Page 1 of 4 1 2 3 4
Looking for Pictures of NHRA legal Roll Cages E body #1540604
11/27/13 05:51 PM
11/27/13 05:51 PM
Mohnton, Pa
DodgeCharger Offline OP
Mohnton, Pa
I have a street car that is a cruiser and I don't want to destroy the car for street use or damage the interior. The problem is with an E body dash pad every cage I see they cut through the dash for the front bars. Does anyone have an alternative way to build the cage?
Re: Looking for Pictures of NHRA legal Roll Cages E body [Re: DodgeCharger] #1540605
11/27/13 06:17 PM
11/27/13 06:17 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The problem with the E-body is the dash protrudes so far back that if the down pillers are placed to clear the dash it limits the room to enter and exit the car.We have done a few similar with out cutting into the dash and use swing out bars and compound angles at the piller bar for easier access.The front bars can be attached to piller bars at a lower position,angled upward and leveled off passing through the firewall to the frame attaching points.The front bars are not part of the cage requirements but certainly help structuraly on a SS or car that likes to wheelstand.Don't confuse the upright(piller bars)which is a mandatory part of the cage with front bars that go to the front frame rails.
Re: Looking for Pictures of NHRA legal Roll Cages E body [Re: DodgeCharger] #1540606
11/27/13 06:20 PM
11/27/13 06:20 PM
Mo.
racerx Offline
racerx  Offline
Mo.
I'v ask this ?many times with the e-bodys do a search on (coming to a strip near you 25.5) and take a look at how he did his front hailo on his chally that's the way i'm in the process of doing mine...............
Re: Looking for Pictures of NHRA legal Roll Cages E body [Re: racerx] #1540607
11/27/13 06:54 PM
11/27/13 06:54 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
the next worst part of an ebody is the door bar goes right between the door handle and window crank
Re: Looking for Pictures of NHRA legal Roll Cages E body [Re: sixpackgut] #1540608
11/27/13 07:03 PM
11/27/13 07:03 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
With a good plan and a string line you can drop the side bar to the floor pan early to clear those items,but you must tie it to the piller bar with a tube angled upward.If your using a swing out bar you can bend a radius in the down bar at the front to clear them also.
Re: Looking for Pictures of NHRA legal Roll Cages E body [Re: B G Racing] #1540609
11/27/13 07:07 PM
11/27/13 07:07 PM
Q
Quicktree Offline
Quicktree  Offline
Q
here is mine, probably not as strong as a straight bar.
Re: Looking for Pictures of NHRA legal Roll Cages E body [Re: Quicktree] #1540610
11/27/13 07:11 PM
11/27/13 07:11 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I didn't build this cage and I think with a little work it could be made straight and a little closer to the dash. I would have just went through the dash for a nice clean fit.
Re: Looking for Pictures of NHRA legal Roll Cages E body [Re: racerx] #1540611
11/27/13 07:19 PM
11/27/13 07:19 PM
Mohnton, Pa
Mohnton, Pa
Thanks for all the responses. I did the search for the 25.5. I seen all I needed to see. I'm not going to do that to my car. I guess if I want to go faster I will have to build a 2nd car. I was hoping the NHRA would lower the roll cage requirement since many street cars today are runing faster than 9.99. It's safer to run these cars at the track than it is to run them on the street.
Back in the day you needed a roll bar at 11.99 then they changed it to 11.49 et. It's safer to run a car at 140 mph with a 5 point harness and roll bar than these guys running 120+ with a factory lap belt and no bar.
Re: Looking for Pictures of NHRA legal Roll Cages E body [Re: DodgeCharger] #1540612
11/27/13 08:41 PM
11/27/13 08:41 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
that was my conclusion also. I sold the e body and don't miss it at all
Re: Looking for Pictures of NHRA legal Roll Cages E body [Re: sixpackgut] #1540613
11/27/13 11:25 PM
11/27/13 11:25 PM
illinois
E
evenflow Offline
evenflow  Offline
E
illinois
i used a S&W roll bar to cage conversion on my cuda. its a little tight by the headlamp switch no difference getting in and out
Re: Looking for Pictures of NHRA legal Roll Cages E body [Re: Quicktree] #1540614
11/27/13 11:26 PM
11/27/13 11:26 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Tree is that a glass dash/plastic?It looks to be aftermarket.
Re: Looking for Pictures of NHRA legal Roll Cages E body [Re: racerx] #1540615
11/28/13 01:11 AM
11/28/13 01:11 AM
Q
Quicktree Offline
Quicktree  Offline
Q
yes it is glass
Re: Looking for Pictures of NHRA legal Roll Cages E body [Re: Quicktree] #1540616
11/28/13 01:56 AM
11/28/13 01:56 AM
campbell river B.C
mopartoby Offline
mopartoby  Offline
campbell river B.C
Where did you get the dash from? Thanks
Re: Looking for Pictures of NHRA legal Roll Cages E body [Re: mopartoby] #1540617
11/28/13 06:37 AM
11/28/13 06:37 AM
Q
Quicktree Offline
Quicktree  Offline
Q
VFN if my memory is right
Re: Looking for Pictures of NHRA legal Roll Cages E body [Re: Quicktree] #1540618
11/28/13 09:26 AM
11/28/13 09:26 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Thax
Re: Looking for Pictures of NHRA legal Roll Cages E body [Re: racerx] #1540619
11/28/13 09:56 AM
11/28/13 09:56 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Thax
Yes VFN make a fiberglass dash. I contemplated swapping out the one on my V-code Cuda and doing the bars right...I am still undecided and still running just mid 10's....If I were to go with a FG dash, it gives you way more flexibility for putting gauges in there...
Re: Looking for Pictures of NHRA legal Roll Cages E body [Re: Dragula] #1540620
11/28/13 10:46 AM
11/28/13 10:46 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Thax
Thats what i'm thinking it gives me a chance to put gauges in the dash and clean it up a bit.....
Re: Looking for Pictures of NHRA legal Roll Cages E body [Re: DodgeCharger] #1540621
11/28/13 11:24 AM
11/28/13 11:24 AM
eastern time zone
Doug Walker Offline
Doug Walker  Offline
eastern time zone
The nicest that I have seen is on a Division 1 car. Unfortunately I do not have any photos of the car with the door open, but these photos may be helpful.
Re: Looking for Pictures of NHRA legal Roll Cages E body [Re: Doug Walker] #1540622
11/28/13 11:25 AM
11/28/13 11:25 AM
eastern time zone
Doug Walker Offline
Doug Walker  Offline
eastern time zone
Photo # 2
Re: Looking for Pictures of NHRA legal Roll Cages E body [Re: Doug Walker] #1540623
11/28/13 11:25 AM
11/28/13 11:25 AM
eastern time zone
Doug Walker Offline
Doug Walker  Offline
eastern time zone
Photo # 3
Page 1 of 4 1 2 3 4
