Tranny fluid #1539552
11/25/13 01:12 AM
11/25/13 01:12 AM
Flordia, USA
sbmopar Offline OP
sbmopar  Offline OP
Flordia, USA
Ok guys n girls what's the right trans fluid for a 1968/ 904 tranny ? Has a shift kit and manual valve body
Re: Tranny fluid [Re: sbmopar] #1539553
11/25/13 01:15 PM
11/25/13 01:15 PM
Type F from Walmart
Re: Tranny fluid [Re: RapidRobert] #1539554
11/25/13 01:43 PM
11/25/13 01:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Old Mopars do best with type F.
Re: Tranny fluid [Re: sbmopar] #1539555
11/25/13 02:00 PM
11/25/13 02:00 PM
AL
jglen490 Offline
jglen490  Offline
AL
A 904? ATF+4.
Re: Tranny fluid [Re: jglen490] #1539556
11/25/13 02:39 PM
11/25/13 02:39 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
ATF+4 is for the newer style OD trans not the older 3 speed.
Re: Tranny fluid [Re: stumpy] #1539557
11/25/13 06:51 PM
11/25/13 06:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Whatever Type F is on sale, for anything short of a racecar. Some guys prefer Dexron over F, though. I've run both, no problems with either. The old B&M Trik-Shift fluid was re-labeled F.
Re: Tranny fluid [Re: topside] #1539558
11/28/13 03:07 AM
11/28/13 03:07 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
The "old" B&M trickshift is what I am now running in a race 727 and a powerglide plus the wifes XR7. Stuff works great and has been around forever. Less than 5.00 a qt from one of the super online parts houses.
I have always used type F but it is almost impossible to find at least in my area.
Re: Tranny fluid [Re: loaderpro] #1539559
11/28/13 10:16 AM
11/28/13 10:16 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
They have "Type-F" up here at the local Meijers (like a Wallymart, but MI based ), by quart only or I'd stock up on gallons, for $2.89/qt.
It is Meijer brand/label but I've run the Dexron III version in 2 daily drivers for at least 100k and it still looks red in both.
Re: Tranny fluid [Re: sbmopar] #1539560
11/28/13 10:29 AM
11/28/13 10:29 AM
Maryville tn
67coronetman Offline
Maryville tn
I have ran B&M trickshift and it worked great. But i run the factory trans fluid to & it works very well & my trans is very well built but its a street car mostly.....
Old car are me......
Re: Tranny fluid [Re: 67coronetman] #1539561
11/28/13 11:47 AM
11/28/13 11:47 AM
jersey
Spaceman Spiff Offline
jersey
Trick shift is just type f with blue dye.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Tranny fluid [Re: Spaceman Spiff] #1539562
11/28/13 11:54 AM
11/28/13 11:54 AM
WalMart Type F will get the job done. If you transbrake you will need to change fluid often. I put a trans temp in one time, you only need it for one race , after that you KNOW what is happening and when. On the button it can go up 100 degrees a second, will drop instantly when button is released. No trans brake, never a problem with temp if unit is healthy.
Re: Tranny fluid [Re: ] #1539563
11/28/13 03:07 PM
11/28/13 03:07 PM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
Yes, any type F is good, just hard to get here. limited supply or what ever, then if you happen upon a case of it they want anywhere from 6-10 dollars a qt. So why not use B&M? 4.97 from Summit! That oil and that company go back along ways. So I wonder how B&M got the red out and put the blue dye in? Every company has there own formulas for their oils. And if it is just a dye job (which I seriously doubt) so be it, it is still a high quality oil! The stuff works and it is cheaper than I can buy from the local parts houses.
Re: Tranny fluid [Re: ] #1539564
11/28/13 10:10 PM
11/28/13 10:10 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Was out today, had a senior moment, and went into a Wallymart to get some type F, going to change the filter on the D100 this weekend.
Totally forgot about the "black Friday" thing, I was early for that to start but they were getting ready, place was crawling with early loiterers and LOTS of employees.
OH, and they had 7 qts of type F, at 3.48/qt. I was looking for gallon jugs, a couple of 'em. nada.
