dual line oil pan for 65 B-Body #1538465
11/22/13 06:54 PM
11/22/13 06:54 PM
SoCal
jake4cars Offline OP
SoCal
Anyone use the Milodon 31470 dual line oil pan on a 65 B-body. I was looking on their site last night and spotted it. I have an old pan of unknown manufacturer now and it rubs.
My car has the original k-member and doesn't use motor plates.
If not the Milodon, anyone have any other suggestions.
Thanks!
Joey
Re: dual line oil pan for 65 B-Body [Re: jake4cars] #1538466
11/22/13 07:08 PM
11/22/13 07:08 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The tube through the pan is in a different location between early and late b-body pans. That could be the source of your problem.
Re: dual line oil pan for 65 B-Body [Re: Stanton] #1538467
11/22/13 07:25 PM
11/22/13 07:25 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The milodon oil pan for the 65 and older has the tube for the steering draglink further forward of the Milodon pan for the 66 and up B-bodys.The engine sets further forward in the 65 and earlier cars.
If your planning on a new pan call Charlies Oil Pans for a custom pan.
Re: dual line oil pan for 65 B-Body [Re: B G Racing] #1538468
11/22/13 08:54 PM
11/22/13 08:54 PM
SoCal
SoCal
Bob,
The pan I currently have is supposed to be for a 65, it doesn't rub hard but it does come into contact and that makes me nervous, I will take your suggestion and call Charlie's, at least I know it will be right for my car and not a mass produced piece.
Joey
Re: dual line oil pan for 65 B-Body [Re: jake4cars] #1538469
11/22/13 09:23 PM
11/22/13 09:23 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Bob,
Joey
Where's it rubbing,front,top,bottom or back?
Re: dual line oil pan for 65 B-Body [Re: B G Racing] #1538470
11/22/13 10:54 PM
11/22/13 10:54 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
After checking my 64 and 73 I think the hole is 1-2 inchs farther back on the 64, both with stock mounts. Is that what you meant? I got two later b-body pans and after checking i'll have to move the engine back now.
Re: dual line oil pan for 65 B-Body [Re: B G Racing] #1538471
11/23/13 01:43 AM
11/23/13 01:43 AM
SoCal
SoCal
Bob,
Joey
Front
Re: dual line oil pan for 65 B-Body [Re: jake4cars] #1538472
11/23/13 08:51 AM
11/23/13 08:51 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If it's a regular big block draglink try putting it on by reversing side to side.If it's just hitting slightly you can remove material on a sander to obtain clearence.You may loosen up all the mounts(trans) also and push the engine forward and lock it down.We have seen guys oblong the insulator holes in the mounts to gain clearence.
