286 Max Wedge heads...to use or not?
#1539806
11/25/13 04:48 PM
11/25/13 04:48 PM
Posts: 411 Big Island ,VA
JC Childress
Big Island ,VA
I have a Max Wedge clone, that I'm working on. Its 493 ci, and I am on a tight budget. I have a bare set of 286 casting Max Wedge heads and I've heard good and bad things about them. Should I use them or sell them ? Its just a grocery getter but I would like it to run pretty decent. Thanks for any input.
J.C. Childress
(434) 665-9541
Re: 286 Max Wedge heads...to use or not?
[Re: Cab_Burge]
#1539808
11/26/13 12:03 PM
11/26/13 12:03 PM
JC Childress
Big Island ,VA
Its not really about my car hooking up. Its just a street car to ride around in with the wife and kids. Its a 64 Belvedere four door. I'd like to make decent power. The heads have 11/32 valves and have had seats put in the ex. They are milled to 73cc. I also have a stock set of 915 heads but they are bone stock and need everything.
J.C. Childress
(434) 665-9541
[Re: JC Childress]
#1539810
11/26/13 12:45 PM
11/26/13 12:45 PM
dogdays
So it's a stroker, the heads are halfway done. I'd say use'em except for one thing; milled to 73cc. Iron heads, max compression of 9.5:1, calculate the amount needed above the piston:
493 / 8 = 61.6 cubic inches Convert to CC 61.6 X 1000 / 61 = 1010cc
R = 9.5, R-1 = 8.5
Gasket = 12cc
CC / (R-1) = cc above the piston at compression ratio R
1010 / 8.5 = 118.8 cc
118.8 - 73 - 12 = 33.8
You need 33.8cc more in the combustion chamber.
R.
Responding to later post: If 10:1 is fine, then 112.2 above the piston, minus 72 and 12 = 28.2cc needed
You may want to use a D-shaped dish to let the squish work, 10.0:1 is pretty high for a bigblock on pump gas.
[Re: dogdays]
#1539811
11/26/13 01:28 PM
11/26/13 01:28 PM
JC Childress
Big Island ,VA
I can run a dished piston and be fine. 10 to 1 is fine I think
J.C. Childress
(434) 665-9541
[Re: 383man]
#1539815
11/26/13 07:31 PM
11/26/13 07:31 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Look for horizontal cracks on the outside of the heads. They all crack under the two center exhaust ports, above the head bolts.
[Re: Cab_Burge]
#1539817
11/27/13 02:41 PM
11/27/13 02:41 PM
JC Childress
Big Island ,VA
Probably just be better off to sell the Max Wedge heads and buy some 440 Source heads...........
J.C. Childress
(434) 665-9541
[Re: KOS]
#1539820
11/27/13 05:38 PM
11/27/13 05:38 PM
JC Childress
Big Island ,VA
I just had them magnafluxed and they are fine. Still may sell them and get some alum. heads.........debating....
J.C. Childress
(434) 665-9541
