Need help on id for rear center 8 3/4 section #1538591
11/23/13 09:43 AM
11/23/13 09:43 AM
NH
3
36dodge Offline OP
36dodge  Offline OP
NH
I have a truck rear end that was narrowed. Now i need help acquiring the center section, prefer a posi unit. The pumpkin is open to the front. What unit is the best to seek when searching used?
part numbers to look for?
Re: Need help on id for rear center 8 3/4 section [Re: 36dodge] #1538592
11/23/13 11:17 AM
11/23/13 11:17 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
If it's a Mopar 8.75 housing you have, lot of info on it at this site.
Re: Need help on id for rear center 8 3/4 section [Re: 36dodge] #1538593
11/23/13 11:22 AM
11/23/13 11:22 AM
A "742" sure grip with the ratio you want. Those are the last 3 of the large cast in numbers on the side of the case. Might put an ad in your local CL & also see what's for sale here on Moparts.
Re: Need help on id for rear center 8 3/4 section [Re: 36dodge] #1538594
11/23/13 12:02 PM
11/23/13 12:02 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Which gear ratio would you be looking for ??
Re: Need help on id for rear center 8 3/4 section [Re: Stanton] #1538595
11/23/13 12:55 PM
11/23/13 12:55 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
they can all handle quite a bit of HP. 742 and 489 have a better selection of gear ratios. 741 742 489 have different pinion stem diameters, but this is not usually where they fail. so why are some better than others?
Re: Need help on id for rear center 8 3/4 section [Re: 65rbdodge] #1538596
11/23/13 02:11 PM
11/23/13 02:11 PM
NH
3
36dodge Offline OP
36dodge  Offline OP
NH
I have a 727 auto. Probably run gears something good with gas milage but some get up and go. I measured the shaft somewhere in the middle and got 1.50"??
Re: Need help on id for rear center 8 3/4 section [Re: 36dodge] #1538597
11/23/13 02:18 PM
11/23/13 02:18 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Good mileage 3.23. A little more get up and go 3.55.
Re: Need help on id for rear center 8 3/4 section [Re: stumpy] #1538598
11/23/13 04:52 PM
11/23/13 04:52 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
If you really want a "posi" you need a GM rear end to start with..
I am truckless..
