Re: Big block water pump housing quest?
[Re: 80arrow]
#1539949
11/26/13 02:02 AM
11/26/13 02:02 AM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
I bought a mancini one last spring and had no problems.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: His and Her 69's]
#1539951
11/26/13 09:11 AM
11/26/13 09:11 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Mine is a real old MP piece.Bought it used from a guy for 40 bucks.Been on at least 15 years.Rocky
Chrysler Firepower
[Re: Thumperdart]
#1539955
11/26/13 03:59 PM
11/26/13 03:59 PM
therocks
Niles , Ohio
Thumper the only thing I can think of is mine had plugs.I had to remove them for the heater hoses.They were really in there.A little heat and they came out.I also had to drill and tap for my mechanical gauge sensor.Rocky
Chrysler Firepower
[Re: StealthWedge67]
#1539958
11/26/13 05:43 PM
11/26/13 05:43 PM
Posts: 280 GEORGIA
barracuda7199
GEORGIA
I bought this one last fall. http://www.ebay.com/itm/361440-CHRYSLER-...=item27cdf0ca61 Works great, no issues. Temp definatelystays at the stat more consistently, and drops quicker than it did with the stock unit. I don't know what spending more could have done for me (??).
i would be careful with that pump! i had one that didn't last long bearings went out and let the shaft wobble and ruined my brand new radiator. Also next time you have the housing off run your finger in the bottom right side water port. if you can't fit your finger in it with room to spare like a stock one it is restricting flow! been down that road as well! 440 source crap is what i had!!
[Re: barracuda7199]
#1539959
11/26/13 06:39 PM
11/26/13 06:39 PM
Posts: 5,445 So Cal
Sinitro
So Cal
440Source had a pile of those housings that had the small water flow passages.. They may work fine if one lives in cold Alaska but in SoCal heat they will overheat.. Don't know where they dumped these.. Stay kleer of any bargain ones.. Just my $0.05...
