Re: Need help on id for rear center 8 3/4 section
[Re: 36dodge]
#1538592
11/23/13 11:17 AM
11/23/13 11:17 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
If it's a Mopar 8.75 housing you have, lot of info on it at this site.
[Re: 36dodge]
#1538593
11/23/13 11:22 AM
11/23/13 11:22 AM
RapidRobert
A "742" sure grip with the ratio you want. Those are the last 3 of the large cast in numbers on the side of the case. Might put an ad in your local CL & also see what's for sale here on Moparts.
[Re: 65rbdodge]
#1538596
11/23/13 02:11 PM
11/23/13 02:11 PM
Posts: 58 NH
36dodge
NH
I have a 727 auto. Probably run gears something good with gas milage but some get up and go. I measured the shaft somewhere in the middle and got 1.50"??
[Re: stumpy]
#1538598
11/23/13 04:52 PM
11/23/13 04:52 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
If you really want a "posi" you need a GM rear end to start with..
I am truckless..
