286 Max Wedge heads...to use or not? #1539806
11/25/13 04:48 PM
11/25/13 04:48 PM
Big Island ,VA
JC Childress Offline OP
Big Island ,VA
I have a Max Wedge clone, that I'm working on. Its 493 ci, and I am on a tight budget. I have a bare set of 286 casting Max Wedge heads and I've heard good and bad things about them. Should I use them or sell them ? Its just a grocery getter but I would like it to run pretty decent. Thanks for any input.
J.C. Childress (434) 665-9541
Re: 286 Max Wedge heads...to use or not? [Re: JC Childress] #1539807
11/25/13 11:18 PM
11/25/13 11:18 PM
It depends on the conditions those heads are in and how much power you want out of them. Look closley at the seats to see if the valves will be sunk or not and if thier sunk how bad Also make sure there are absolutely no cracks in them before deciding to use them or not If you really want the most power you can get out of a stroker buy a new set of ported aluminum M.W. castings like the Indy SR, EZ wth teh big ports or the ported 440-1 would be the better choice IMO How much HP can your car hook up now
Re: 286 Max Wedge heads...to use or not? [Re: Cab_Burge] #1539808
11/26/13 12:03 PM
11/26/13 12:03 PM
Big Island ,VA
Big Island ,VA
Its not really about my car hooking up. Its just a street car to ride around in with the wife and kids. Its a 64 Belvedere four door. I'd like to make decent power. The heads have 11/32 valves and have had seats put in the ex. They are milled to 73cc. I also have a stock set of 915 heads but they are bone stock and need everything.
Re: 286 Max Wedge heads...to use or not? [Re: JC Childress] #1539809
11/26/13 12:33 PM
11/26/13 12:33 PM
OHIO
THE GLASS MAN Offline
OHIO
I have been racing the max wedges since 1982 and there is nothing wrong with them. Just like any heads, make sure of no cracks , seats are good and valve guides are in good shape too.
Re: 286 Max Wedge heads...to use or not? [Re: JC Childress] #1539810
11/26/13 12:45 PM
11/26/13 12:45 PM
dogdays Offline
dogdays  Offline
So it's a stroker, the heads are halfway done.
I'd say use'em except for one thing; milled to 73cc.
Iron heads, max compression of 9.5:1, calculate the amount needed above the piston:
493 / 8 = 61.6 cubic inches
Convert to CC 61.6 X 1000 / 61 = 1010cc
R = 9.5, R-1 = 8.5
Gasket = 12cc
CC / (R-1) = cc above the piston at compression ratio R
1010 / 8.5 = 118.8 cc
118.8 - 73 - 12 = 33.8
You need 33.8cc more in the combustion chamber.
R.
Responding to later post:
If 10:1 is fine, then 112.2 above the piston, minus 72 and 12 = 28.2cc needed
You may want to use a D-shaped dish to let the squish work, 10.0:1 is pretty high for a bigblock on pump gas.
Re: 286 Max Wedge heads...to use or not? [Re: dogdays] #1539811
11/26/13 01:28 PM
11/26/13 01:28 PM
Big Island ,VA
Big Island ,VA
I can run a dished piston and be fine. 10 to 1 is fine I think
Re: 286 Max Wedge heads...to use or not? [Re: JC Childress] #1539812
11/26/13 02:01 PM
11/26/13 02:01 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
We have a set of max heads too went from 915s to the maxs with no other changes, was running 1140s all day with the 915s when we put the maxs on it, we went 10.80s all day ! Oh I did put a dommy on it also ! No port work just valve job and indy intake ! I love them ! Still got them on that old 440 ! Just going to use it as my back up motor !
Re: 286 Max Wedge heads...to use or not? [Re: 70dusterjohn] #1539813
11/26/13 05:34 PM
11/26/13 05:34 PM
Big Island ,VA
Big Island ,VA
Were gonna magnaflux them this evening and we'll see.
Re: 286 Max Wedge heads...to use or not? [Re: JC Childress] #1539814
11/26/13 07:02 PM
11/26/13 07:02 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My old 440 with 906 heads I ran at 10.1 comp. I did use the quench pad pistons and I had no pinging with 38 total timing that came in fast. I did not use a vacum advance as the dist did not have one. It ran 11.49 @ 116 best in my 3700 lb 63. Ron
Re: 286 Max Wedge heads...to use or not? [Re: 383man] #1539815
11/26/13 07:31 PM
11/26/13 07:31 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Look for horizontal cracks on the outside of the heads. They all crack under the two center exhaust ports, above the head bolts.
Re: 286 Max Wedge heads...to use or not? [Re: TRENDZ] #1539816
11/26/13 10:27 PM
11/26/13 10:27 PM
I've never seen a OEM M.W. head crack under the exhaust ports like the 906 heads do Never the less have them magnafluxed and check for cracks
Re: 286 Max Wedge heads...to use or not? [Re: Cab_Burge] #1539817
11/27/13 02:41 PM
11/27/13 02:41 PM
Big Island ,VA
Big Island ,VA
Probably just be better off to sell the Max Wedge heads and buy some 440 Source heads...........
Re: 286 Max Wedge heads...to use or not? [Re: JC Childress] #1539818
11/27/13 03:14 PM
11/27/13 03:14 PM
Probally not, you kow you want t run the M.W.. heads and intake, correct? why not do that now as long as the parts are good You can control the compression ratio with a reverse dome or dished pistons and the piston deck hieghts as well as thicker head gaskets Besides who else has a 4 door family car witha Maxie motor with two carbs. on it
Re: 286 Max Wedge heads...to use or not? [Re: Cab_Burge] #1539819
11/27/13 04:26 PM
11/27/13 04:26 PM
K
KOS Offline
KOS  Offline
K
for what their worth to some resto maxie guy i would sell them if you can get decent coin and buy some indy/eddy/etc alum head with max wedge ports.if theres no interest at what you asking $ use em.
Re: 286 Max Wedge heads...to use or not? [Re: KOS] #1539820
11/27/13 05:38 PM
11/27/13 05:38 PM
Big Island ,VA
Big Island ,VA
I just had them magnafluxed and they are fine. Still may sell them and get some alum. heads.........debating....