And I certainly wasn't expecting it to be 3.48 /qt either!
I guess it's been a while since I bought any house brand stuff, was expecting maybe 1.50-2.00 ea.
Going back to my regular jobber, and get name brand for probably just a little more.
It takes gasoline to interest me.
Re: Tranny fluid [Re: VL21] #1539565
12/02/13 03:37 PM
12/02/13 03:37 PM
montana
P
pjc360 Offline
pjc360  Offline
P
montana
Has anyone here ran dexron6 in a 727 transmission or a A-518? I have read it is fully back words compatible to dexron3, From what I have gathered it should provide the same shift characteristics as dexron3 but it is synthetic and will last a lot longer and protect a lot better against heat. I have a non lock up A-518 that I have been running dexron3 in, but I am seriously considering trying the new dexron6.
Re: Tranny fluid [Re: stumpy] #1539566
12/02/13 04:37 PM
12/02/13 04:37 PM
AL
jglen490 Offline
jglen490  Offline
AL
Use whatever fluid you want, but finger wagging is uncalled for.
ALLPAR Torqueflite Page
Also....
ALLPAR Tranny Fix Page
Especially the part that says "Chrysler TSB# 21-006-01 notes that all current vehicles only use ATF+4 type 9602, part 05013457AA (for quart bottles). The advantages of ATF+4 over +3 (and Dexron for that matter) include:
•Better anti-wear and anti-corrosion properties — and maintains its friction properties over time
•Controls oxidation - eliminates deposits
•Anti-foaming
•Superior low temperature operation
You can use ATF+4 with all older Chrysler transmissions (except some Jeeps, as noted earlier, and very early automatics — before the TorqueFlite).
Rich Hutchinson wrote: [In 1989-91] both the manual and the dipstick said Dexron was okay, which is wrong. For non lockup 3 spds, either can be used. For lockup 3 spds up to some date in 1999 either could be used but ATF+3 was prefered. After that date ATF+4 is to be used in all automatics.
The best bet for transmissions made before 1998 is to just use ATF+4. Even if it's not needed, it's better than Dexron. "
It is a fact that ATF+4 MUST be used on the newer 4-speeds (except as noted), but there is no such prohibition on ATF+4 for the 3-speed torqueflite - only the older pre-TF trannies.
Re: Tranny fluid [Re: jglen490] #1539567
12/02/13 05:58 PM
12/02/13 05:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The backwards compatibility issue with ATF+4 has a lot to do with dealers only having to stock one fluid.
Re: Tranny fluid [Re: John_Kunkel] #1539568
12/02/13 06:14 PM
12/02/13 06:14 PM
AL
jglen490 Offline
jglen490  Offline
AL
It may be economics at work, but in reality why stock an older type fluid (or an ATF+2, ATF+3, Dexron III, etc.), when ATF+4 is a superior fluid to the other/older fluids and, except as noted with the Jeep and pre-TF trannies, is fully backwards compatible.
Re: Tranny fluid [Re: jglen490] #1539569
12/02/13 07:19 PM
12/02/13 07:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Depends on the intended usage and the ATF+4 is "superior" in lube properties but not friction properties that many desire.
Non-lockup 3-speeds don't need the lube properties.
Re: Tranny fluid [Re: John_Kunkel] #1539570
12/02/13 07:32 PM
12/02/13 07:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
jglen490, are you speaking from experience as someone who has built a few transmissions or are you just going by what you have read? My long term experience working on Mopars has shown me that the Type F fluid will make the 3speed torqueflite transmissions last longer and shift more solidly then the +4 fluid. I use +4 in all the Auto OD transmissions.
Re: Tranny fluid [Re: stumpy] #1539571
12/02/13 11:46 PM
12/02/13 11:46 PM
AL
jglen490 Offline
jglen490  Offline
AL
Since you've set yourself up as the top expert on the subject - then use whatever you want. It's no skin off my back, and there's no need to be defensive about it. My only reason for saying anything was to participate in the conversation and bring some reference material in that others might find useful - or not. If that is problematic, then perhaps we need to take this off-line.
Have a good evening.
