Re: Which is better, flat or dished piston at same comp.?
[Re: gregsdart]
#1538546
11/23/13 01:53 PM
11/23/13 01:53 PM
Posts: 22,696 Bitopia
jcc
Bitopia
However a proper chamber shape could also recreate the dish effect you suggest is beneficial, thought I read somewhere less piston surface area, ie flat is more efficient, with all other parameters being optimized. /2
[Re: jcc]
#1538547
11/23/13 06:41 PM
11/23/13 06:41 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
You would have to create more volume somewhere, so reduced quench would be the result. If we are talking about something like a 450 to 470 inch BB, then you have some choices, dish the piston and cut the head, or just run a flat top for pump gas. Once you go past that number of cubes, a dish will be needed anyway. I have 440-1 heads with 62cc chambers. They would need a dish for pump gas on anything bigger than about 420 cubes ,just off the top of my head. But the surface to volume ratio would be better with a dish than a 75 cc chamber and no dish. I suspect the comment about flat tops being better was meant to mean no dome. I fully agree with that, thats why I had the heads cut so far to reach 15/1 compression, very little dome.
[Re: Twostick]
#1538549
11/23/13 07:25 PM
11/23/13 07:25 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
The main reason the flat piston works so good is because you can get quench and a nice flat flame front that can travel very good. I mean which would you prefer to have say 11.0 comp with an open chamber head and a pop up piston or the same 11.0 comp with a closed chamber head with quench and a flat piston ?? Of course the flat piston with quench will be the better as it wont have anything in its way of the flame front that a pop up piston would. The main reason for the D-dish piston is to have quench and a pump friendly comp of about 10.5 and lower. So I would think the flat piston with quench would be best. The D-dish will work fine since part of the piston head is still flat for quench but as I said if you dont need a dished piston to drop comp then most go with the flat piston which I believe will have the best flame travel. I was going to go with flat pistons and quench but when I decided to use 75cc heads instead of the 84cc heads I had no choice but to use a D-dish piston and still have 10.6 pump friendly comp and still have quench. All said I believe the flat piston will work best. Ron
[Re: 383man]
#1538550
11/24/13 08:14 AM
11/24/13 08:14 AM
Posts: 208 Norrland, Sweden
Swedcharger67
Norrland, Sweden
My gut feeling says that a flat head, with the combustion chamber in the piston, would be the best. I've seen this design in highly efficient diesel engines. Drawback could be a somewhat heavier piston, on the other hand modern pistons are so much lighter than the old...
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
[Re: Swedcharger67]
#1538552
11/24/13 01:50 PM
11/24/13 01:50 PM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
One of reasons that works on a diesel is because they don't as a rule turn any RPM. Compared to a 6-7000 RPM engine the flame front on a diesel has all day to get its job done. I'm pretty sure the fact that the fuel is injected directly into the chamber enters into it too.
Kevin
[Re: Twostick]
#1538553
11/24/13 04:24 PM
11/24/13 04:24 PM
gregsdart
The real answer to this question may also be "it depends" Some times stuff works like it is supposed to, some times it doesn't. There are many other factors besides flame travel that will effect the end result. Stuff like the effect of tumble and swirl, how it changes as the piston rises, engine rpm used, plug location, and on and on. But figuring that we were talking about my favorite motor, a BB, then I am betting on a dish based on the fact that the majority of the fuel/air mix winds up closer to the plug, (shorter flame travel to the edge of the charge) and the quench area actually increases if you cut the heads a lot like mine are. The reason you see engines at less than 4.00 bore now days is that it is better for emissions, hp and efficiency. Some of that comes from reduced surface to volume ratio. One clue to my first statement is that I read somewhere that 60 percent of the computer design time spent on the new Corvette was spent on combustion engineering in the new motor. That alone says there is much to learn yet, and all the "rules" are subject to new info.
[Re: Hemi Allstate]
#1538555
11/24/13 09:02 PM
11/24/13 09:02 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I can only speak from experience.
The question is kinda wrong to start with. The same quench. I assume to OP means piston to head clearance. Then if you change nothing else the ratio would have to change when going from flat top to dish pistons. Opening the combustion chamber or running more valve angle to deepening the combustion chamber.
I like shallow valve angles although some say a sharper angle slows the flame in say a power adder. So if I run my small chamber heads. A shallow angle then we are talking less than 40 cc. With any stroke we have a compression problem. Running a full dish fixes this problem. Can't see how that would disturb a flame front as the valve reliefs are much less evident in a dished piston. Some heads like P7 have a lot of lumps placed in key areas to make compression with short strokes. When you install these heads on larger strokes you start thinking of getting rid of these lumps.
I have always thought if you are starting with a clean sheet of paper you should make the combustion chamber in the head 2/3 the size of the needed combustion space at TDC. Then make the piston with the other 1/3 mirrored to the head. This way at just before TDC you have better flame front characteristics requiring less ignition advance before TDC. I have always felt it was an advantage to have an engine requiring less timing.
Leon
[Re: Leon441]
#1538556
11/25/13 12:28 PM
11/25/13 12:28 PM
Posts: 610 long time lurker, short time p...
PorkyPig
I'll rephrase it for you. Closed-chamber head (Indy SR) used with flat-top pistons and 11.0 compression ratio. Mill heads to reduce volume by 10 cc and swap to pistons with dish that mirrors the combustion chamber and adds 10 cc to volume (no change to quench area or piston to head clearance). Same CR, but now part of the total chamber volume is in the dish. Is there an advantage to either approach?
[Re: PorkyPig]
#1538557
11/25/13 03:59 PM
11/25/13 03:59 PM
383man
Balt. Md
Basically what I was trying to say is that just like when I built my 493 I was shooting for zero deck and quench with about 10.5 comp for pump gas. I did not shoot for a setup to use the D-dished pistons as I wanted a flattop piston with quench and the comp ratio I was shooting for. But at the last minute I decided to use the 75cc EZ heads instead of the 84cc Eddy heads and the only way to now get comp in the 10.5 area with quench was to use the D-dish piston to have the comp I wanted and still have quench and nothing in the way of the flame travel. So to me I shoot for everything to work with the flat piston and only consider the D-dish piston if I have to much comp and a D-dish piston will get me what I want. I am not aware of any advantage of using the D-dish over the flat top other then letting the builder hit his comp mark and still have a good flame travel. Ron
