODS ON DYEING INTERIOR [Re: 1_WILD_RT] #154087
11/20/08 02:37 PM
11/20/08 02:37 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
clean everything with rubbing alcohol before you spray.
Re: TRICKS AND METHODS ON DYEING INTERIOR [Re: plumcrzyTA] #154088
11/20/08 03:04 PM
11/20/08 03:04 PM
pittsburgh,Pa.
mikepar Offline
mikepar  Offline
pittsburgh,Pa.
something that works real good and is cheap as the day is long-----Wesleys Bleach White...yah thats right, tire cleaner.scrub with a stiff brush.Works beatiful on fadded paint also, We're ghetto here,ya know.
Re: TRICKS AND METHODS ON DYEING INTERIOR [Re: mikepar] #154089
12/01/08 04:46 PM
12/01/08 04:46 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Since this is a semi-fresh thread I'll piggyback.
Any tips on removing dye/paint from the dash pads? It's been painted once and it's peeling to beat the band so I need to re-do it.
Just scrub scrub scrub? Would alcohol kill it? Not the hard plastic, the squishy lower dash pad.
This car's killin' me here.
I can't afford this. mark
Re: TRICKS AND METHODS ON DYEING INTERIOR [Re: mikepar] #154090
12/01/08 05:03 PM
12/01/08 05:03 PM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
Yea, what he said!!! I have a white interior and was surprised of the job it did.
Re: TRICKS AND METHODS ON DYEING INTERIOR [Re: stubbs300 ] #154091
12/02/08 06:41 AM
12/02/08 06:41 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Sweet, I'll pick some up.
Re: TRICKS AND METHODS ON DYEING INTERIOR [Re: a12superbee] #154092
12/02/08 09:07 PM
12/02/08 09:07 PM
Indianapolis
Waveraider Offline
Waveraider  Offline
Indianapolis
I used the SEM product and was pleased with the results. I went from green to black. SEM also sells a special cleaning soap and adhesion promoter that you need to buy One can/bottle of each will do your car. The die will take several cans.
